elcamino/wheelhorse 9,360 #1 Posted November 3, 2024 I am replacing the spindles on a 1972 36-inch RD deck. Does anyone know what the torque specs for the bolts that mount the spindle housing to the deck. I can find specs on the bolts for blades and bolt for the pulleys , but not for the mounting bolts. Anyone want to suggest a SWAG (scientific Wild A** guess) for the torque spec. I did find out that the carriage bolts that WH used are not standard. The square portion of the WH bolts are the same thickness of the deck. Any help from the head lug nut (you know who you are) would be appreciated. thanks Waldo Share this post Link to post Share on other sites
WHX?? 50,816 #3 Posted November 3, 2024 Jimbo... specs can't be found just use the spec for that style of fastener. 2 Share this post Link to post Share on other sites
Ed Kennell 40,637 #4 Posted November 3, 2024 Trusting my memory a bit Jim, but I think those bolts are 7/16-14 grade 5. If so, the lubricated torque is 35 ft lbs. 1 Share this post Link to post Share on other sites
PWL216 980 #5 Posted November 3, 2024 @elcamino/wheelhorse Do you know what the part number is for the deck? I have this spindle identification poster that shows the detail of the decks, including torque spec. If you have a part number, I can find it for you. I’ve attached a couple of pictures as an example from the poster. 1 Share this post Link to post Share on other sites
stevasaurus 23,102 #7 Posted November 3, 2024 How many tries does it take to start a Left Handed bolt in a Right Handed hole?? Only the Head Lug Nut knows. 6 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,360 #8 Posted November 3, 2024 @Ed Kennell Thanks for the chart, the bolts are 3/8 - 16 x 1 carriage style bolt and The square part of the bolt depth is the same thickness as the metal of the deck. @PWL216 I'll get back you , if I can find the part number , The deck number is a 05-620. Share this post Link to post Share on other sites
Ed Kennell 40,637 #9 Posted November 3, 2024 16 minutes ago, elcamino/wheelhorse said: the bolts are 3/8 - 16 x OK, 23 ft lb should work. 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,360 #10 Posted November 3, 2024 @PWL216 here are the part numbers for the bolts 900234-4 , the nuts are number 915113-6 . The spindle is a number 100675 which was replace by 101525. The 101525 came with threaded holes and non threaded holes for mounting to the deck. Share this post Link to post Share on other sites
elcamino/wheelhorse 9,360 #11 Posted November 3, 2024 Now if some one could provide the replacement part number for a squonk , the current model is wearing the forum out. 2 1 Share this post Link to post Share on other sites
stevasaurus 23,102 #12 Posted November 3, 2024 Here is the part number...# ou-812 !! I could not survive without my best friend in the hills of NY. If you go to any auto parts store and ask them about # ou-812, they will tell you they cannot replace it and they are NLA. You might find one on the shelf of an old True-Value or that oher Auto Store that escapes my mind at the moment. Didn't this guy tour with the Carpenters?? 1 Share this post Link to post Share on other sites
squonk 42,721 #13 Posted November 4, 2024 19 hours ago, elcamino/wheelhorse said: Now if some one could provide the replacement part number for a squonk , the current model is wearing the forum out. Speaking of wearing out. Have you finally run out of mirrors in your house? 4 Share this post Link to post Share on other sites
Pullstart 64,776 #14 Posted November 4, 2024 Nobody suggested to crank it til it snaps and back off a 1/4 turn? 1 3 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,360 #15 Posted November 4, 2024 I did not attend the flip flop school of working like you and the head lug nut. 1 Share this post Link to post Share on other sites
