Joker72
'74 c160 Auto Ring Job
Joker72
@oliver2-44 So you just don't put the balance gear and needle bearings back in upon re-assembly?  No other adjustments to "delete" it?
Thanks.
ebinmaine
Thanks.
That's correct.
The vibration of the engine will likely change.
It's just a matter of finding the right RPM to "work" at.
WHX??
1 hour ago, Joker72 said:
let the snow threats blow over
Yep your not in dire straits yet so wait till you can lay it up for a bit. Yes you can measure the bore and all that good stuff with just the head off.
702854boy
23 minutes ago, WHX?? said:
dire straits
Are we installing microwave ovens and moving color tvs now?
  • Haha 3
kpinnc
2 hours ago, ineedanother said:
is it reasonable to open the block and break the balance gears to remove them without getting into an entire teardown?
Yes.
Just drop the pan. The bottom gear can be reached with snap ring pliers. Top one depends on the throw of the crank as to how much of a pain it is. Probably easier to break that one. Just don't leave any debris in the case. But both shafts will (can) be left in place.
Joker72
@oliver2-44can to pull the piston to replace the rings without touching the balance gear?
oliver2-44
Yes, you can unbolt the rod from the bottom and pull the piston out the top.
whit the rod out, its even a little more access to remove those pesky balance gears.
If john Deere though they didn't need them, a Wheel Horse sure doesn't need them. (OK I'm biased)
ebinmaine
Remove the gears..... or you'll eventually wish you did.
With the piston & rod out it's an easy enough task.
Joker72
@ebinmaineI'm not arguing against but I do want to consider that it runs, what seems to be near perfectly, with the exception of consuming oil.    ??
Edited by Joker72
squonk
21 hours ago, oliver2-44 said:
@Joker72
Here's some pictures of the C161 I picked several years ago.
It was parked for many years as the balance gear destroyed the side of the piston.
You can see a needle in the oil pan and piston picture trash.
If you keep the balance gears, when you replace the bearings you also have to check the short polished shafts they ride on. As I recall, the shafts have a very tight wear allowance.
134994509_pistonskirtfailuredebrisinoilpank341.jpg.2c29fa30449bc24364b465554a26d81a.jpg
Had the exact same thing!
ebinmaine
....... for now.
The gears wear. The gear's bearings wear. The shafts wear. Combine those and it doesn't go well.
Here's a video of one of my own C160 K341s from several years ago.
I get your logic. If it ain't broke....
But REALLY check your own gears when you have the engine apart.
They WILL be out of spec.
Again ... I will NEVER go into another Kohler big block without removing the balance gears.
  • Heart 1
Joker72
I see.  Great vid!  Thanks for sharing.
Joker72
Any long-term success stories after removing the balance gear?  10-15 yrs of service since removal??
Thanks!
Edited by Joker72
ebinmaine
2 minutes ago, Joker72 said:
Any long-term success stories after removing the balance gear??  10-15 yrs of service since removal??
Thanks!
@kpinnc  ?
