953 nut 68,796 #1 Posted July 12, 2024 I am setting up the hardware department of my church's Bazaar, annual big yard sale. Got a couple of things that I can't ID, perhaps some of you will know. First one has a heavy duty hook on one end and has a place to hammer on to pull on something? The second mystery is a pair of tools (left hand and fright hand) that are offset with a curve like they will be used to go around a pipe or log? I have no idea what they are for and the church probably won't get any more for them if I know what they are, but it would be nice to know. 1 Share this post Link to post Share on other sites
rmaynard 17,549 #2 Posted July 12, 2024 The first tool The second item appears to be mortar pointing tools. 1 Share this post Link to post Share on other sites
Handy Don 17,380 #3 Posted July 12, 2024 Possibly tire irons? 1 1 Share this post Link to post Share on other sites
sqrlgtr 3,799 #4 Posted July 12, 2024 First one is easy its a whatchamacallit agree the 2nd one is mortar joist tool. 1 Share this post Link to post Share on other sites
Pullstart 71,160 #5 Posted July 12, 2024 Bearing puller? 1 Share this post Link to post Share on other sites
midpack 1,148 #6 Posted July 12, 2024 Not sure what it actually does, but I'd give the first one a shot at being a tire bead breaker. Share this post Link to post Share on other sites
rjg854 13,330 #7 Posted July 12, 2024 I'm guessing of course, the first one of being a slate shingle hook. Used for replacing broken tiles. 1 Share this post Link to post Share on other sites
953 nut 68,796 #8 Posted July 12, 2024 1 hour ago, rjg854 said: slate shingle hook best guess I've heard yet. Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #9 Posted July 12, 2024 I thought the first one was @squonk toe nail cleaner. 3 Share this post Link to post Share on other sites
squonk 47,990 #10 Posted July 12, 2024 3 minutes ago, elcamino/wheelhorse said: I thought the first one was @squonk toe nail cleaner. I thought it was your tooth pick. 2 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #11 Posted July 12, 2024 Looks the hanger for my suspensers or my under wear. 1 Share this post Link to post Share on other sites
87 416-8 horse 430 #12 Posted July 14, 2024 I’m kinda with @midpack on the first one. Use the straight end to break a bead on a small tire then maybe use the hook to pull it over the rim. That’s what came to mind Share this post Link to post Share on other sites
Mickwhitt 5,259 #13 Posted July 14, 2024 To me, it only looks small and light weight. The thing looks like you hold it by the handle and hammer down on the worn pad to exert a downward force on the hooked end. Just a total guess but based on the way it looks to function, is it a tool for closing barrel lids? Hook it Over the barrel side, tap the anvil and pull the lid down? Share this post Link to post Share on other sites
Rick3478 465 #14 Posted July 14, 2024 3 hours ago, Mickwhitt said: To me, it only looks small and light weight. The thing looks like you hold it by the handle and hammer down on the worn pad to exert a downward force on the hooked end. Just a total guess but based on the way it looks to function, is it a tool for closing barrel lids? Hook it Over the barrel side, tap the anvil and pull the lid down? Like your thinking, but wonder about the function of the extra tang. Doesn't look like a good place for fingers if you're going to hammer on it. Share this post Link to post Share on other sites
Mickwhitt 5,259 #15 Posted July 14, 2024 36 minutes ago, Rick3478 said: Like your thinking, but wonder about the function of the extra tang. Doesn't look like a good place for fingers if you're going to hammer on it. Yeah that was my concern. Maybe something where the hand holding the tool is not against a surface. Nothing like it in car body work or sheet metal work? Share this post Link to post Share on other sites
