Redtickuleez
My New d180/wife upsetter
Redtickuleez
Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
Pullstart
Congrats!  A D series loader hoe is a very capable machine!
  • Excellent 7
ebinmaine
I'm not familiar with the D Series but the C Series did have a "Wheelhorse Dealer offered" Front End Loader for years.
Backhoe,  I don't know.
Be VERY careful with using any paint removal chemicals on that. Check closely to see if that plate has embossed letters/ numbers under the paint.
@Pullstart  Is that where the only ID is?
953 nut
:WRS:
The "D" could have been equipped with the loader and backhoe from the dealer. They would have been "Allied Attachments" offered by Wheel Horse dealers but not built by Wheel Horse.
The model number tag that has been painted over can be cleaned up with a careful application of oven cleaner or lacquer thinner on an old tooth brush. Use gloves and eye protection and be surer you don't get it on painted surfaces you wish to protect.
Edited by 953 nut
WHX??
Pics Red??
I use regular paint thinner. Just be careful.
oliver2-44
Must be quite a Horse!
:wwp:
Achto
Some brake cleaner on a rag & a little scrubbing might remove enough paint to see the serial number.
1321123318_wifetractor.jpg.a762d8f562f3a226043c17dfedf339c5.jpg     :thumbs2:
  • Haha 5
  • Heart 2
ri702bill
OR - brake fluid. Bubbles the paint right up...
Redtickuleez
Thanks gentlemen.... now  why is reverse barley working? Sometimes it wont go in reverse at all. When it does its slower that the kid wearing a backwards bicycle helmet on the short bus.... please dont take that personal any helmet wearers out there around the Redsquare... lol
Edited by Redtickuleez
  • Haha 3
953 nut
Sundstrand transmissions have ACCELERATION VALVES AND SPRINGS that have to be replaced from time to time.
oliver2-44
Start with cleaning the linkage and adjusting/replacing any worn/sloppy components.  Some of it needs to be lubes, some needs to stay dry.  The hydro pump and motor fins should also be cleaned to insure good cooling.
Also checkout the acceleration valves and springs as 953nut mentioned.
Probable just some maintenance in both areas is due.
Achto
There is an acentric screw on the linkage on the left hand side behind the battery. If this is loose or worn out it will effect reverse. You will probably need to remove the battery to get to it.
gwest_ca
D-series service info in this manual.
When we see the model and serial number we can find more.
wh500special
The serial number isn’t particularly useful on these tractors.  The model number is.   The D-180 was made in two model years, 1974 and 1975, and was assigned the model numbers 1-0611 and 1-0612 respectively.  In the case of the D-180, the two models are essentially identical so you can probably use either one when looking up parts.
Since you have a front loader you should make sure your front spindles have been upsized to 1” diameter.   Originally these were 3/4” and were prone to breaking even without a loader attached.
The loader is fairly common, the backhoe is quite scarce.  The loader was made by Ark, I don’t remember if the back hoe was by Ark or Brantly.   Regardless, you have a desirable and somewhat rare piece of machinery.
The main point of my reply is to tell you that your short bus comment is inappropriate and unappreciated.  I have thick enough skin, but I do take this personally.
Grow up and cut the crap.
Enjoy the tractor.
Steve
  • Similar Content
    • JoeM
      By JoeM
      Good Toro XI Lift Valve and Cylinder Assy.
      Hurry this deal won't last! $60 Plus shipping.
    • rustyedge1
      By rustyedge1
      Need a condenser for engine shown in photos 8 hp Kohler. Any venders carry them on this site ?
      All help appreciated..Have PayPal or can send check..
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • Aaron Coffman
      By Aaron Coffman
      Hi Red Square Community,
      I am looking into purchasing the below pictured "POND" Walk Away. The unit itself has the cast in “POND” on the chain reduction housing. The two main things I am looking to learn are what value is typical for these to sell for. This one has a Briggs & Stratton model “N” engine. It runs and drives, but the throttle linkage needs some adjusting. It comes with a cultivator and plow implement.
      Secondly, I was wondering if there is any way to determine what year specifically this Pond is from. The seller believes late 1940s and not 1950s. I am new to these machines, so I am looking for some guidance. Thank you in advance!
