UNBOUND 73 #1 Posted June 2 Changing trans fluid in my Raider 14. The drain plug is rounded and cant remove. I am having to suck it out and may not get it all. Plan on filling with diesel, drive it around some, drain it, refill with diesel, drive it , drain and fill with lube. Will the small amount of diesel left in there hurt anything? The drain plug is 1/4 allen, correct? That what I used and it just slips. 1 Share this post Link to post Share on other sites
ebinmaine 75,732 #2 Posted June 2 Diesel is a lubricant of sorts but I'd want to get as much of that out of there as possible. There's a hump in the middle of the inside of these cases so there's going to be some fluid left over in the front. There's a drain plug on the bottom as you know. There is sort of a fill plug at the left rear of the case on the side. Raise the front of the tractor as much as you can SAFELY do so with a tilt favoring that direction. Proceed as planned..... I would change the fluid multiple times and I would also raise the tractor every single time. 2 Share this post Link to post Share on other sites
Achto 30,188 #3 Posted June 2 32 minutes ago, UNBOUND said: The drain plug is 1/4 allen, correct? That what I used and it just slips. I have used a Torx bit to remove a rounded out Allen. Find a Torx that is just a bit bigger than the rounded out socket. Drive the bit in with a hammer as far as it will go. Sometimes this will be enough bite to get the plug out. 1 1 Share this post Link to post Share on other sites
Horse Newbie 7,398 #4 Posted June 2 If Achto’s remedy doesn’t work, drill out the Allen head plug, a bit smaller than its diameter. Use an “Easyout”, or screw extractor to back it out. I have actually drilled out most of such screw/ plugs and collapsed the screw in upon itself. Chase the threads in the drain hole with a tap. Then do as Eb says… 2 Share this post Link to post Share on other sites
UNBOUND 73 #5 Posted June 2 I have used torx several times with success but cant seem to find the one I need. Its here somewhere, just need to find it. 2 1 Share this post Link to post Share on other sites
Ed Kennell 43,779 #6 Posted June 2 2 hours ago, UNBOUND said: I am having to suck it out and may not get it all. Do it right...get the plug out 2 Share this post Link to post Share on other sites
UNBOUND 73 #7 Posted June 2 Found my t45 which is what I needed and got it out. When I fill it do I fill until it runs out the plug on the side or go by the dip stick. I ask because when I put the diesel in it, it ran out the plug but nothing showed on dipstick. I would assume dip stick would be correct. But I have read on certain sites that you fill until it runs out of plug. 1 Share this post Link to post Share on other sites
Ed Kennell 43,779 #8 Posted June 2 (edited) Tractor 1972 Raider 8, 10, 12 & 14 D&A OM Wiring Rev SN.pdf - 1965-1972 - RedSquare Wheel Horse Forum Edited June 2 by Ed Kennell 1 Share this post Link to post Share on other sites
UNBOUND 73 #9 Posted June 2 So that manual would apply to my Raider 14? If so where can I down load from. Cant seem to find an owners manual for my tractor thats a download. 1 Share this post Link to post Share on other sites
stevasaurus 23,515 #10 Posted June 2 Look here for your Raider. You did not say what year you have. Manual Section on main page. https://www.wheelhorseforum.com/files/category/8-1965-1972/ 1 Share this post Link to post Share on other sites
ebinmaine 75,732 #11 Posted June 2 1 hour ago, UNBOUND said: Found my t45 which is what I needed and got it out. When I fill it do I fill until it runs out the plug on the side or go by the dip stick. I ask because when I put the diesel in it, it ran out the plug but nothing showed on dipstick. I would assume dip stick would be correct. But I have read on certain sites that you fill until it runs out of plug. Just put in 2 quarts in any manual transmission and you're fine. 1 Share this post Link to post Share on other sites
pfrederi 19,247 #12 Posted June 2 If you are having to use a Torx to get the plug out time to buy a new one a whole $ 0.26 3 Share this post Link to post Share on other sites
ri702bill 10,567 #13 Posted June 2 Inspect what comes out in the first draining for broken gear teeth bits & needle bearing rollers.. you may be unpleasantly surprized... 1 Share this post Link to post Share on other sites
UNBOUND 73 #14 Posted June 2 There isnt an owners manual that I can find there, I do have a parts manual but thats not helpful I will do the 2 quarts and check dipstick.. The dipstick is there for a reason. 52 minutes ago, stevasaurus said: Look here for your Raider. You did not say what year you have. Manual Section on main page. https://www.wheelhorseforum.com/files/category/8-1965-1972/ Share this post Link to post Share on other sites
Ed Kennell 43,779 #15 Posted June 2 1 hour ago, UNBOUND said: So that manual would apply to my Raider 14? No, sorry I posted in the wrong thread. Share this post Link to post Share on other sites
UNBOUND 73 #16 Posted June 2 Got it done, 2 quarts and shows correct on dipstick. 2 1 Share this post Link to post Share on other sites
