Pullstart
1998 Tradewinds, Diesel Pusher Motohome
Handy Don
Looking good. Headlights need a re-aiming!
Pullstart
I have four new LED bulbs to install and aim.  It’s funny, this coach takes the old school 2B1 bulbs that are high and low beam.  The outer bulbs are wired for low and the inners for high.  Since I am changing to LED and the load will be lesser, I plan to make them all work, when asked to.  A machine this large, good lighting seems crucial to me.
Fun fact, that was one item on the coach that Julie and David were not sure if they worked.  They owned it for 17 years and never drove in the dark!
  • Haha 2
Handy Don
Totally agree on good lighting (that’s why I noticed it 😉) however I’m very sensitive to the risk of too much light, especially for oncoming and near-ahead drivers.
Since your coach’s wiring already accommodates separate high and low beam circuits I hope your plan is to add diodes of adequate capacity that will let you power both high and low from the “high side” but only the lows from the “low side."
I’ve also become a solid fan of my car’s auto-dimming system which uses a video camera and software instead of a simple sensor to detect situations where dimming is appropriate. It can remarkably reliably detect (and quickly react to) oncoming headlights, taillights of a vehicle ahead within radar range (~350 meters), overhead street lights, blinding fog, or daylight.
ebinmaine
1 hour ago, Pullstart said:
machine of any size driven in the dark,
Fixed that for you
Pullstart
I do not plan to run both high and low at the same time, but I will have the ability to run 4 low beams or 4 high beams at once.
Handy Don
So the LEDs have separate brightness and aim points for “high” and “low"?
I know that Rivian has figured out (and has the only U.S. certified version of) matrix LED tech, also called adaptive headlights.
Running 4 wide and long illumination high beams will be great for your visibility but could be very intimidating to an oncoming or ahead vehicle, even across a median. Even 4 low beams can put out a lot more light than some state regs permit (32 candlepower or ~400 lumens in NY).
I know that Michigan does not require universal annual vehicle inspections but headlight performance is part of the NYS annual inspection regime (though I concede that some inspectors are less than diligent on areas where there is no income stream opportunity for remediating non-compliance).
Pullstart
yep :handgestures-thumbupright:
I’ll make it selectable, for that reason :handgestures-thumbupright:
I saw a 2011 or so Chevy 1500 pickup yesterday with the majority of the box cut off with a sawzall, so it was a frame width “flat bed” if you will.  The frame was so rusted the section behind the cab was at about a 30 degree angle.  Sometimes I wish we did have a safety inspection. :rolleyes:  They might feel safe, but my kid could be in the oncoming lane when it rips loose.
  • Sad 1
Handy Don
Well said.
  • Heart 1
Pullstart
On 4/29/2026 at 9:54 PM, AlexR said:
CAT motors are the Cats meow!
:lol:
I’m reading and learning and watching videos on these engines and have found the Adept Ape YouTube channel.  Lots of good information there!
Pullstart
Yesterday Eloise and Cylvia went camping!
Our friend’s pusher “Cylvia” has the 8.3 Cummins that I longed for so badly. Eloise has the 7.2 3126 CAT.  Accelerating to highway speeds, or off highway, I felt very light on the throttle.  When we arrived to the campground about an hour and a half away, he mentioned how he could not keep up with me on take offs.  Once again, the 100 hp lesser engine has impressed me!
Happy 250th Independence Day, America!
  • Like 8
WHX??
That setup would look really good at Portage... that's where you was supposed to take it's cherry... :ychain:
Pullstart
You know I’d love to be there…
  • Sad 2
