elcamino/wheelhorse 9,363 #1 Posted September 10, 2024 Does anyone know where I can buy 7"deck wheels for my 42 inch rd deck ? I can find 6 " and 8" ,but not 7". 1 Share this post Link to post Share on other sites
rjg854 13,370 #2 Posted September 10, 2024 Did you try Tractor Supply? Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #4 Posted September 10, 2024 I have looked at Northern , big box store HF , with no luck . I'll try Tractor supply. Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #5 Posted September 10, 2024 @rjg854 Randy thanks for the suggestion TS sells Martin wheel 7" all I have to do is check the bore size and off set if any. Wonder where the LUGNUT is whose knows everything ? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #6 Posted September 11, 2024 Suspect this is the wheel you want to replace. The dimensions are listed https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=359 1 Share this post Link to post Share on other sites
squonk 48,137 #7 Posted September 11, 2024 Buy an 8" wheel and turn it into a 7" with a hammer and chisel! 2 Share this post Link to post Share on other sites
Brockport Bill 2,478 #8 Posted September 11, 2024 5 hours ago, gwest_ca said: Suspect this is the wheel you want to replace. The dimensions are listed https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=359 this web site says they are canadian located - which makes me wonder if their price listing is US dollars or Canadian - big difference?????????????? Wheel Horse Parts and More sells those wheels but i do not see a size indicated Share this post Link to post Share on other sites
Brockport Bill 2,478 #9 Posted September 11, 2024 7 hours ago, elcamino/wheelhorse said: I have looked at Northern , big box store HF , with no luck . I'll try Tractor supply. Wheel Horse Parts and More ships Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #10 Posted September 11, 2024 13 hours ago, squonk said: Buy an 8" wheel and turn it into a 7" with a hammer and chisel! And the lug nut has spoken Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #11 Posted September 11, 2024 14 hours ago, gwest_ca said: Suspect this is the wheel you want to replace. The dimensions are listed https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=359 That is for a 6 inch , Wpm is also for a 6inch. Share this post Link to post Share on other sites
pfrederi 21,166 #12 Posted September 11, 2024 at $8 per wheel replace them every couple years... 1 Share this post Link to post Share on other sites
Handy Don 17,484 #13 Posted September 11, 2024 Be aware of the plastic hub with no bushing in the bore. These are intended for push mowers and will NOT stand a lot of side force (as might be seen by a deck during a sharp turn or when being mounted/unmounted). Still, at the price replacing every few years, per @pfrederi is probably a deal! 1 hour ago, pfrederi said: 1 Share this post Link to post Share on other sites
peter lena 10,073 #14 Posted September 12, 2024 @elcamino/wheelhorse 7" wheels are ideal for a deck , the issue is the construction of the wheel , typically chinese junk , with push in bearings , and weak wheel design . would look look for a wheel in smaller version for a zero turn mower set up , have personally hunted around for solid wheels , don't expect to fine exactly what you want , it will be for something else , has to be able to handle side loading , at bearing mount point , would also favor a smooth tread point , so wheel can slide , and not side grip , that pulls wheel apart . my initial trials were good , but as I went on , the wheel to bearing point just fell apart , might make an axel from threaded rod , so you could elastic lock nut the bearing hold in place . starts to get , repetitive with issues , pete 1 Share this post Link to post Share on other sites
953 nut 69,409 #15 Posted September 13, 2024 I picked up a pair of deck wheels from A-Z at the show along with new shoulder bolts. Cost more than the plastic wheels but should last much longer. https://www.a-ztractor.com/advanced_search_result.php?keywords=deck+wheels Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #16 Posted September 13, 2024 I found 7 inch wheels at TS , not stocked in the stores . Made by Martin Wheel ,there are steel with a 55 lb capacity. Should arrive on the 18th . I'll let everyone know how they fit etc. after I get them mounted. 1 1 Share this post Link to post Share on other sites
