TractorEd 669 #1 Posted 22 hours ago (edited) Looking for an online 1979 owners manual for a 48” deck with model number 95-48MS00. I would be okay with one from a year before or a year after that details steps to install and adjust deck for a ‘79 c-161 with hydraulic lift. Any manual/file finding gurus that can help? Edited 22 hours ago by TractorEd Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,106 #2 Posted 22 hours ago 1 2 Share this post Link to post Share on other sites
Handy Don 16,200 #3 Posted 21 hours ago 1 hour ago, TractorEd said: Any manual/file finding gurus that can help? @gwest_ca has you covered, but you can become a guru by learning to use this site’s search bar and exploring the Documents/Files archive! 1 1 Share this post Link to post Share on other sites
TractorEd 669 #4 Posted 14 hours ago @gwest_ca Thank you for the quick response! Share this post Link to post Share on other sites
TractorEd 669 #5 Posted 14 hours ago On a ‘79-ish C series with hydraulic lift, do we really adjust the lift lever chain/bar trunnion so that the rubber bumpers on the mower deck draft arms touch the bottom of the foot rests? The geometry doesn’t seem like it would work since I’d have to raise the chain up a couple/several links to get the bumpers to touch the foot rests. And that would cause other issues with removing/installing the deck as well as not being able to lower the deck enough to cut shorter. There isn’t much lift with the hydraulic version. My other C series has the manual lift and it has much more lift and making the bumper touch the foot rest is no problem and it will still be able to be lowered all the way to the ground. Share this post Link to post Share on other sites
Handy Don 16,200 #6 Posted 3 hours ago Two goals of the bumper touch: 1) a non-metal-to-metal upper limit to travel, and 2) a stabilizing position for the raised deck when driving around. 10 hours ago, TractorEd said: There isn’t much lift with the hydraulic version The different holes in the rock shaft arms give different amounts yield different lift distances. Those closest to the shaft have the least movement but need the least effort to lift and vice-versa for those farthest out. Maybe the two tractors’ are not set up the same for mower lifting? 2 Share this post Link to post Share on other sites
TractorEd 669 #7 Posted 3 hours ago (edited) 8 minutes ago, Handy Don said: Maybe the two tractors’ are not set up the same for mower lifting? They’re both using the same holes. Maybe the hydro should use different ones? The owner’s manual(s) do not differentiate between manual vs hydro on setup. Edited 3 hours ago by TractorEd Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,106 #8 Posted 3 hours ago This is a later illustration that identifies the lift locations for hydraulic lift. Still suspect they are the same for manual lift. https://www.partstree.com/models/21-14ke01-314-a-toro-garden-tractor-1985/hydraulic-lift-linkage-400-series-10/ 1 Share this post Link to post Share on other sites
TractorEd 669 #9 Posted 1 hour ago 1 hour ago, gwest_ca said: This is a later illustration that identifies the lift locations for hydraulic lift. Still suspect they are the same for manual lift. Thank you for that. I’ll try to find some time to mess around with things to see if I can “remedy” the issue. Share this post Link to post Share on other sites
