siebenaler 114 #1 Posted May 18, 2024 My steering seams to be skipping when I turn it hard all the way to the left. nothing Seams to be broken . I'm wondering if there is anything that could be tightened Up there is some up and down play in the steering shaft . Share this post Link to post Share on other sites
ri702bill 9,392 #2 Posted May 18, 2024 Look for a sheared roll pin at the lower steering (if not welded) and the fan gear on the lower shaft. A fairly common problem.... 2 Share this post Link to post Share on other sites
Pullstart 66,689 #3 Posted May 18, 2024 The shaft with the fan gear that rides under the engine can be shimmed closer to the steering shaft. That should help tighten it up. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,471 #4 Posted May 18, 2024 Illustration of parts list may help https://www.partstree.com/models/1-0422-toro-bronco-14-lawn-tractor-1972/front-axle-and-steering-5/ Share this post Link to post Share on other sites
squonk 43,774 #5 Posted May 18, 2024 Steering block wallowed out. #5-25 in the diagram. Share this post Link to post Share on other sites
daveoman1966 3,839 #6 Posted May 18, 2024 Common issue. Get under the tractor and shim the lower steering rod like this: For the up/down of the steering column, (1) open the hood (2) loosen the 3/4" ID collar on the column and (3) move it up to be tight against the dash housing. Put some grease in there too. 3 Share this post Link to post Share on other sites
peter lena 9,251 #7 Posted May 18, 2024 @daveoman1966 are you suggesting , grease and shims ? just horsing around . thats like ground zero for me . love to IMPROVE ON INTENDED , FUNCTION . good basic call , pete 2 Share this post Link to post Share on other sites
peter lena 9,251 #8 Posted May 18, 2024 @Pullstart you know that ! the repetitive failure of a set up is your track for eliminating it , and its more often than not , the detail in its functional set up ! regularly washer / shim up a connection point , enhance lubrication . usually at that point , i,m in the WHAT IF STAGE . between you and @daveoman1966 , you might be on to something , grease slick , pete 1 Share this post Link to post Share on other sites
siebenaler 114 #9 Posted May 18, 2024 Got it thanks and especially grease slick Pete. 1 Share this post Link to post Share on other sites
