ebinmaine 80,065 #26 Posted February 1 2 hours ago, kpinnc said: Some folks can create models that are so realistic that they are difficult to distinguish from the real thing. There's obviously a lot of them around but search: Tim Ahlborn He's a pro level builder for decades now. Travels the country and sets up displays for commercial places like Peterbilt !! 2 hours ago, kpinnc said: Nowadays my eyesight just doesn't work well enough for that level of detail. That's what glasses and magnifiers are for young man. I have to use reading glasses for anything close. I definitely am overdue for an eye 👁 doc visit but haven't had a serious need for normal life reasons. For this hobby..... I may find the time. 5 Share this post Link to post Share on other sites
kpinnc 18,849 #27 Posted February 1 8 hours ago, ebinmaine said: young man That's meant to be you and me laughing about the same comment... 8 hours ago, ebinmaine said: glasses and magnifiers Last time I did some electronics repair, I had to use both my glasses and an illuminated magnifier. STILL struggled to see it! But the stuff was tiny in my defense. And I did get it done! 8 hours ago, ebinmaine said: For this hobby..... I may find the time. I do not sleep well on any given day. Once I'm asleep, I'm in a coma. But falling asleep no matter how tired I am is difficult. My mind races over the tiniest, silliest stuff and I can't drift off. Many of my best ideas happen in the middle of the night. Some may notice that I post stuff at 3:00AM or so... Last time I built a model, I stayed up all night to finish it. Not uncommon for me but since I can build them in the comfort of the indoors, well you get the picture... 2 1 Share this post Link to post Share on other sites
ebinmaine 80,065 #28 Posted February 1 @Wheel Horse 3D and I are looking at figuring out how to use his talents and tools to make a stretched frame in 1/25 scale. This is an internet find picture: This is my project truck: The frame(s) are approximately 11 inches long. I'd like to add 10 inches about where the pointer is. Cut paste. ✂️ Total frame length around 21", 22". This weekend I spent a few hours cutting clipping sanding fitting etc.. to get this trailer suspension mostly done. I'm at the point of needing to paint everything that's glued together a flat black. Then add more parts. I also got the 3 sections of the tank cemented individually. These are not attached to each other yet. It'll take some creative use of scrap sheet styrene between the right and middle sections. They aren't meant to be attached. 3 4 Share this post Link to post Share on other sites
ebinmaine 80,065 #29 Posted February 1 These are some reference photos of older Heil 6000 gallon tankers. @c-series don might recognize the first one. 6 Share this post Link to post Share on other sites
c-series don 12,302 #30 Posted February 2 Holy cow @ebinmaine ! Yes that is our tanker trailer. It was originally pulled buy a 1969 cabover Ford with a 534 cu.in. gas motor coupled to a 10-speed Road Ranger. That’s how I learned to drive a tractor trailer, with that combo. I was on the truck purchasing committee when we replaced the Ford with a brand new 1996 Peterbuilt 379 with a 425hp Caterpillar and a 9-Speed Fuller Roadranger. Still using that truck and trailer, 6200 gallon capacity. I’ve taken it to many fires and parades across the county. 1 6 Share this post Link to post Share on other sites
8ntruck 9,171 #31 Posted February 2 @ebinmaine - a tube of Squadron Green Stuff filler putty will be your friend on that tanker project. 3 1 Share this post Link to post Share on other sites
ebinmaine 80,065 #32 Posted February 2 7 hours ago, 8ntruck said: @ebinmaine - a tube of Squadron Green Stuff filler putty will be your friend on that tanker project. I'll check that one out. I have some Tamiya filler on order. 2 Share this post Link to post Share on other sites
MainelyWheelhorse 3,008 #33 Posted February 2 Cool, @ebinmaine I used to build kits pretty regularly from about 10-15 or 16. It was to the extent I started “kitbashing” like putting a viper engine in a Ford F-1. I’ve got them somewhere around here. I’ll grab some pics if I find them later. 3D printing and resin casting have really brought modeling to another level. There are groups on Facebook, that looking at some of the pics you would think it was a 1.1 car with scratch building down to caps on different fluid containers etc…. 4 2 Share this post Link to post Share on other sites
ebinmaine 80,065 #34 Posted February 2 13 hours ago, c-series don said: Correct me if I'm wrong here.. That appears to be filled from the ground? The ones my father pulled were all loaded from the top. You can see the hatch in other pics above. IIRC he would/ could watch the fuel meter for the amount but that's obviously not foolproof. At some point I need to come up with a generic style piping setup for the model. Tank to PTO & pump, then to ground... 2 Share this post Link to post Share on other sites
MainelyWheelhorse 3,008 #35 Posted February 2 2 hours ago, ebinmaine said: Correct me if I'm wrong here.. That appears to be filled from the ground? The ones my father pulled were all loaded from the top. You can see the hatch in other pics above. IIRC he would/ could watch the fuel meter for the amount but that's obviously not foolproof. At some point I need to come up with a generic style piping setup for the model. Tank to PTO & pump, then to ground... @ebinmaine As far as the piping setup, you may be able to find it resin cast online. I’ve heard of kits to change square body grilles, 60’s Camaros to the same year Firebirds etc.. I wouldn’t be surprised if there are kits to change a more generic tanker to a Heil from a specific time period. 2 1 Share this post Link to post Share on other sites
c-series don 12,302 #36 Posted February 2 Correct Eric, it is filled from the bottom either 4” or 6” inlets. We have a little three cylinder diesel 400 GPM pump and a 14”x14” gravity dump chute that empties the tank in about 4-5 minutes. 3 1 Share this post Link to post Share on other sites
ebinmaine 80,065 #37 Posted February 2 On 1/29/2026 at 7:47 PM, ebinmaine said: This is the model kit of the tractor that I have. My Ole Man drove International S2500s. This is a 4300. Same basic shape but this model is a little longer nose. That was IHC's fancier road tractor back then. The 2500 series was the worker of the fleet. I'll take the chrome off the grill and only use one exhaust stack. The sleeper will be removed in favor of a large hydraulic pump. That basically turns it into an S model. So here's something neat..... While perusing old magazines this evening I found that Ertl did make an S-series IHC back in the 1970s and 80s. It was obviously rare.... They retail nowadays for $300!!!!! 4 Share this post Link to post Share on other sites
c-series don 12,302 #38 Posted February 3 (edited) Just found this while looking at Nylint Tractor Trailers on the web. I’ve never seen this on before. It was for sale for over $200! I’m not going to lie, I do want it but not for that price! Edited February 3 by c-series don 2 1 3 Share this post Link to post Share on other sites
ebinmaine 80,065 #39 Posted February 3 Got my new scale model building desk in & built. 48" wide x 30" deep. This is just the scant beginnings... LOTS of storage and organizing items arriving in the next week. Shelves. Bins. Tool holders. Nice bright wide light. More new tools, supplies & several model kits. 6 Share this post Link to post Share on other sites
Handy Don 17,167 #40 Posted February 4 Notice that desktop doesn’t yet have any razor knife gouges, dried glue drips, or paint splotches. But give it time! 1 2 Share this post Link to post Share on other sites
ebinmaine 80,065 #41 Posted February 4 Just now, Handy Don said: Notice that desktop doesn’t yet have any razor knife gouges, dried glue drips, or paint splotches. But give it time! And it won't either.... I have a LARGE work blotter coming. 3 1 Share this post Link to post Share on other sites
Beap52 2,424 #42 Posted February 4 I'm working on a dilapidated industrial building for the railroad layout. Several hours work on the building and a bunch more to go. The goal is to have the train pass between this building and it's sister building with a elevated walkway between. 4 4 Share this post Link to post Share on other sites
Handy Don 17,167 #43 Posted February 5 1 hour ago, Beap52 said: dilapidated industrial building f Very early 20th century! Rusty water tower with faded brand name....? 2 Share this post Link to post Share on other sites
Beap52 2,424 #44 Posted February 5 1 hour ago, Handy Don said: Very early 20th century! Rusty water tower with faded brand name....? Yes going for early 20th century. I'm going for three roof lines. The front "office" flat, the middle rounded with exposed brick, and the "addition" peaked roof with stucco type covering over brick and some brick exposed where stucco has fallen off. To color the brick, I have three colors of "brickish" colored paint. I dab a little on a small brush and pretty much paint each brick. Below is a picture I found on computer that gave me the inspiration of tracks between builds and the walkway. I'm planning on covered the sidewalk/loading dock. Haven't given much thought about the building across the tracks--maybe rusty metal. Haven't thought about a water tower. I've got one that is in memory of my brother on another part of the track. I used his initials as the name of the water district and his ham radio call sign for the telephone number. My layout has family members owning businesses or headstones in the graveyard. Behind these building along the back of the layout I've got an are about 10" wide by a couple of feet long that I'd like to make and industry with smoke stacks, pipes running between buildings but that will be another winter project for another year. I'm beginning to collect different items that I can use for the piping and smoke stacks--straws, packaging materials whatever I can find that may fit the diorama. 2 2 1 Share this post Link to post Share on other sites
ebinmaine 80,065 #45 Posted February 5 @Beap52 Very cool. 1 1 Share this post Link to post Share on other sites
squonk 47,701 #46 Posted February 5 On 2/3/2026 at 6:15 PM, ebinmaine said: Got my new scale model building desk in & built. 48" wide x 30" deep. This is just the scant beginnings... LOTS of storage and organizing items arriving in the next week. Shelves. Bins. Tool holders. Nice bright wide light. More new tools, supplies & several model kits. I don't think Colossus will fit on that table! 1 4 Share this post Link to post Share on other sites
ebinmaine 80,065 #48 Posted February 5 36 minutes ago, squonk said: I don't think Colossus will fit on that table! Could be tight ..... 1 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,008 #49 Posted February 5 3 hours ago, ebinmaine said: Could be tight ..... @ebinmaine You could start off with building a model of how it will eventually look😀 1 1 1 Share this post Link to post Share on other sites
ebinmaine 80,065 #50 Posted February 5 13 minutes ago, MainelyWheelhorse said: @ebinmaine You could start off with building a model of how it will eventually look😀 Now ya see. In principle I like that idea quite a lot. But the reality is, I don't know what it's going to look like yet ... so it would be impossible to build a model. 2 Share this post Link to post Share on other sites
