adsm08 5,247 #26 Posted February 21 4 hours ago, sqrlgtr said: Johnny Pullstart CRash 3 Share this post Link to post Share on other sites
WHX?? 58,388 #27 Posted February 21 4 hours ago, Pullstart said: - The tractor man in black Just. Ain't. Right 1 Share this post Link to post Share on other sites
AlexR 3,139 #28 Posted February 21 I do the break the bead and dump. Lot faster, you can dump the gallon in about as fast as it comes out of the bottles. First time I did RV antifreeze going to do winter windshield washer fluid the next tires I am filling. 2 Share this post Link to post Share on other sites
WHX?? 58,388 #29 Posted February 22 2 hours ago, AlexR said: do the break the bead and dump. Maybe we can have a demo at plow day then? Gotta be as entertaining as drill presses, step bits & 3/8 taps... 3 Share this post Link to post Share on other sites
AlexR 3,139 #30 Posted February 22 5 minutes ago, WHX?? said: Maybe we can have a demo at plow day then? Gotta be as entertaining as drill presses, step bits & 3/8 taps... Well let's be honest it's only entertaining when @Pullstart does it 3 Share this post Link to post Share on other sites
sqrlgtr 4,225 #31 Posted February 22 (edited) 2 hours ago, AlexR said: I do the break the bead and dump. Lot faster, you can dump the gallon in about as fast as it comes out of the bottles. First time I did RV antifreeze going to do winter windshield washer fluid the next tires I am filling. I never figured I could get bead to seat back if I ever tried that. It doesn't take long at all with the little transfer pump, maybe 3omin per.... Edited February 22 by sqrlgtr Share this post Link to post Share on other sites
Pullstart 71,561 #32 Posted February 22 When I dumped it in the bead, I bead sealed the back bead, aired it up, broke the front side down, filled, dried, bead sealed, and aired up to bead it again. Signed, sealed, delivered. All the music today! 1 2 1 Share this post Link to post Share on other sites
Pullstart 71,561 #33 Posted February 23 I got a new digital air gauge and filler upper combo deal. Putting the accessories away, I found what looks like a fluid putter inner! 3 Share this post Link to post Share on other sites
WHX?? 58,388 #34 Posted February 23 3 minutes ago, Pullstart said: I got a new digital air gauge and filler upper combo deal. Same one I got Kev but I didn't get the filler upper hooby doo. I got robbed For what I paid figure it lasted a year don't owe me anything. Going on two now. 2 Share this post Link to post Share on other sites
sqrlgtr 4,225 #35 Posted February 23 Heres the one I have and man is it handy. Zero to 200 psi covers tractors and big truck tires. Also pic of liquid ballst adapter kit I used. 1 Share this post Link to post Share on other sites
sqrlgtr 4,225 #36 Posted February 25 Finally got around to weighing wheels/tires after adding the RV antifreeze, wish I would have remembered to weigh them before adding . Figured it added at least 45/50 # to each side maybe a little more than that. 2 Share this post Link to post Share on other sites
ebinmaine 81,281 #37 Posted February 25 1 hour ago, sqrlgtr said: Finally got around to weighing wheels/tires after adding the RV antifreeze, wish I would have remembered to weigh them before adding . Figured it added at least 45/50 # to each side maybe a little more than that. At 6.5 gals per tire and usually around 8.5 to 9 lbs per gallon you'll have an additional 55 to 58 lbs per tire. Share this post Link to post Share on other sites
sqrlgtr 4,225 #38 Posted February 25 3 minutes ago, ebinmaine said: At 6.5 gals per tire and usually around 8.5 to 9 lbs per gallon you'll have an additional 55 to 58 lbs per tire. yup your probably right I was figuring weight of water, but the antifreeze is a little heavier. 1 Share this post Link to post Share on other sites
ebinmaine 81,281 #40 Posted February 26 @squonk Some great info there Mike. 👍 Share this post Link to post Share on other sites
