Mike'sHorseBarn 3,712 #1 Posted February 9, 2025 So I've had my eye out for a nice 314H to use to mow grass and use around the house, but they seem to never be for sale around me. A 520lxi came up for sale on it's intriguing me. Has a 20hp kawasaki and 400 hours. What do you all have to say about those? I'm unfamiliar with toro's that new. How is parts availability etc? I also don't really what what's a good price for one either. Share this post Link to post Share on other sites
8ntruck 9,420 #2 Posted February 9, 2025 I think @Pullstart has one of these in his heard. They are said to be beasts. Like any piece of machinery, the durability and reliability depend on how it has been used and maintained. 3 Share this post Link to post Share on other sites
kpinnc 19,107 #3 Posted February 9, 2025 Both options are tough machines. Both use basically the same hydrostatic. Simply put- the 312 is a simple, easy to work on machine. If the engine was properly maintained it will run thousands of hours and is literally bulletproof. Thousands of spare parts available for it. Every attachment made for classic machines since 1973 will fit on it. The 5xi is a bit more complex, and likely more expensive. None of the attachments from other tractors will fit, though New Holland also used the same machine painted blue. If it comes with multiple attachments, great. If not, the search for them will be more involved. 2 2 Share this post Link to post Share on other sites
Ed Kennell 47,946 #4 Posted February 9, 2025 1 hour ago, kpinnc said: None of the attachments from other tractors will fit I would hold out for a 300 series for a dedicated mower. I just don't like the twins for mowing. They burn too much fuel and throw off too much heat. Share this post Link to post Share on other sites
Handy Don 17,735 #5 Posted February 9, 2025 (edited) IMHO the 314-H is the mid-range “best versatility” model along with the 854 at the low end and the swept/reduction 520’s at the high end. Strong, good on fuel, and excellent components. 48” deck or blade--no problem. 12” Plow--no problem. Easy maintenance. Certainly there are “C’s” out there with hydros that are close but the Eaton is a fave. Edited February 9, 2025 by Handy Don 1 Share this post Link to post Share on other sites
squonk 48,427 #6 Posted February 9, 2025 If you want an Eaton look for a C-145 or 65 1 Share this post Link to post Share on other sites
kpinnc 19,107 #7 Posted February 9, 2025 (edited) 11 minutes ago, squonk said: If you want an Eaton look for a C-145 or 65 The 314-H has the Eaton 1100 and hydraulic lift. The 5xi also has the Eaton 1100, but the transaxle is 90 degrees offset and shaft driven. Edited February 9, 2025 by kpinnc Share this post Link to post Share on other sites
Pullstart 71,561 #8 Posted February 10, 2025 Mike did you run my Xi at the plow day? I’m always impressed! It has a truck like frame and is all around hugely beefy! 2 Share this post Link to post Share on other sites
RED-Z06 2,720 #9 Posted February 10, 2025 6 hours ago, Mike'sHorseBarn said: So I've had my eye out for a nice 314H to use to mow grass and use around the house, but they seem to never be for sale around me. A 520lxi came up for sale on it's intriguing me. Has a 20hp kawasaki and 400 hours. What do you all have to say about those? I'm unfamiliar with toro's that new. How is parts availability etc? I also don't really what what's a good price for one either. 520xi should have had a Kohler unless its an LXi which has the water cooled kawasaki. 1 Share this post Link to post Share on other sites
JoeM 10,318 #10 Posted February 10, 2025 I have had both and both are nice. If you are looking for comfort, the Lxi is the machine. Power steering, very stable on slopes, high low range transmission, and a awesome foot control for the hydro. As far as fuel economy, that liquid cooled Kawasaki engine is a sipper, and there is a lot less operator heat. Parts are out there and just as available as the other WH stuff. A 60 inch deck is available and they cut nice. The 48 uses the same shell and spindle parts as the 3,4 and 500 series, The deck hanging hardware is different. Snow plow is longer, 2 1/2" longer than the 520 with an extension, can be modified to fit if necessary. Tillers will work but use a different belt arrangement and mule drive. 400 hours is not that much if someone changed the oil. The LXI I have on my FEL has 1700 hours. Runs okay but is a little tired. I would expect to see a low hour machine between 1-2K. I still have a 14HP hydro machine and every now and then I get nostalgic and run it.......but that wears out quick and I am back on the bigger machine. The 522xi has the mower deck now. I suppose the older I get, the more I lean toward comfort. 7 Share this post Link to post Share on other sites
WHX?? 58,388 #11 Posted February 10, 2025 I think Tom has a couple too. @Shynon They pop up around here abit but just never had the hair for one. Most are pretty beat up and attachments rough and since they are specific. They were considered pricey in the day ... the ultimate estate mower and none others had much to match. 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,712 #12 Posted February 10, 2025 Thanks for all the replies, the one I'm looking at is listed for $1,600 and in the video it's running good and seems in decent shape. I have my eye on a c-165 hydro as well, but I can't tell if it has the eaton or sundstrand. I know the 1980 models still had the sundstrand. 15 hours ago, Pullstart said: Mike did you run my Xi at the plow day? I’m always impressed! It has a truck like frame and is all around hugely beefy! I didn't get to run yours that day. Does yours have the Kawasaki or the kohler? Share this post Link to post Share on other sites
Pullstart 71,561 #13 Posted February 10, 2025 13 minutes ago, Mike'sHorseBarn said: I didn't get to run yours that day. Does yours have the Kawasaki or the kohler? Mine’s the 20 hp Kohler. It will run most all day with one tank of fuel. It’s a HUGE tank (with a gauge)! @JoeM might be able to confirm, but I bet it’s a full 5 gallons or more. Share this post Link to post Share on other sites
RED-Z06 2,720 #14 Posted February 10, 2025 54 minutes ago, Pullstart said: Mine’s the 20 hp Kohler. It will run most all day with one tank of fuel. It’s a HUGE tank (with a gauge)! @JoeM might be able to confirm, but I bet it’s a full 5 gallons or more. Should be 4.25gal 1 Share this post Link to post Share on other sites
WHX?? 58,388 #15 Posted February 10, 2025 1 hour ago, Pullstart said: run most all day with one tank of fuel and no oil pressure ... There fixed that ... when he left it here for plow day I hopped on it to move it and the oil light wouldn't go off. Oil checked ok so just ran it like i stole it figurin it just Pullstart's anyway... 1 Share this post Link to post Share on other sites
Pullstart 71,561 #16 Posted February 10, 2025 43 minutes ago, WHX?? said: There fixed that ... when he left it here for plow day I hopped on it to move it and the oil light wouldn't go off. Oil checked ok so just ran it like i stole it figurin it just Pullstart's anyway... yup, I’ve never worried about it on that machine. It hasn’t died yet, it shouldn’t now. Share this post Link to post Share on other sites
Pullstart 71,561 #17 Posted February 10, 2025 1 hour ago, RED-Z06 said: Should be 4.25gal That’s why I don’t use my wife’s money to bet Share this post Link to post Share on other sites
JoeM 10,318 #18 Posted February 10, 2025 (edited) yep 4.25 but the manual says to leave a little room in the tank. Another thing I weighed mine with out the deck and it was just short of 1000 by 25 lbs One nicety is the transmission has a neutral and makes it easy to tow! Oil checked ok so just ran it like i stole it figurin it just Pullstart's anyway... Edited February 10, 2025 by JoeM 2 Share this post Link to post Share on other sites
RED-Z06 2,720 #19 Posted February 10, 2025 1 hour ago, JoeM said: yep 4.25 but the manual says to leave a little room in the tank. Another thing I weighed mine with out the deck and it was just short of 1000 by 25 lbs One nicety is the transmission has a neutral and makes it easy to tow! Oil checked ok so just ran it like i stole it figurin it just Pullstart's anyway... Those tire sizes are kinda disappointing for this market of tractor, id have liked to see an 18x8.50-8 up front and at least a 24x12x12 in back, really makes a tractor sit up Share this post Link to post Share on other sites
Pullstart 71,561 #20 Posted February 10, 2025 54 minutes ago, RED-Z06 said: Those tire sizes are kinda disappointing for this market of tractor, id have liked to see an 18x8.50-8 up front and at least a 24x12x12 in back, really makes a tractor sit up Share this post Link to post Share on other sites
RED-Z06 2,720 #21 Posted February 10, 2025 1 hour ago, Pullstart said: Mmm like a glove Share this post Link to post Share on other sites
Cee245 881 #22 Posted February 12, 2025 @Mike'sHorseBarn, My brothers and I have a camp where one mowers is a 520xi with the kohler we've owned for aboot 10 yrs.... Has about 5XX hrs on it and its a very nice heavy duty, capable machine. We only use for mowing, but it's been reliable. (Had a tiller in past). The 48" deck cuts very nice. My Dad has 2 520xi's and both hadve been very good to him as well. I haven't owned or used a 520Lxi with the kawi, power steering though. In my area, Northwestern, PA, the XI's are generally are priced close to double what a comparable 314H is. The Xi's are nice, but harder to find implements. In my area, ~750 for a good 314H, maybe with a couple implements. And ~1200-2000 for a comparable Xi package. Of course, some steals come up if you're looking close enough Share this post Link to post Share on other sites
