WHX?? 55,672 #1 Posted February 4 In reverse ... Guy was asking for help the other day on slow reverse on a hydro. and @Racinbob commented that horses are not supposed to go fast in reverse. Designed that way for safety reasons I suspect. Some new machines including late model Toro verticals had a key switch under the seat with a light on the dash for reverse operation when the blades were spinning. So this 520 FEL I have was always a slug in reverse. Didn't matter how the motion linkage (Matt's pedal kit) was adjusted. Seemed like it took a hour to back away from the gravel pile. The other three 520's in my herd have this issue as well but not as severe and not as aggravating as they are all snow machines and don't see a lot of reverse time it seems. Since it was in the shop for other work & maintenance something was gonna be done about it. Started by marking the full forward and full reverse positions of the motion lever on top of the hydro. To get the control plate to move the lever to go to full forward was obtainable but only allowed a small amount of lever travel in reverse. The problem is the eccentric cam would bottom out in the control plate before the lever reached it's max reverse limit. Simple enough to elongate the reverse slot. Took a little more than 1/8" out was all that was needed. The motion lever now hits it's stops in both directions & a full cleaning & lubrication of all linkage makes for a very smooth pedal greasy Pete would be proud of. 4 12 2 Share this post Link to post Share on other sites
Tonytoro416 1,312 #2 Posted February 4 Going to have to take a closer look on the work 416. This may be the ticket for it also. Also has a pedal kit installed 3 Share this post Link to post Share on other sites
JoeM 9,671 #3 Posted February 4 5 hours ago, WHX?? said: Took a little more than 1/8" out was all that was needed Yep that works. Just to elaborate on the hydro, the same internal parts that provide forward also are used in reverse. It just the cam ring directs the oil to either forward or reverse from the pump to the motor. It can actually run as fast in reverse as forward. 3 1 1 Share this post Link to post Share on other sites
squonk 45,789 #4 Posted February 4 I've seen the cam itself wear a groove in it causing the same issue. Not enough pushin for the cushion! 2 Share this post Link to post Share on other sites
Racinbob 12,846 #5 Posted February 4 7 hours ago, WHX?? said: In reverse ... Guy was asking for help the other day on slow reverse on a hydro. and @Racinbob commented that horses are not supposed to go fast in reverse. Actually what I was referring to was the lever movement to get it to reverse. Basically the neutral stop. It's no secret that I'm not a hydro fan in any way but that movement drove me nuts. My wife said it really didn't bother her. I did this modification last summer to the 314-H. A mechanical stop on that bracket slot blocking the lever right at the neutral switch. From there it had to be pushed down to get to reverse. It wasn't a smooth movement from F to R. A little cutting did the trick. My wife told me the movement didn't bother her but when I was done she said she really liked it. As far as the reverse speed, I like the idea here. I would do it but this tractor will end up with a new owner this spring. 2 Share this post Link to post Share on other sites
peter lena 9,796 #6 Posted February 4 @WHX?? yup can fefinetly relate , to angularity issues , that led me to HEIM JOINTS LONG AGO ? BTW would also do a WIRING REROUTE , in the same area ? separate multiple issues , in the same zone ? the ANGULARITY OF A HEIM JOINT IS WITHOUT QUESTION , there is no hang up spot , what it does is show you the way . STOP ! take picture , or write down , what you were going to change / do , so you do not loose that thought , it happens ! that step up , slide / switch area , ironically , shows the UPCOMING frayed wire set up , ? have often used a light vinyl sleeve on metal slide areas . repetitive issues , are what you want for a refit / elimination to a problem ? my view ? TAKE ADVANTAGE IF IT ! what if ? what works ? what repeats itself ? my repetitive problems are long gone , just my way of looking at failure , no offence to anyone , make it go away , pete 1 Share this post Link to post Share on other sites
WHX?? 55,672 #7 Posted February 4 (edited) 10 hours ago, Tonytoro416 said: closer look on the work 416. Here is another improvement Tony. The spacer at the front part of the control rod has a short, maybe 3/8". I replaced it with a longer one maybe 3/4" that was just hanging out in my spacer drawer. It allowed for more a strait pull on the cam plate making things smoother. The rod comes really close to hitting the hydro top motion lever in full reverse & this gives more clearance. Pat attention to the brake return to neutral linkage for binding & lubricate. Not sure what kind of lube is appropriate maybe greasy Pete can chime in. I used a "dry" lube in hopes that it wouldn't attract dirt much like a starter bendix. The adjustment of the heim joints is critical. Even one or two turns can change things up. Fine tuning is required between here and the eccentric cam. Mark the eccentric cam so you have a good baseline to where things are at in adjusting. Remove the return to neutral spring temporarily makes adjusting much easier. Don't forget to jack up the rear when adjusting neutral under power. @cleat and the manual says no lube on the cam plate but check the pivot bushing for burrs and wear. Same with the eccentric cam. I see @76c12091520h has replacement plates now. Don't know if he has the eccentrics. Edited February 4 by WHX?? Fat Fingers 2 Share this post Link to post Share on other sites
pfrederi 20,047 #8 Posted February 4 (edited) The original post in question was about an Electro12 with a sunstrand hydro. You would have to redesign the plastic slider plate to get additional throw into reverse. Edited February 4 by pfrederi 2 Share this post Link to post Share on other sites
ACman 7,711 #9 Posted February 4 @Racinbob Bob did you leave a small detent at the neutral position ? Is this for motion control lever up by the steering wheel on the council or lover mounted on the side panel? I don’t know the 300 400 and 500 series very well as my 520 lever is up by the steering wheel. Ive never driven my tractors personally, but watching others it just seems like a pain in the butt having to push the lever down to go into reverse. Next question for everybody is there only one pedal kit for 3 , 4 and 500 series ? I’d love to add one of Matt‘s kits to my tractor and is a factory option pedal kit pretty much the same as Matt’s and Matt just improved on it ? Is the slot above the pivot hole just to adjust the tension on the plate ? My next question would be could you make the slots longer on the reverse side or even the side to increase speed or does the lever and the pump itself hit something else so you can’t make it go faster in reverse ? Does the HD just have a different Cam Hydro speed control plate or do they run a different gear ? Would be nice to get a little more speed for cruising. 1 Share this post Link to post Share on other sites
WHX?? 55,672 #10 Posted February 4 29 minutes ago, pfrederi said: redesign the plastic slider plate That might be next ... but yeah sunnies are their own breed. Funny thing with them, mine anyway, some are speedsters forward and reverse. Some are snails both ways. Even with a new plate and adjusted. Never looked into it but guessed it may be fluid related or just wear & tear on the internals. 2 Share this post Link to post Share on other sites
pfrederi 20,047 #11 Posted February 4 2 minutes ago, WHX?? said: That might be next ... but yeah sunnies are their own breed. Funny thing with them, mine anyway, some are speedsters forward and reverse. Some are snails both ways. Even with a new plate and adjusted. Never looked into it but guessed it may be fluid related or just wear & tear on the internals. With 3-D printers it might be doable....but not by me 3 Share this post Link to post Share on other sites
Racinbob 12,846 #12 Posted February 4 17 minutes ago, ACman said: @Racinbob Bob did you leave a small detent at the neutral position ? Is this for motion control lever up by the steering wheel on the council or lover mounted on the side panel? I don’t know the 300 400 and 500 series very well as my 520 lever is up by the steering wheel. Ive never driven my tractors personally, but watching others it just seems like a pain in the butt having to push the lever down to go into reverse. Next question for everybody is there only one pedal kit for 3 , 4 and 500 series ? I’d love to add one of Matt‘s kits to my tractor and is a factory option pedal kit pretty much the same as Matt’s and Matt just improved on it ? Is the slot above the pivot hole just to adjust the tension on the plate ? My next question would be could you make the slots longer on the reverse side or even the side to increase speed or does the lever and the pump itself hit something else so you can’t make it go faster in reverse ? Does the HD just have a different Cam Hydro speed control plate or do they run a different gear ? Would be nice to get a little more speed for cruising. No I didn't Jeff. Depressing the brake returns it there. That's not a bad idea though. Something to give a little feel in neutral. This is on a 314-H with the column mount lever. I can't help you on the other questions. I don't know all that much about hydros. 1 Share this post Link to post Share on other sites
Bill D 2,677 #13 Posted February 4 4 hours ago, Racinbob said: Actually what I was referring to was the lever movement to get it to reverse. Basically the neutral stop. It's no secret that I'm not a hydro fan in any way but that movement drove me nuts. My wife said it really didn't bother her. I did this modification last summer to the 314-H. A mechanical stop on that bracket slot blocking the lever right at the neutral switch. From there it had to be pushed down to get to reverse. It wasn't a smooth movement from F to R. A little cutting did the trick. My wife told me the movement didn't bother her but when I was done she said she really liked it. As far as the reverse speed, I like the idea here. I would do it but this tractor will end up with a new owner this spring. I think you should consider adding a foot pedal control in place of the hand control. I never liked hydros until I built a foot pedal control for them. Now I have more hydros than 8 speeds. Share this post Link to post Share on other sites
Racinbob 12,846 #14 Posted February 4 6 minutes ago, Bill D said: I think you should consider adding a foot pedal control in place of the hand control. I never liked hydros until I built a foot pedal control for them. Now I have more hydros than 8 speeds. I would if I was keeping the tractor. I had a foot control hydro on a junk deer when we first moved to Florida. Definitely better than a hand control. Share this post Link to post Share on other sites
peter lena 9,796 #15 Posted February 4 @Racinbob lots of those , TEFLON washers in H/W store pullout drawer section , also like super lube hydraulic lubricant , in tough areas , comes in both liquid / oil form , paste incredible operational temp range , hot / cold , once I find a fix / cure , I ENHANCE IT. especially like that on a chronic issue . something that you have regularly dealt with . Share this post Link to post Share on other sites
76c12091520h 4,129 #16 Posted February 4 5 hours ago, WHX?? said: Here is another improvement Tony. The spacer at the front part of the control rod has a short, maybe 3/8". I replaced it with a longer one maybe 3/4" that was just hanging out in my spacer drawer. It allowed for more a strait pull on the cam plate making things smoother. The rod comes really close to hitting the hydro top motion lever in full reverse & this gives more clearance. Pat attention to the brake return to neutral linkage for binding & lubricate. Not sure what kind of lube is appropriate maybe greasy Pete can chime in. I used a "dry" lube in hopes that it wouldn't attract dirt much like a starter bendix. The adjustment of the heim joints is critical. Even one or two turns can change things up. Fine tuning is required between here and the eccentric cam. Mark the eccentric cam so you have a good baseline to where things are at in adjusting. Remove the return to neutral spring temporarily makes adjusting much easier. Don't forget to jack up the rear when adjusting neutral under power. @cleat and the manual says no lube on the cam plate but check the pivot bushing for burrs and wear. Same with the eccentric cam. I see @76c12091520h has replacement plates now. Don't know if he has the eccentrics. Eccentrics coming soon! ( About a month ) 1 1 Share this post Link to post Share on other sites
Handy Don 16,049 #17 Posted February 4 6 hours ago, ACman said: is there only one pedal kit for 3 , 4 and 500 series ? I’d love to add one of Matt‘s kits to my tractor and is a factory option pedal kit pretty much the same as Matt’s and Matt just improved on it ? There are several versions of pedal motion controls with different linkages and other features. The factory kit used a single rocking pedal--toe forward, heel reverse, no self-centering but brake pedal centering on Eatons, and typically the “reverse catch” would be removed or defeated as part of the install. There is a fellow who’s made copies of this (I have two awaiting installation). Matt’s kit uses a two-armed pedal one for forward and one for reverse and self-centers as well as brake centering on Eatons Two others I know about: @BillD made his own with a two-armed pedal and included a centering spring (and brake-pedal centering?) @Ed Kennell made his own to suit his preference using a single pedal with spring-to-reverse and brake pedal centering. 1 1 Share this post Link to post Share on other sites
76c12091520h 4,129 #18 Posted February 4 Factory style: 1 4 Share this post Link to post Share on other sites
Bill D 2,677 #19 Posted February 5 3 hours ago, Handy Don said: There are several versions of pedal motion controls with different linkages and other features. The factory kit used a single rocking pedal--toe forward, heel reverse, no self-centering but brake pedal centering on Eatons, and typically the “reverse catch” would be removed or defeated as part of the install. There is a fellow who’s made copies of this (I have two awaiting installation). Matt’s kit uses a two-armed pedal one for forward and one for reverse and self-centers as well as brake centering on Eatons Two others I know about: @BillD made his own with a two-armed pedal and included a centering spring (and brake-pedal centering?) @Ed Kennell made his own to suit his preference using a single pedal with spring-to-reverse and brake pedal centering. I've actually built three different versions. I can't figure out how to attach the link to my build threads. They are titled Hydro Pedal #1, #2, #3 if anyone wants to look up the build threads. 2 Share this post Link to post Share on other sites
kpinnc 17,482 #20 Posted February 5 6 hours ago, 76c12091520h said: Eccentrics coming soon! That will be nice. The cam plates hold up better than the eccentrics do. Many of the ones I see have a groove worn in them. Just 1/16 is actually noticeable at the end of the travel on the hydro. 4 Share this post Link to post Share on other sites
JoeM 9,671 #21 Posted February 5 I know i bought some better heim joints also. those factory one are not real smooth. I fixed a couple cam plates and eccentrics on xi machines. to remove/repair the plate the hydro rear needs to be out of the machine. A good time to look and touch up a bit. I hit the eccentric with a dab of weld too. 4 2 Share this post Link to post Share on other sites
Pullstart 69,197 #22 Posted February 5 @JoeM it’s always refreshing to see clean beads! 2 1 Share this post Link to post Share on other sites
peter lena 9,796 #23 Posted February 5 @WHX?? glad for your mod , typically functional detailing , enhancing / insuring has its way . realise I constantly refer to similar issues / problems , but more often than not that suddenly makes it all good . levers / linkage areas , and related movement set ups , are basically simple , my reference to roller stooling around , has led me to many finds / to improve , think that visual change to a shoulder bolt , on lower plow squeeze lever , to plow frame point , letting you literally dial in what you want , holding that with elastic Lok nut , for swing quadrant slide pin , made my day . then basically using that thought to other spots . might even expose a related bearing hang up , ex , my pto cone does not have the brake pad set up , removed it , spins silently for years , on lucas grease , needle bearing , 3 tractors , smooth / easy / silent . thank you for being you , pete 1 Share this post Link to post Share on other sites
WHX?? 55,672 #24 Posted February 5 12 hours ago, JoeM said: remove/repair the plate the hydro rear needs to be out of the machine. Really?!?!? Most others might be able to do without taking the fender pan off. 2 hours ago, Pullstart said: @JoeM it’s always refreshing to see clean beads! Yep yer gonna put Brian out of business with beads like that! 1 Share this post Link to post Share on other sites
kpinnc 17,482 #25 Posted February 5 (edited) 17 hours ago, JoeM said: I hit the eccentric with a dab of weld too. I would appreciate it if you don't show those welds anymore. ...Reminds me just how much my welds look like ostrich crap. Edited February 5 by kpinnc 6 Share this post Link to post Share on other sites
