gt14rider 1,244 #1 Posted June 20, 2025 Morning all, I've been working on the 856 and would appreciate your thoughts on this head. These spots just don't want to disappear, first sandpaper grit was 180, worked for a while and this mark's don't want to clean up. Should I keep going? 0.001 feeler gauge won't go under the head. Thanks 1 Share this post Link to post Share on other sites
ebinmaine 79,715 #2 Posted June 20, 2025 18 minutes ago, gt14rider said: Should I keep going? 0.001 feeler gauge won't go under the head. Manual might say something like .003 or less? I don't see why you shouldn't be able to just run that on some 400 paper for a little while and smooth it out. Then reinstall. 1 1 Share this post Link to post Share on other sites
oliver2-44 11,632 #3 Posted June 20, 2025 Some you been sanding awhile, that spot had a little depth. Yes manual says .003 feeler gage. You have a lot of good smooth contact area around it. If a .001 won't go under it I’d would run it. 1 1 Share this post Link to post Share on other sites
8ntruck 9,057 #4 Posted June 20, 2025 Looks to me like that head casting has a bit of porosity. It might not sand out. I'll agree with the others - probably good to run. If it were mine, I'd use a new head gasket. Might think about using Copper Coat on the gasket as well 3 Share this post Link to post Share on other sites
ebinmaine 79,715 #5 Posted June 20, 2025 5 minutes ago, 8ntruck said: Copper Coat Not sure I've ever done that on any of my own but I thought about it several times. Then I forgot about it. Maybe a good idea here. 1 Share this post Link to post Share on other sites
gt14rider 1,244 #6 Posted June 20, 2025 (edited) 1 hour ago, 8ntruck said: Looks to me like that head casting has a bit of porosity. It might not sand out. That's what it looks like, did a little sanding with 500 grit, I'll get a genuine kohler head gasket , should work fine. Thanks for input , waiting on gaskets, every part I've ordered lately is taking 2-3 weeks, still don't have the tires yet,. Well it gives me time to brake something else, Can't feal those mark's with my fingernail. Edited June 20, 2025 by gt14rider Share this post Link to post Share on other sites
gt14rider 1,244 #7 Posted June 20, 2025 Got a question, looking for a good head gasket, what the scoop on Rotary or stens, head gaskets. Any genuine kohler gaskets all seem to take 2 weeks to get here. THANKS Share this post Link to post Share on other sites
ebinmaine 79,715 #8 Posted June 20, 2025 Somebody was looking for one just recently that had a fire ring in the middle. Share this post Link to post Share on other sites
ri702bill 12,496 #9 Posted June 20, 2025 1 minute ago, gt14rider said: Got a question, looking for a good head gasket, what the scoop on Rotary or stens, head gaskets. Any genuine kohler gaskets all seem to take 2 weeks to get here. THANKS But it's worth the wait. The OE gasket with the fire ring is the way to go. Are you sanding in a figure-8 motion?? That gives the best result. DO retorque the head after allowing the engine to get to temp with no load. Repeat as many times as necessary to compress the gasket and have the proper torque when cold. Usually takes 3 or 4 times..... 1 Share this post Link to post Share on other sites
gt14rider 1,244 #10 Posted June 20, 2025 Don't see any with the fire ring , thay say genuine kohler but don't have the ring Share this post Link to post Share on other sites
gt14rider 1,244 #11 Posted June 20, 2025 I don't think the small block head gasket (k181) has a fire ring like the big block head gasket (k241- k321). I found some genuine kohler head gaskets but don't have a fire ring. Anybody know. Share this post Link to post Share on other sites
ebinmaine 79,715 #12 Posted June 20, 2025 My understanding is that old ones did. New ones do not. @Achto ? @WHX?? 1 Share this post Link to post Share on other sites
adsm08 4,802 #13 Posted June 20, 2025 (edited) 45 minutes ago, gt14rider said: I don't think the small block head gasket (k181) has a fire ring like the big block head gasket (k241- k321). I found some genuine kohler head gaskets but don't have a fire ring. Anybody know. I think older ones did. I have not been able to source one with a ring in the 6 years I've owned my WH. 22 minutes ago, ebinmaine said: My understanding is that old ones did. New ones do not. @Achto ? @WHX?? Not sure where @Achto is. I saw @WHX??sitting on his butt with @squonkand @953 nut this morning in Biglerville. He weren't particularly close to the computer at that time. 2 hours ago, ebinmaine said: Somebody was looking for one just recently that had a fire ring in the middle. That was me. Never did find one. Edited June 20, 2025 by adsm08 3 Share this post Link to post Share on other sites
gt14rider 1,244 #14 Posted June 20, 2025 @adsm08 what do you prefer the stens, or rotory. 1 Share this post Link to post Share on other sites
adsm08 4,802 #15 Posted June 21, 2025 1 hour ago, gt14rider said: @adsm08 what do you prefer the stens, or rotory. I don't know that I can say. I have been using Stens mostly. I think the most recently replaced on was a "Garden Buddy". It looks to be about the same as the Stens, price was within a dollar. I think the biggest difference when I bought was how fast I could have it. I'm not sure I ever used a Rotory brand one. 1 1 Share this post Link to post Share on other sites
squonk 47,419 #16 Posted June 21, 2025 The old Kohler gasket with the fire ring has been replaced by a graphite coated one. I think the Stens gasket is still the metal wafer. 1 1 Share this post Link to post Share on other sites
ebinmaine 79,715 #17 Posted June 21, 2025 38 minutes ago, squonk said: gasket with the fire ring Or the metal wafer. You have a preference? Share this post Link to post Share on other sites
Achto 32,101 #18 Posted June 22, 2025 Here is a small block head gasket with a fire ring. https://www.ebay.com/itm/235643113133?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D264183%26meid%3D76ff18c6941848fa917702a13190f196%26pid%3D101224%26rk%3D3%26rkt%3D5%26sd%3D275631368204%26itm%3D235643113133%26pmt%3D0%26noa%3D1%26pg%3D2332490%26algv%3DDefaultOrganicWebV9BertRefreshRankerWithCassiniEmbRecall%26brand%3DKohler&_trksid=p2332490.c101224.m-1 I believe that Rotary gaskets also have a fire ring. 2 Share this post Link to post Share on other sites
