tmix61 95 #1 Posted October 9, 2025 Looking to buy a c175 automatic was wondering where the tow valve is so I can push it I know it doesn't run will I need a special tool to open the valve not sure where it is? Share this post Link to post Share on other sites
953 nut 69,339 #2 Posted October 9, 2025 Many C-175s had the Eaton 1100 which has no tow valve, just move the direction control lever to forward. 1 1 Share this post Link to post Share on other sites
tmix61 95 #3 Posted October 9, 2025 I thought all automatic had a tow valve Share this post Link to post Share on other sites
kpinnc 18,967 #4 Posted October 9, 2025 6 minutes ago, tmix61 said: I thought all automatic had a tow valve Eaton 1100 hydros do not. Sundstrands do have a valve. If you can get pics under the right side rear fender we can tell you which is which. Or- with the brake released (usually just push and release the brake pedal all the way) it will roll easily by hand if it is an Eaton. If not, it's likely a Sundstrand. DO NOT FORCE IT EITHER WAY. 1 Share this post Link to post Share on other sites
tmix61 95 #5 Posted October 9, 2025 (edited) The tractor is for sale 75 miles from home just thought I would ask if anybody knew. Now I'm scared to go look at it. I hate to wreck something by pulling it onto my trailer. I'm sure this picture doesn't help much but this is all I have to go by Edited October 9, 2025 by tmix61 Picture Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #6 Posted October 9, 2025 If you get a chance at the tractor model number the transmission is in it. 01-17KS01 will have the Sundstrand hydro. 01-17KE01 will have the Eaton hydro. 17 = hp K = Kohler Share this post Link to post Share on other sites
tmix61 95 #7 Posted October 9, 2025 Where would the tow valve be on a sandstrand hydro? Share this post Link to post Share on other sites
Lee1977 7,772 #8 Posted October 9, 2025 Most C-175 have Eaton's . 1 Share this post Link to post Share on other sites
Ed Kennell 47,362 #9 Posted October 9, 2025 The 1980 C-175 had the Sundstrand 90-1173. The others had the Eaton 1100 that is safe to push 1 Share this post Link to post Share on other sites
Ed Kennell 47,362 #10 Posted October 9, 2025 I believe the 90-1173s tow valve was a 7/16 hex head bolt on the left rear of the transmission. Paul @pfrederi may know for sure. Share this post Link to post Share on other sites
ri702bill 13,068 #11 Posted October 9, 2025 Or... lift the Rear with a floor jack to get it on the trailer... Share this post Link to post Share on other sites
tmix61 95 #12 Posted October 9, 2025 It's a lawn mower for sale 75 miles from home so I'm sure it's in a storage shed out in a yard somewhere from the looks of the picture so using a floor jack but not be the way to go how can I tell if it's a sundstrand or a Eaton by looking at it? Share this post Link to post Share on other sites
kpinnc 18,967 #13 Posted October 9, 2025 (edited) Wooden dollies at Harbor Freight are $12 each, and about the right size for the rear wheels. If you don't buy it, just return them. So long as you have a hard surface to roll to the trailer you'll be fine if it is by chance a Sundstrand. Edited October 9, 2025 by kpinnc Share this post Link to post Share on other sites
c-series don 12,452 #14 Posted October 10, 2025 You can easily tell by the filter location. Eaton is on the End. Sunstrand is on the Side. That’s just an easy way to remember. 2 Share this post Link to post Share on other sites
tmix61 95 #15 Posted October 10, 2025 You wouldn't happen to have a picture of that would you? Share this post Link to post Share on other sites
Lee1977 7,772 #16 Posted October 10, 2025 It's not a C-175, but this is the location of the trans. filter on an Eaton. 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #17 Posted October 10, 2025 Would item # 46 be the tow valve on the Sundstrand? Bottom of the page https://www.partstree.com/models/01-17ks02-c-175-toro-garden-tractor-1980/automatic-transmission-1/ Share this post Link to post Share on other sites
c-series don 12,452 #18 Posted October 10, 2025 @gwest_ca That’s it! It takes a 5/16” wrench, not a 7/16” like @Ed Kennell said. C’mon Ed get it together, you’re off by an 1/8” get it together. You should know better 😜😜 1 Share this post Link to post Share on other sites
tmix61 95 #19 Posted October 10, 2025 1 minute ago, c-series don said: @gwest_ca That’s it! It takes a 5/16” wrench, not a 7/16” like @Ed Kennell said. C’mon Ed get it together, you’re off by an 1/8” get it together. You should know better 😜😜 Would you have a picture to show me exactly where it would be new to the 175s I own a d200 I know where that is. LOL Share this post Link to post Share on other sites
953 nut 69,339 #20 Posted October 10, 2025 If it is a Sundstrand it would be a 90-1173 as pictured below. The push valve is circled for you. Now go buy it and remember, 3 1 Share this post Link to post Share on other sites
Ed Kennell 47,362 #21 Posted October 10, 2025 (edited) 46 minutes ago, c-series don said: It takes a 5/16” wrench, not a 7/16” like @Ed Kennell said. C’mon Ed get it together, you’re off by an 1/8” get it together. You should know better 😜😜 OK, you passed Don. I was just checking to see if you were paying attention. Now dust off your Polaroid and get tmix61 a picture.. Edited October 10, 2025 by Ed Kennell 4 Share this post Link to post Share on other sites
tmix61 95 #22 Posted October 11, 2025 Thanks for all the help guys I will be going down Sunday to look at the lawn mower at least I know I can push it and find a tow valve. Or if it has a filter in the back of the lawn mower I can just push it with no repercussions thanks again to all you guys 3 1 Share this post Link to post Share on other sites
Bar Nuthin 3,243 #23 Posted October 11, 2025 14 minutes ago, tmix61 said: Thanks for all the help guys I will be going down Sunday to look at the lawn mower at least I know I can push it and find a tow valve. Or if it has a filter in the back of the lawn mower I can just push it with no repercussions thanks again to all you guys If it is the Sundstrand - that valve can be hard to reach and tight/stiff as all get out (especially with a tiny 5/16 wrench). If it's tight, work it a little at a time, back and forth. I just ran into this on a C-141. But with a little perseverance, I got it freed up. 1 1 Share this post Link to post Share on other sites
953 nut 69,339 #24 Posted October 11, 2025 11 hours ago, tmix61 said: if it has a filter in the back of the lawn mower I can just push it with no repercussions On the Eaton 1100 you will hear a slight clicking noise while pushing it, this is normal. 1 1 Share this post Link to post Share on other sites
Dan 312-8 617 #25 Posted October 11, 2025 11 hours ago, tmix61 said: Thanks for all the help guys I will be going down Sunday to look at the lawn mower at least I know I can push it and find a tow valve. Or if it has a filter in the back of the lawn mower I can just push it with no repercussions thanks again to all you guys What I love about this forum. Everyone is always willing to help with the perseverance of this brand! 1 1 Share this post Link to post Share on other sites
