wallfish 20,246 #1 Posted May 4, 2025 Not sure how much time this is going to take but the bones are already there for truck project. Obviously won't be all WH parts like every other build but oh well. Lots of time saved and still a cool project. Bought this at the Zag show yesterday. @Sparky and @Docwheelhorse were kind enough to go grab it for me since there was no room to haul it home but the seller is close by to them. Anyone familiar with that type of trans? What's this handle for? 5 4 Share this post Link to post Share on other sites
ebinmaine 79,769 #2 Posted May 4, 2025 Looks awesome! 6 minutes ago, wallfish said: Anyone familiar with that type of trans? What's this handle for? @Stepney ? Share this post Link to post Share on other sites
squonk 47,466 #3 Posted May 4, 2025 7 minutes ago, wallfish said: Anyone familiar with that type of trans? What's this handle for? Either the ejection seat or it lets out the emergency brake (boat anchor) 4 Share this post Link to post Share on other sites
ebinmaine 79,769 #4 Posted May 4, 2025 Just now, squonk said: Either the ejection seat or it lets out the emergency brake (boat anchor) I was thinking brake but ejection seat is WAY more fun. 2 Share this post Link to post Share on other sites
squonk 47,466 #5 Posted May 4, 2025 That transmission may have more ranges than Julia Child! 5 Share this post Link to post Share on other sites
wallfish 20,246 #6 Posted May 4, 2025 The handle in question is connected right into the trans. There's a regular flywheel and clutch assembly operated by a pedal but it's likely/possible the trans is older than that setup is. Could be a trans brake used for a parking brake maybe??? This stuff is out of my wheelhouse and it's not here yet to play with. Those 2 homemade levers in the pic are connected to the E brake cables for steering brakes. The rear drum brakes are plumbed to an auto style master cylinder with front and rear lines Tee'd together. The hydraulics are old and need replacement of lines, no pump, no valve. I have an old style Jeep hydraulic setup that runs off 12v starter so that might be cool. Planning to power it with an old twin cylinder Onan CCK 6v engine. Think it's 13.5 Hp but... 3 Share this post Link to post Share on other sites
Sparky-(Admin) 25,988 #7 Posted May 4, 2025 While @wallfish is sitting around in his PJ’s talking about what he “might do” I’m here gettin it done!! 1 13 1 Share this post Link to post Share on other sites
squonk 47,466 #8 Posted May 4, 2025 (edited) 21 minutes ago, Sparky said: While @wallfish is sitting around in his PJ’s talking about what he “might do” I’m here gettin it done!! Get some white paint and call it the " Popemobile! " Edited May 4, 2025 by squonk 6 Share this post Link to post Share on other sites
8ntruck 9,094 #9 Posted May 4, 2025 @wallfish think you will get this done before @ebinmaine finishes his Colossus project? 8 Share this post Link to post Share on other sites
Pullstart 70,835 #10 Posted May 4, 2025 Cool stuff! Looks fun! 1 Share this post Link to post Share on other sites
Handy Don 17,022 #11 Posted May 4, 2025 (edited) That extra handle on the “truck” is attached to a band brake on the final-drive end of the transmission. So there are: - separate levers activating the “parking brakes” on each rear wheel, - a single brake pedal activating the rear drum brakes on both rear wheels, and - that lever for the band brake. Plenty of “stop”. Need to explore the “go”. There was no diagram covering the shift pattern so it’ll be fun exploring the trans--I suspect you’ll find a 3- or 4-speed and reverse. Edited May 4, 2025 by Handy Don 3 1 Share this post Link to post Share on other sites
ebinmaine 79,769 #12 Posted May 4, 2025 7 minutes ago, 8ntruck said: @wallfish think you will get this done before @ebinmaine finishes his Colossus project? Man I hope so..... 1 Share this post Link to post Share on other sites
Ed Kennell 46,642 #13 Posted May 4, 2025 (edited) Parking brake. Edited May 4, 2025 by Ed Kennell 2 Share this post Link to post Share on other sites
oliver2-44 11,646 #14 Posted May 4, 2025 Does the transmission have a 2nd output shaft (or blank removable cover for one) which was typically used for a winch or hydraulic pump. 3 Share this post Link to post Share on other sites
wallfish 20,246 #15 Posted July 5 The trans was stuck and also had a large crack in cast pan. Probably from water in it freezing. The crack saved the gears from rusting bad since the water could just run out. Cleaned the rust off the gears and did a JB weld of the crack. It's been about a month since we (my nephew Paul has been helping me) got it running and shifting. This is a little above idle in 3rd gear so it looks like it will go pretty fast in 3rd. 3 1 Share this post Link to post Share on other sites
wallfish 20,246 #16 Posted July 5 We put tubes in all the tires, new brake master cylinder, waiting for some new 1/4" brake line but we did make a temp line out of copper tubing I had laying around to check the wheel cylinders and brake operation. So far so good and need to adjust those brakes back from removing the drums. If the brakes work then it's time for a temp seat and take it for a test drive!. Hold my beer and watch this! LOL As suspected the cab is a little too small so it even crams me in there at only 5' 7". The cab will need to be lengthened about 8" front to back and the roof raised about 4 more inches higher. I'll try and get rid of that square "Pope mobile" look since it needs modifications anyway. 3 Share this post Link to post Share on other sites
ebinmaine 79,769 #17 Posted July 5 1 hour ago, wallfish said: running and shifting Niiiiice! Share this post Link to post Share on other sites
squonk 47,466 #18 Posted July 5 (edited) 36 minutes ago, wallfish said: If the brakes work then it's time for a temp seat and take it for a test drive!. Hold my beer and watch this! LOL Guy I worked with got ahold of an old doodle bug. He got it running and stopping and decided to take it for a test run. Used an upside down bucket for a seat. Lots of hills in his area. Everything was fine until going down a hill with a curve, That bucket slid out of the cab and the only thing keeping him in the cab was the fact he had a death grip on the steering wheel. Edited July 5 by squonk 2 Share this post Link to post Share on other sites
Sparky-(Admin) 25,988 #19 Posted July 5 2 hours ago, wallfish said: As suspected the cab is a little too small so it even crams me in there at only 5' 7". The cab will need to be lengthened about 8" front to back and the roof raised about 4 more inches higher. FYI…I’m just over 6’ so don’t cheap out on the new improved cab 3 Share this post Link to post Share on other sites
wallfish 20,246 #20 Posted July 5 2 hours ago, squonk said: Guy I worked with got ahold of an old doodle bug. He got it running and stopping and decided to take it for a test run. Used an upside down bucket for a seat. Lots of hills in his area. Everything was fine until going down a hill with a curve, That bucket slid out of the cab and the only thing keeping him in the cab was the fact he had a death grip on the steering wheel. Well, that's basically the same plan here except for the hills. My death grip is fairly solid 3 Share this post Link to post Share on other sites
wallfish 20,246 #21 Posted July 5 On 5/4/2025 at 4:52 PM, oliver2-44 said: Does the transmission have a 2nd output shaft (or blank removable cover for one) which was typically used for a winch or hydraulic pump. I don't see anything and that would definitely be helpful if it was there 1 Share this post Link to post Share on other sites
wallfish 20,246 #22 Posted July 14 We got enough done on it in order to take it for a test drive. We've been pecking away at it any time we could. My nephew Paul has been helping me with this one and apparently a little underwhelmed when it took off. The right rear tire is skidding when braking so we'll need to take a look in there and make some adjustments before full throttle in 3rd gear. And that Teccy engine has got to go. 6 7 Share this post Link to post Share on other sites
Pullstart 70,835 #23 Posted July 20 On 7/14/2026 at 7:14 PM, wallfish said: apparently a little underwhelmed That’s about like the Snowmotractor. The way it screams with that 440 under the hood, 30 mph is boring. Sweet project, and good to hear Paul is still wrenching! We didn’t scare him away at the show! 1 1 Share this post Link to post Share on other sites
squonk 47,466 #24 Posted July 20 Hopefully that has a minimal amount of wiring! All it needs is some bullet proof glass! 3 Share this post Link to post Share on other sites
Blaine 250 #25 Posted July 20 (edited) You may want to install one of these. You know, safety first. Edited July 20 by Blaine 5 Share this post Link to post Share on other sites
