TonyToro Jr. 2,042 #1 Posted September 27 Good evening. I picked up a 1257 today. The owners says it ran but TBD. The main issue is it will only roll so far (maybe a foot) and the transmission will lock up. The rod going through the transmission from the brake drum to the other side moves up and down for some reason. I think I’m missing something there. Also, the shifter is loose but we kinda got it tighten but the screw is a little messed up so I need a new one of those. And best part when the transmission tipped water came out. (Yay!!) Hopefully you guys can help. I will get some pictures tommorow. Share this post Link to post Share on other sites
953 nut 61,318 #2 Posted September 28 Sounds like the nut has come off one of the differential bolts. Don't force it or you may bust something inside. 3 Share this post Link to post Share on other sites
TonyToro Jr. 2,042 #3 Posted September 28 18 minutes ago, 953 nut said: Sounds like the nut has come off one of the differential bolts. Don't force it or you may bust something inside. Thanks. I think our plan is to open it up tommorow. 1 Share this post Link to post Share on other sites
ebinmaine 73,934 #4 Posted September 28 10 hours ago, TonyToro Jr. said: open it up This is the way. Getting in there and verifying the actual issue. Repair as needed. Whatever you find, the parts are available. 2 Share this post Link to post Share on other sites
stevasaurus 23,381 #5 Posted September 28 This should be the #5058 bevel gear differential transmission. Along with the bolts, you have roll pins in the differential. Take pictures please. 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,042 #6 Posted September 28 So I have verified it’s missing this bearing too. I ordered this from WH parts and more. Does the bearing get put in from the inside or the outside of the case? Share this post Link to post Share on other sites
stevasaurus 23,381 #7 Posted September 28 From the outside toward the inside. The bearing is pressed or tapped in enough to make room for the seal (1/8"). A cap bearing is pressed or tapped in until flush with the ounside of casting. 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,042 #8 Posted Sunday at 11:16 PM Today we dug into it. First got the hub and drive pulley off. Then got the hitch pin to move some so we will smash the rest of that out tommorow. Then drained the water from the transmission and soaked all the bolts so we can remove the transmission tommorow and really dig into it. And in one of the pictures you can see how the brake rod is missing that bearing Here’s the pics! 1 3 1 Share this post Link to post Share on other sites
953 nut 61,318 #9 Posted Sunday at 11:31 PM Great hub puller. Looking forward to your progress. Share this post Link to post Share on other sites
stevasaurus 23,381 #10 Posted Monday at 07:16 PM Actually, missing that cap bearing could be causing your locked up trans issue. The large gear on that shaft is on that end, just on the other side of that hole there. Great pictures...thanks 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,042 #11 Posted Monday at 11:00 PM So I’m kinda glad we pulled the transmission. Look at the pictures @stevasaurus I think you are right. Nothing else seems to be broken. Hopefully the bearing will be here by Thursday. I have the gears and parts socking right now to hopefully clean them. Tommorow I’m going to fully clean the transmission and the inside. 1 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,042 #12 Posted Tuesday at 12:40 AM Ok another question Is it ok if I just use some simple green to clean the inside of the transmission and then spray it with brake and parts cleaner after it’s all clean? 1 Share this post Link to post Share on other sites
WHX?? 52,416 #13 Posted Tuesday at 12:52 AM If that's all you have that's fine. As long as you get any big chunks of stuff and loose rust off. Give it a good blow out with the air compressor if possible. Be careful not to over spin the 1533s with the air. On 9/28/2025 at 12:14 PM, stevasaurus said: cap bearing is pressed or tapped in until flush with the ounside of casting You sure it's not flush with the inside Steve? 1 Share this post Link to post Share on other sites
kpinnc 15,165 #14 Posted Tuesday at 06:02 AM Is that a bevel gear differential? That tranny should clean up nice. You did good being easy with it. Makes me wonder how that bearing popped out? Share this post Link to post Share on other sites
squonk 44,296 #15 Posted Tuesday at 10:10 AM (edited) I would have cleaned everything before ordering anything. You never know what might be lurking in the other bearings under the crud. That bearing left the chat by locking up and destroying itself or rot. The other bearings can't be too far behind. Edited Tuesday at 10:12 AM by squonk 1 1 1 Share this post Link to post Share on other sites
stevasaurus 23,381 #16 Posted Tuesday at 08:41 PM @WHX?? ...flush with the outside Jim...I am positive. @kpinnc...yes, that endplate gives it away...1 1/8" axles too. @TonyToro Jr....I would not use brake fluid inside the transmission. That stuff will be caustic to the seals if traces are still there. Better to use diesel fuel or kerosene. I would also take apart that differential and clean that also. If the other bearings are good, I would still change out all 4 the seals. 1 1 Share this post Link to post Share on other sites
953 nut 61,318 #17 Posted Tuesday at 11:16 PM 22 hours ago, TonyToro Jr. said: Ok another question Is it ok if I just use some simple green to clean the inside of the transmission and then spray it with brake and parts cleaner after it’s all clean? I would avoid both simple green and brake cleaner inside of a transaxle. Mineral Spirits would be the way to go in my opinion. 2 1 Share this post Link to post Share on other sites
ebinmaine 73,934 #18 Posted Tuesday at 11:20 PM 3 minutes ago, 953 nut said: brake cleaner I've been known to use brake clean to get a bearing spotless but I also use spray oil right after. Dry bearing no happy happy. 1 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,042 #19 Posted Tuesday at 11:24 PM (edited) 13 minutes ago, 953 nut said: I would avoid both simple green and brake cleaner inside of a transaxle. Mineral Spirits would be the way to go in my opinion. Yep I didn’t I just used a rag, and the air hose and a nylon brush for and got it the best I could All new bearings ordered from WH parts and more so now we are at a standstill for now Once we get it running and driving I am going to run it for a hour or so and drain it again. Edited Tuesday at 11:29 PM by TonyToro Jr. 4 1 Share this post Link to post Share on other sites
squonk 44,296 #20 Posted Wednesday at 10:33 AM (edited) Since you are replacing all the bearings and seals, you can clean the case and gears with whatever you desire. I used Dawn degreaser and Power wash on the 2 3 spds I did. Then brake cleaner on all the gears to get all the grit out of the teeth. Then a light coat of oil or assembly lube to keep from rusting until the parts arrive. As far as bearing depth, Before disassembly I used a depth gauge on the bearing caps to the outer edge on both transmissions and they were recessed about 1/16th of an inch Edited Thursday at 10:24 AM by squonk 2 1 Share this post Link to post Share on other sites
stevasaurus 23,381 #21 Posted Wednesday at 07:07 PM Well, it looks like a depth of new cap bearings discussion is in order. So be it. To be fair to @TonyToro Jr. , I suggest we start a new topic and not ruin his thread. The cap bearing issue is common to all of the Wheel Horse manual and auto transmissions, and since there seems to be no resourse from Wheel Horse clearifying the issue, it will be up to us and our common since and experience to determine the correct depth of placement of the "Cap Bearing". Gentlemen, let's have the discussion we can all be proud of that effects all of us who have re-built one of these excellent transmissions. Link is here. 2 Share this post Link to post Share on other sites
TonyToro Jr. 2,042 #22 Posted Thursday at 12:28 AM 5 hours ago, stevasaurus said: Well, it looks like a depth of new cap bearings discussion is in order. So be it. To be fair to @TonyToro Jr. , I suggest we start a new topic and not ruin his thread. The cap bearing issue is common to all of the Wheel Horse manual and auto transmissions, and since there seems to be no resourse from Wheel Horse clearifying the issue, it will be up to us and our common since and experience to determine the correct depth of placement of the "Cap Bearing". Gentlemen, let's have the discussion we can all be proud of that effects all of us who have re-built one of these excellent transmissions. Link is here. Thank you for making a new thread Steve. 1 Share this post Link to post Share on other sites
TonyToro Jr. 2,042 #23 Posted Thursday at 10:29 PM Parts have shipped and will be here Monday. Thanks @wheelhorseman! 1 Share this post Link to post Share on other sites
