953 nut 68,442 #26 Posted April 24, 2024 On 4/23/2024 at 7:10 PM, 953 nut said: for heavy items that are on the dirt I would suggest getting some plywood that they can be pushed onto and attach some ropes to one end to pull them out of the way. 3 minutes ago, SylvanLakeWH said: cheaper alternative.. I'm about as thrifty as they come but with the price of building materials your "Slide-A-Boggan" might be cheaper. 1 Share this post Link to post Share on other sites
c-series don 12,361 #27 Posted April 25, 2024 12 hours ago, ebinmaine said: I was thinking maybe @c-series don Don should just put in a four post lift in the garage... I actually have thought about a lift in my garage, I have a 12’ ceiling so I have the height but honestly for the amount that I would use it I think it would be in the way more than anything? 2 Share this post Link to post Share on other sites
peter lena 10,011 #28 Posted April 25, 2024 @Ed Kennell @PWL216 @SylvanLakeWH , OTHERS , wow thinking out side the box ! has to be an answer here , have also used the , slide a boggan for snow blower chute , sliding base , material ,makes it swing with ease . watch out for the dreaded " you can't do that " , usually related to correcting an existing problem . pete 1 1 Share this post Link to post Share on other sites
Lee1977 7,750 #29 Posted May 1, 2024 I managed to shift enough stuff around that I could back all the way to the back of the basement to get the 42 deck out, 1 2 Share this post Link to post Share on other sites
Bob Lister 142 #30 Posted May 5, 2024 I have the small mower deck so can muscle and roll it into place. for my snow blower i drive the front wheels up on a couple 2x4 to get it up higher and slide a pallet under it. Reverse to install I don't move it off the tractor 1 Share this post Link to post Share on other sites
victorb 46 #31 Posted July 4, 2024 Just to give update (most of this happened several weeks ago) ... 1) I managed to get the snow blower attachment onto a pallet and slide it out of the way. 2) I tried to use slide toboggan but it kept pulling out from bottom (like the table cloth trick) 3) I was able to get the mower deck onto big hand truck to move it next to a flat spot near the tractor on driveway 4) ended up just man handling the deck under the tractor I was very busy the last few weeks but was able to use the tractor today to mow before getting ready now to go to ball game and fireworks with family. Thank you all. BTW, happy 4th of July 2 Share this post Link to post Share on other sites
SylvanLakeWH 32,107 #32 Posted July 4, 2024 Just used this set up. Worked like a charm... 3 Share this post Link to post Share on other sites
peter lena 10,011 #33 Posted July 12, 2024 @ SLYVANLAKE WH that slide a boggan , makes for a great snowblower chute , base slide gasket , add silicone spray , smooth / easy , pete 1 Share this post Link to post Share on other sites
peter lena 10,011 #34 Posted July 13, 2024 @ SLYVANLAKE , btw just that small FUNCTIONAL DETAILING , of a wheel horse anything , is the basis to a lot of my improvements , terrifies purests , you can't do that , really ? those snow blower idler and drive pulleys , and the rusty dragging steel frame they are on , can be greatly improved in rotational function . no screaming PTO drive clutch , also added , cleaned out / re greased bearings , and chute cable rotation / connection . roller stool sit / watch how things work , pete Share this post Link to post Share on other sites
cleat 9,206 #35 Posted July 13, 2024 I use this. I built an adapter to put forks on instead of the bucket. I then built a rack. Now I can move and store 3 decks at once. Shown in picture are 3 SD decks, 42",48", and 60". Tractor cost a bit of money but has paid for itself many times over with work performed and in possible injuries avoided due to exertion. You simply don't need to lift a heavy load when you have a loader to do it for you. 4 7 Share this post Link to post Share on other sites
victorb 46 #36 Posted October 6, 2024 BTW, I took the 60" deck off today. Maybe a tad easier now that I have better idea of what I am doing but my back is still killing me now. I did get the deck up onto a pallet that I can stand vertical when using a hand truck too move around. If I can find a pallet jack (for reasonable price) that can go through dirt and grass then that would be perfect. 1 Share this post Link to post Share on other sites
peter lena 10,011 #37 Posted October 6, 2024 @victorb days of moving / lifting anything are long gone , regularly use heavy cargo lift straps , with lift shackle's hooked to tractor , movable slide point , low range , 2 nd gear makes it very easy , have screw in eye hooks at go to points . lots of opportunities to make a go to leverage pull / lift point . pete Share this post Link to post Share on other sites
TractorEd 675 #38 Posted October 6, 2024 (edited) imagine it’s red Edited October 6, 2024 by TractorEd 1 Share this post Link to post Share on other sites
kpinnc 18,875 #39 Posted October 6, 2024 (edited) 6 hours ago, TractorEd said: imagine it’s red Ah yeah, nope. The way I see it, anything bigger than a garden tractor can be whatever color you like since Wheel Horse didn’t make anything like that! Edited October 6, 2024 by kpinnc 2 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,040 #40 Posted October 6, 2024 On 4/24/2024 at 7:23 PM, SylvanLakeWH said: Perhaps a cheaper alternative... I used one of these to skid the yard art... For a second there I thought that was a stick of dynamite…I know what it is now though. 😁 3 Share this post Link to post Share on other sites
Ed Kennell 46,966 #41 Posted October 6, 2024 Here's my deck storage dolly. A 3X3 ft skid with a swivel casters. I put 3-4 decks on with an electric hoist. 2 2 Share this post Link to post Share on other sites
Lane Ranger 12,091 #42 Posted October 7, 2024 This is how we moved massive , heavy items! dad made this 3 x 7 or bigger sheet metal skid with a chain and ring attachment welded to the front to attach over a ball on the rear of our 1054s. (Or other tractors). The torque and power of a wheel horse could pull this thing with no problem! Dad made three of these drawbar hitches that attached to the backside of the 1054/953 tractor rear hitches . It did not interfere with the rear slot hitch either 1 2 1 Share this post Link to post Share on other sites
BBQVultureWings 160 #43 Posted October 10, 2024 On 4/24/2024 at 6:38 AM, squonk said: How about leaving it on and building a trolley with a winch or a chain hoist and lifting the front of the tractor up to clean underneath and service the blades? Unistrut. This is a Link to the "B-Line" Catalog in PDF Format which is the most thorough Catalog I have Ever seen for the Extremely Wide variety of Unistrut Channel, Brackets, Trolley Rollers That hold 600lbs, Fasteners,clamps & tons of other different hardware. The only limit is a lack of imagination ... the possibilities are Endless. https://www.eaton.com/content/dam/eaton/products/support-systems/strut-systems-&-accessories/strut-system-catalog-2018.pdf You're Welcome 1 Share this post Link to post Share on other sites
