rmaynard 17,313 #426 Posted Wednesday at 03:03 PM 18 minutes ago, Horsin'round said: Do you have 4 for me? yes Share this post Link to post Share on other sites
rmaynard 17,313 #427 Posted Wednesday at 03:04 PM 16 minutes ago, EthanL said: I’ll take one if still available You got it. Thanks. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,717 #428 Posted Wednesday at 04:06 PM 1 hour ago, rmaynard said: Okay Steve. I'll pull 3-5 for you. I don’t want to hoard them but I would like at least 3 Share this post Link to post Share on other sites
rmaynard 17,313 #429 Posted Wednesday at 04:15 PM 6 minutes ago, stevebo said: I don’t want to hoard them but I would like at least 3 I pulled 5, but you can take any number you want. Share this post Link to post Share on other sites
Mike'sHorseBarn 3,568 #430 Posted Wednesday at 05:30 PM @rmaynard I'll take 2. Thanks bob! Share this post Link to post Share on other sites
fast88pu 3,392 #431 Posted Wednesday at 05:41 PM Attacha matic front mule drives, will be at the show $20 each. You can pm me or call or text 845 591 7317 kyle 2 Share this post Link to post Share on other sites
rmaynard 17,313 #432 Posted Wednesday at 06:00 PM 35 minutes ago, Mike'sHorseBarn said: @rmaynard I'll take 2. Thanks bob! You got it. Share this post Link to post Share on other sites
Sodaking27 1,263 #433 Posted Wednesday at 06:34 PM @rmaynard Bob I’ll take 3 if still available. Thanks Share this post Link to post Share on other sites
Horsin'round 440 #434 Posted Wednesday at 07:13 PM 1 hour ago, fast88pu said: Attacha matic front mule drives I'll be in the market for one. Please set one aside for me. Thanks Share this post Link to post Share on other sites
fast88pu 3,392 #435 Posted Wednesday at 09:35 PM 2 hours ago, Horsin'round said: I'll be in the market for one. Please set one aside for me. Thanks Will do Share this post Link to post Share on other sites
zigzag 136 #436 Posted Wednesday at 10:42 PM @rmaynard I'll take 2 if you have any left. 1 Share this post Link to post Share on other sites
953 nut 66,837 #437 Posted Wednesday at 10:50 PM 9 hours ago, rmaynard said: PTO Brake Pads. 1-1/2" wide by 5/8". Perfect replacement for worn out pad. $1.00 each Please put two aside for me. Share this post Link to post Share on other sites
Blaine 76 #438 Posted 6 hours ago (edited) K&B had the points plunger i needed, and thanks to @squonk and @702854boy, i now have everything to make sparks and find out if i have a good motor, maybe tomorrow. Still looking for the 6908 drive pulley for a gear drive deck to make everything play nicely together. From what I’m gathering, WH added the 6908 pulley which has the larger outer drive pulley, to a standard 5-2362 gear drive mower so it could be used with the PT-6 pto, and called it a RL-366 mower. The one in the manual appears solid, while the one i spotted at the show today is spoked. 5” or 6” outer pulley with two smaller pulleys behind it. If anyone happens to spot one, please give me a shout and i’ll stop by Saturday morning. Edited 6 hours ago by Blaine 1 Share this post Link to post Share on other sites
Pullstart 70,195 #439 Posted 5 hours ago @Blaine come see the @stevasaurus Steve Oh Two. Whatever you need from me, let’s make it run! 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,717 #440 Posted 1 hour ago I am at the show and looking for these “arms” and cross member where it attaches to the tractor. Please let me know if you have these. The ball joint I will call it is lose in the cross member. This is for a square style 1045 deck. Share this post Link to post Share on other sites
