Handy Don 17,735 #76 Posted November 16, 2025 3 hours ago, ebinmaine said: Not plowable. But pretty... My spouse’s favorite. She calls it picturesque and then asks if the road are good for driving! 3 Share this post Link to post Share on other sites
Wheelhorse#1 1,998 #77 Posted November 16, 2025 4 hours ago, Teddy da Bear62 said: Have any dirt roads? Never known a road commission that could properly grade a road yet! Just put on a neon yellow vest and hard hat If anyone asks? You tell them simply " budget cutbacks" Good idea , keep a look out for my pic at the post office if it doesn’t work out 1 2 Share this post Link to post Share on other sites
ebinmaine 81,281 #78 Posted November 23, 2025 I flipped the cutting edge on one plow this weekend. I plan on using this one for the scooper. For now it rests nearby my '75 C160 Automatic. 2 Share this post Link to post Share on other sites
SylvanLakeWH 32,921 #79 Posted November 23, 2025 3 2 Share this post Link to post Share on other sites
Handy Don 17,735 #81 Posted November 28, 2025 (edited) Quite unexpectedly, we had a couple of very heavy snow showers blast through this afternoon where I’m visiting my daughter and SIL south of Lowell MA. Way too warm for sticking but it looked very pretty and left my car very wet! Edited November 28, 2025 by Handy Don 4 1 Share this post Link to post Share on other sites
mudmowerdiesel 236 #82 Posted November 29, 2025 3 hours ago, ebinmaine said: Im ready for snowmobile season Share this post Link to post Share on other sites
peter lena 10,125 #83 Posted November 29, 2025 @nylyon just put on a new set of flat rubber bar snow chains , picked up 2 welded rings for spring pull point , and some springs at tractor supply , very tight set up , used a slim tapered bar as a spring hold / slider , let me plow and not damage any related driveways , pete 2 Share this post Link to post Share on other sites
kpinnc 19,107 #84 Posted November 29, 2025 1 hour ago, Handy Don said: Way too warm for sticking but it looked very pretty and left my car very wet! Sounds like typical NC snow! 2 Share this post Link to post Share on other sites
Bar Nuthin 3,644 #85 Posted November 29, 2025 (edited) 5 hours ago, ebinmaine said: We're gonna need some videos of that in action!!! Afterthought Edit: Kinda negates the trip springs, I imagine Edited November 29, 2025 by Bar Nuthin Afterthought 4 Share this post Link to post Share on other sites
ebinmaine 81,281 #86 Posted November 29, 2025 4 minutes ago, Bar Nuthin said: We're gonna need some videos of that in action!!! That you can bet on.. 4 minutes ago, Bar Nuthin said: Afterthought Edit: Kinda negates the trip springs, I imagine There's a slot in the sides that could permit some trip movement or pivoting of the sides. I'm choosing to leave them firmly bolted in place for now. Likely look at bracing options tomorrow. 2 1 Share this post Link to post Share on other sites
Bar Nuthin 3,644 #87 Posted November 29, 2025 (edited) 10 minutes ago, ebinmaine said: There's a slot in the sides that could permit some trip movement or pivoting of the sides. I'm choosing to leave them firmly bolted in place for now. Likely look at bracing options tomorrow. You could always weld 2 rods on each backside. The bottom hole circular to match rod diameter. Top hole slotted arc to allow the side panels to float with the terrain. Washers (or plates?) and pins for easy removal. Edited November 29, 2025 by Bar Nuthin 3 Share this post Link to post Share on other sites
ebinmaine 81,281 #88 Posted November 29, 2025 7 hours ago, Bar Nuthin said: You could always weld 2 rods on each backside. The bottom hole circular to match rod diameter. Top hole slotted arc to allow the side panels to float with the terrain. Washers (or plates?) and pins for easy removal. The plates themselves are very strong. My concern is the attachment point where they bolt to the plow. I'm thinking about getting a corner brace from approximately 12" out from the plow and brace making a triangle 🔺️. Simple strap steel. The terrain float isn't likely to be a huge issue. Our driveway surface is pretty flat. 4 Share this post Link to post Share on other sites
Ed Kennell 47,942 #89 Posted November 29, 2025 Erics Snow pusher Cleats Snowplow 3 2 1 Share this post Link to post Share on other sites
Lane Ranger 12,167 #90 Posted December 1, 2025 We got about four inches Saturday and Sunday in two different snowfalls. Melted a bit on Sunday. More snow expected this evening and tomorrow morning. So i had a bobboo event where i cliped a concrete curb with the B-80 snowplow Saturday. i had this happen once before and knew what to do. I never fully understood how the snowplow springs work until the first time i did this . The spring actually has the top and bottom screw into the spring to hold in place. You can see in these pictures. Very easy to correct by screwing the detached piece back in the spring and reattaching on the horizontal rods with ins. 6 Share this post Link to post Share on other sites
peter lena 10,125 #91 Posted December 1, 2025 @c-series don like your fleet , ever slicken up that plow blade ? really lets me back plow easily , for more sun areas melting . then the sun puts it in the corner drains , used mineral oil and also PAM food spray , pete 3 Share this post Link to post Share on other sites
cleat 9,448 #92 Posted December 1, 2025 Well, we got lucky this weekend and just got a light dusting of snow. Much more was forecast but it never happened, just lots of wind. 5 Share this post Link to post Share on other sites
adsm08 5,247 #93 Posted December 1, 2025 Good old Rom Tussel and his ilk are calling for 3-5 tomorrow. I'm off this week, so I guess I best go get tractors ready for snow duty. 2 Share this post Link to post Share on other sites
c-series don 12,752 #94 Posted December 1, 2025 @peter lena Yes Pete, Pam cooking spray after a light sanding with fine sandpaper depending on the smoothness of the blade. 3 1 Share this post Link to post Share on other sites
nylyon-(Admin) 9,196 #95 Posted December 1, 2025 The weather forecasters aren’t in agreement, some are saying we will have a rain event, and others 3-6”? Going to get the plowing tractor in position just in case. 6 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,898 #96 Posted December 1, 2025 LOL! Snow coming/forecasted for tomorrow and guess who’s driving up to Maine for work . Might even be driving up while it’s coming down, although my plan is to leave early and be off the highways before snow starts falling. But my 510-8 and Ariens snowblower are prepped and ready for action. 7 Share this post Link to post Share on other sites
pfrederi 21,342 #97 Posted December 1, 2025 Snow horses, 2 plows and blower are ready to go... Big improvement this year, garage door remotes for each snow horse 5 4 Share this post Link to post Share on other sites
ebinmaine 81,281 #98 Posted December 1, 2025 3 of the Herd are nearly ready. Just a couple minor things to attach. The Ugly Bruce tractor with a 48". The Military Tribute Tractor Milie with a 42". The '75 C160 Automatic with Super Scooper in now. That may get changed to the wiiiide 60" blade or the two stage tall chute snowblower. 7 3 1 Share this post Link to post Share on other sites
adsm08 5,247 #99 Posted December 1, 2025 855 is gassed up, chained up, hydraulics are all back together, albeit a bit jankier than usual, but not leaking, and the plow is on. So there will be no snow. 1 2 Share this post Link to post Share on other sites
ebinmaine 81,281 #100 Posted December 1, 2025 11 minutes ago, adsm08 said: . So there will be no snow. One can hope Share this post Link to post Share on other sites
