Southern_Secret
IT'S a D-180 & IT'S all MINE!!
OutdoorEnvy
Wow great score!  Front loader and a 3pt!  That will be a handy rig for sure!
  • Excellent 2
Wayne0
I'll betcha' stole it too!
ol550
For a few of us a D series is like a boat.  Excited the day you get it and even happier to see it going down the driveway. :happy-bouncyredfire:
  • Haha 4
Southern_Secret
Well as of now there as been no cotton paper change hands..............and being as he said "if the scrap yard would have been open today it would have went there" the day he dropped it off, im not suspecting there will be but I could be wrong.
JoeM
Looks like some wicked stacks too!
they are a heavy machine and will do work.
Do keep an eye on the pump to engine coupler as they are prone to fail. Always throttle down be fore turning off the engine also. my neighbor snapped mine off and zinged the coupler spline.
Southern_Secret
The more digging I do on here the more nerves I get about it :confusion-helpsos:
ebinmaine
:text-welcomewave:. Back!!
Southern_Secret
@JoeM The pump coupler is looking good from what I can tell.
Southern_Secret
I know the list will probably get longer, but thus far these are the issues im working threw
Im sure some D-series fanatics will find the thread  (I hope)
#1- The dadgum gas tank is rust welded to the fender pan
#2- The steering wabbles so much it got pulled over for DUI :laughing-rofl:
#3- Im pretty sure the FEL pump is pushed against the frame around the grill
#4- One of the axel seal is leaking
the rest is un-none at the time.
ebinmaine
There's a checklist in this following thread. Might help you sort through things. Not specific to any particular model so there's going to be some unneeded information in there.
JoeM
The three point was nice for hooking up a weight box.
I believe the steering box has an adjustment maybe someone here might be able to help with that issue.
And to be honest. I took the loader off and put it on a 520H because of consistent issues with the D. Coupler issues, Hydro piping leaks, and very, very hard to steer with a load. The 520 reduction steering was a big improvement.
If I was only using it once in a while I would have kept it, but I used it all the time and the steering was a deal breaker.
I actually moved my gas tank back some cause I eat well. It has been a while and can't remember how tho.
My loader was homemade and the pump mounted underneath and utilized the mule drive for the mower deck to route the belt.
Southern_Secret
@JoeM I do understand more clearly than I'd like :laughing-rofl: that the D's come with there baggage. Only other tractors I have is a 314h, ym1300, and 2605 massy & I dare not put the FEL on my 314h.
Im not sure how the tank got rusted to the fender pan. I got all the nuts off no problem, but one corner of the tank is "stuck" to the fender pan :ranting:
JoeM
better then JB Weld!
  • Haha 1
Achto
D's are not all that bad, to me they are a little more like working on a Cub Cadet.
Southern_Secret
Question, does anyone know the Wheel Horse Part# for a carb kit? I found a # in my small engine book Part# 2575701s, but I want to be sure it is right before ordering it. TIA
Southern_Secret
Another Question I have is, with the tractor not running (cause iv not got it running yet lol) I can push the motion control lever forward & almost back to the Neutral position and it stops moving...is this normal??
ebinmaine
That's the correct number for a single cylinder Kohler carb. If it's a twin, 2575702
Southern_Secret
Thanks @ebinmaine you always got the slack out the trigger ready to go :handgestures-thumbupright:, it is indeed a twin cylinder & I thought that part# looked wrong so I asked.
Southern_Secret
@ebinmaine I cant make that Part# work, this is what there showing in my book. They might have superseded it im not sure
ebinmaine
That looks like the newer style twin. Command?
Try 2575702S
I failed to put the S on the first time
Southern_Secret
@ebinmaine The one I was referring to is the 2nd from the top of page.
So I got the 2575702s to cross finally and this is what it crossed to in my napa system. I might have to go threw Kohler to get it
ebinmaine
You can get them online for about $20, $25. Original Kohler. Here's an eBay listing number you can search if you like.
165926250876
Southern_Secret
Thank you @ebinmaine, im trying to get this beast running & make sure there is no huge problems with it before dump time and $ in it.
How common was the Johnnson loaders on them? I see most all with the ARK & it seems top be built better and the controls are on the left, as mine is on the right & I see this being an issue when operating FEL while driving.
ebinmaine
I'm not sure on production numbers or years made...
As far as the controls go, I'll say this. I run different machines at home and at work.
There are ups & downs to having controls on either side.
Whatever way it's set up you'd get used to it and eventually the operation becomes about muscle memory.
  • Similar Content
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
