Pullstart 71,253 #1 Posted March 24 @peter lena this post is for you! I fed the paint and it’s wild seeing it spread over a couple days. Keep some oil on that old machine, it’ll keep making you happy. I rubbed some used motor oil on my 1445 Auto the other day. It’s about an inch wider now! I’ll eventually rub the whole thing, but I want to see how far it reaches. 11 2 Share this post Link to post Share on other sites
ri702bill 13,068 #3 Posted March 24 Winter Migration!!!! 2 Share this post Link to post Share on other sites
pfrederi 21,151 #4 Posted March 24 (edited) Back in the old Army we liked shinny OD paint. Officially it was semi-gloss. To make it look better for an inspection the motor pool would wipe down the truck with DF2. Looked spiffy until some other trucks drove around the dirt motor pool stirring up dust...which stuck like glue to the Diesel making them look gray. Edited March 24 by pfrederi 5 Share this post Link to post Share on other sites
peter lena 10,065 #5 Posted March 24 @Pullstart THANK YOU FOR THAT ! been doing that forever , regularly suggest any recent pick ups / buys , get a penetrating oil soak going on , if the paint has not broken . waisted away , it can typically be recovered in a perfect era patina . my problem of picture transfers , inhibits me from , sending related issues , that oil spray down is the first thing I do , on any neglect , never scrub it down , let the lubrication do that ! my paints are all decades old , yet look clean and fresh , never scratched , just lube stage recovery , once a paint breaks thru the grunge stage , thats a delicate transition , penetrating oil / mineral oil , clean oiled cloth , it starts to show itself , 6" electric palm buffer , cleaner wax , regularly lightly rub down my horses , with a clean oiled cloth , nothing else. also did the same basic on my mower decks , top and underside , hot oil sun bake , none of my decks have rot / rust . once hot oil established , they stay that way , decades in usage , maintained . thanks again , pete 3 1 Share this post Link to post Share on other sites
WHX?? 58,140 #6 Posted March 24 (edited) Nice wheel weights Doing the RJ-35 in linseed oil now ... get some pics today. Edited March 24 by WHX?? 3 Share this post Link to post Share on other sites
Lane Ranger 12,106 #7 Posted March 24 26 minutes ago, WHX?? said: Nice wheel weights Doing the RJ-35 in linseed oil now ... get some pics today. Boiled linseed oil- ! Make sure to say that as it does matter Jim! 1 1 Share this post Link to post Share on other sites
8ntruck 9,301 #8 Posted March 24 careful with the rags you used to apply the stuff. Left wadded up, they are capable of self igniting. 8 2 Share this post Link to post Share on other sites
Pullstart 71,253 #9 Posted March 24 1 hour ago, 8ntruck said: careful with the rags you used to apply the stuff. Left wadded up, they are capable of self igniting. My shop towels get burned generally. 3 Share this post Link to post Share on other sites
WHX?? 58,140 #10 Posted March 24 1 hour ago, 8ntruck said: they are capable of self igniting. Never could figure out why but agreed. 8 minutes ago, Pullstart said: My shop towels get burned generally. Yep heats the shop. 1 Share this post Link to post Share on other sites
wallfish 20,618 #11 Posted March 24 We used to tease Stevebo about his "salad dressing" tractors because he did that with used oil too. 5 Share this post Link to post Share on other sites
squonk 48,126 #12 Posted March 24 I use Penetrol so the tractor doesn't end up looking like a dust mop 2 Share this post Link to post Share on other sites
wallfish 20,618 #13 Posted March 25 14 hours ago, Pullstart said: I fed the paint and it’s wild seeing it spread over a couple days Probably creeps more than those sprays for rust penetrating bolts and nuts loose. Thin it with some carb spray and use for that. I tried gear oil for a steering wheel since a leaking trans will never have a seized hub. It certainly didn't pop right off but it worked well. It didn't happen fast but it stays there instead of evaporating so quickly. The cap on the wheel was missing so I just filled that cavity and walked away. Think is was a week to 10 days before getting back to it. Put a few drops of gear oil on there and have a race to see which one goes farther, not necessarily faster. 2 1 Share this post Link to post Share on other sites
Pullstart 71,253 #14 Posted March 25 58 minutes ago, wallfish said: Probably creeps more than those sprays for rust penetrating bolts and nuts loose. Thin it with some carb spray and use for that. I tried gear oil for a steering wheel since a leaking trans will never have a seized hub. It certainly didn't pop right off but it worked well. It didn't happen fast but it stays there instead of evaporating so quickly. The cap on the wheel was missing so I just filled that cavity and walked away. Think is was a week to 10 days before getting back to it. Put a few drops of gear oil on there and have a race to see which one goes farther, not necessarily faster. Great thoughts! I have soaked Allis Chalmers implement clasps in buckets of oil to free them up, filled a 24 hp Kohler to the brim for a year to get it to break free from seizure, why wouldn’t it have more advantages? 1 Share this post Link to post Share on other sites
mrc 1,119 #15 Posted March 25 pfrederi, while stationed on guam i was assigned care of a particular M818. i would wipe it down with diesel all the time. best looking 5 ton in the bomb dump! the 'oil it down' treatment was great protection from the salt air environment on that island too. 3 1 Share this post Link to post Share on other sites
peter lena 10,065 #16 Posted March 25 @Pullstart this is an example of my paint recovery , emphasis is on immediate anything I pick up , transition from . neglect to saved . once finished off with a 6" electric palm buffer , cleaner wax , finish , just give it a regular clean cloth penetrant wipe down , stays clean and clear , does not attract dust / dirt . doing this for years , tractors all have many removed , repetitive failures , they are amazingly solid once corrected , pete Share this post Link to post Share on other sites
WHX?? 58,140 #17 Posted March 25 (edited) Chain case done with BLO. It's the only thing i would ever use. I tryed Marvel MO and it just don't cut it. BLO drys a bit glossy and dust on it rinses right off. It. It brings out the best patina. Cons are kind of a pain and messy to apply. Have to try a spray bottle. It also should be reapplied every so often. On 3/24/2026 at 8:55 AM, Lane Ranger said: Boiled linseed oil- ! Make sure to say that as it does matter Jim! Absolutely Lane That 60 yo paint just pops. Pics don't do it justice. Before and after. Edited March 25 by WHX?? 2 5 Share this post Link to post Share on other sites
squonk 48,126 #18 Posted March 25 Rear fenders done with Penetrol. This pic is after a year of application. No slime and any dust blows off with a leaf blower. This is a pic after a month after application. Here's what they looked like before anything was done. 2 4 Share this post Link to post Share on other sites
WHX?? 58,140 #19 Posted March 26 3 hours ago, squonk said: Penetrol. Never tried it but wouldn't be beyond it... twice I liked it. Will have to pick up a can ever see it on a shelf. Share this post Link to post Share on other sites
AlexR 3,113 #20 Posted March 26 33 minutes ago, WHX?? said: Never tried it but wouldn't be beyond it... twice I liked it. Will have to pick up a can ever see it on a shelf. I can hook you up, I got a can you can have. 1 Share this post Link to post Share on other sites
WHX?? 58,140 #21 Posted March 26 (edited) 26 minutes ago, AlexR said: I got a can you can have. What else are you supposed to use it for? I never heard of it before Squonkies. Edited March 26 by WHX?? Share this post Link to post Share on other sites
squonk 48,126 #22 Posted March 26 7 hours ago, WHX?? said: What else are you supposed to use it for? I never heard of it before Squonkies. PENETROL® Oil-Based Coating Additive is a versatile low-odor additive to improve penetration, adhesion and flow of oil-based paints, stains, varnishes and primers. 2 1 Share this post Link to post Share on other sites
WHX?? 58,140 #23 Posted March 26 3 hours ago, squonk said: PENETROL® Oil-Based Coating Additive is a versatile low-odor additive to improve penetration, adhesion and flow of oil-based paints, stains, varnishes and primers. Ahhh I see ... the same as BLO. You ever use it for that? Share this post Link to post Share on other sites
squonk 48,126 #24 Posted March 26 3 minutes ago, WHX?? said: Ahhh I see ... the same as BLO. You ever use it for that? No but Penetrol doesn't attract dirt Share this post Link to post Share on other sites
Lane Ranger 12,106 #25 Posted March 26 3 hours ago, squonk said: PENETROL® Oil-Based Coating Additive is a versatile low-odor additive to improve penetration, adhesion and flow of oil-based paints, stains, varnishes and primers. I used Flood Penetrol mixed with a quart can of Rustoleum International Harvester Red several years ago to pain a 1054 Wheel Horse tractor! This Flood Penetrol does a great job of thinning thick paint and it makes a smooth finish that is difficult to distinguish from spray potted surfaces. Adhesion is great too! 2 Share this post Link to post Share on other sites
