sqrlgtr 3,583 #1 Posted March 3 When installing didoes back in a 551 I assume i need them oriented were the juice flow toward battery correct. I smoked one or both this morning but I may have them installed wrong. Also had juice when unhooking Pos battery cable with key off or on. @squonk @Achto @WHX?? @953 nut Posted this in resto forum also but thought may get more attention here. 1 1 Share this post Link to post Share on other sites
Achto 32,246 #2 Posted March 3 1 hour ago, sqrlgtr said: When installing didoes back in a 551 I assume i need them oriented were the juice flow toward battery correct. Remove the diodes, hook your battery up. Use a multi meter to determine which terminals are hot or which ones have continuity to the positive battery terminal. The stripe on the diode should be towards the positive terminal on the battery. This allows the positive AC wave go to the battery but prevents the negative AC wave from going to the battery. Simple rectifier. Changing AC voltage to DC voltage. 3 Share this post Link to post Share on other sites
sqrlgtr 3,583 #3 Posted March 3 5 minutes ago, Achto said: The stripe on the diode should be towards the positive terminal on the battery. Thx that was what I was looking for I know I had seen this in Tecky manual before but could not find it anywhere for some reason. In my on defense I had a tooth pulled Friday and hadn't been myself for a day or two 1 Share this post Link to post Share on other sites
Achto 32,246 #4 Posted March 3 (edited) 8 minutes ago, sqrlgtr said: In my on defense I had a tooth pulled Friday and hadn't been myself for a day or two Getting 'em pulled hurts enough. Getting screws put in your jaw for implants to put them back in is not much better, but totally worth it. Edited March 3 by Achto Share this post Link to post Share on other sites
sqrlgtr 3,583 #5 Posted March 3 ya I got several I'm going to have to do sumin too just been putting it off long as I could, way too long actually. Share this post Link to post Share on other sites
WHX?? 57,629 #6 Posted March 4 3 hours ago, sqrlgtr said: I smoked one Smokem if ya got em ... Read trough them with a multi meter. Usually they go in only one way because of the notch. Notch end or cathode up feeding the fuse and the battery. 4 1 Share this post Link to post Share on other sites
Handy Don 17,168 #7 Posted March 4 Answered this in your other thread. The hazard of putting the same post in two places. 1 1 Share this post Link to post Share on other sites
Lane Ranger 12,070 #8 Posted March 4 The posting Bill Allert made is the avenue I took with my Lawn Ranger Tecumseh motors. I rebuilt three rectifier boards with the 3 amp diodes from Radio Shack and the other parts that Ed Stoller mentioned. They work and do the same thing the original diodes did and they will produce the same electrical output! Ed Stoller did three articles in the Lawn and Garden Tractor Magazine a couple years ago that highlighted this issue. The bigger HH 100 Tecumseh 10 HP electronic coils are also an issue that many Tecumseh motor owners have dealt with. Ed Stoller came up with a solution for that one too! 1 1 Share this post Link to post Share on other sites
Terry M-(Moderator) 2,308 #9 Posted March 11 From what I understand, Diodes are like an electrical "check-Valve" that allows flow in one direction only. I don"t believe that there is any rectifying or actual regulating going on.. Share this post Link to post Share on other sites
Handy Don 17,168 #10 Posted March 11 4 hours ago, Terry M said: From what I understand, Diodes are like an electrical "check-Valve" that allows flow in one direction only. I don"t believe that there is any rectifying or actual regulating going on.. No “regulating” is correct -- the diodes do nothing to control the voltage passing from the stator to the battery. But “rectifying” there is indeed. As the stator turns it creates positive and negative voltage “pressure” in alternating directions in its two connections (the frequency depends on the engine’s RPM). The diodes (as check valves) permit only the “positive” voltage to go to the battery, blocking out the “negative” voltage from each connection. . 1 2 Share this post Link to post Share on other sites
