adsm08 5,247 #51 Posted April 25, 2024 On 4/16/2024 at 10:57 PM, 87 416-8 horse said: I found it why the engine was stuck in the parts truck. When I got it I thought it had 143k miles judging by the body but I think it’s 43k because it still has the cross haching and no ring ridge! You can't go just by that on those old cast iron Fords. I pulled apart my first 2.9 with a known 215K miles on it. Cross-hatch visible, no ring ridge, and the part numbers on the main bearings were still readable. My dad bought that truck used when it was 1 year old with about 10K on it, between me and him we put the other 205K on it and it was never out of our possession. 2 Share this post Link to post Share on other sites
87 416-8 horse 430 #52 Posted April 30, 2024 Pulled the engine out with the excavator and the rear axel. Now it’s time to slice and dice the frame with the torch. 1 Share this post Link to post Share on other sites
87 416-8 horse 430 #53 Posted April 30, 2024 (edited) Edited April 30, 2024 by 87 416-8 horse 1 Share this post Link to post Share on other sites
ebinmaine 81,282 #54 Posted April 30, 2024 Now THAT is an engine hoist!! 1 Share this post Link to post Share on other sites
87 416-8 horse 430 #55 Posted May 1, 2024 The parts truck is now a pile of truck parts and scrap. Everything in front of the fuel tanks are parts. 1 Share this post Link to post Share on other sites
ebinmaine 81,282 #56 Posted May 1, 2024 Nice quick work! 1 Share this post Link to post Share on other sites
adsm08 5,247 #57 Posted August 12, 2024 On 4/30/2024 at 11:09 PM, 87 416-8 horse said: What's the not-yellow car? 1 Share this post Link to post Share on other sites
87 416-8 horse 430 #58 Posted August 13, 2024 4 hours ago, adsm08 said: What's the not-yellow car? It’s a 1971 Oldsmobile cutlass supreme. We have to do some frontend work and rebuild the transmission. 1 Share this post Link to post Share on other sites
adsm08 5,247 #59 Posted August 13, 2024 19 hours ago, 87 416-8 horse said: It’s a 1971 Oldsmobile cutlass supreme. We have to do some frontend work and rebuild the transmission. I was close. My dad has a 72 Pontiac Ventura and I was thinking the lines that I can see looked similar. 1 Share this post Link to post Share on other sites
87 416-8 horse 430 #60 Posted September 12, 2024 The project has begun! A couple weeks ago I took the head from the parts truck engine to be ported out. It turns out it was cracked. Last night we pulled the cab and stripped the engine down. I’m going to have it bored out and the head ported out to let it breathe. Next I'm going to strip the frame down and repaint it with frame paint and primer. 1 1 Share this post Link to post Share on other sites
87 416-8 horse 430 #61 Posted October 19, 2025 Well I guess it’s been a little over a year since the last update… I’m still working on the truck around work and school and I’ve made some progress. The chassis is pretty much complete besides running wires and tightening a few things up. The project has snowballed a lot more than I anticipated, went from just cleaning the frame up to completely stripping it down and having every single piece of hardware zinc plated. Also went ahead and installed some traction bars to keep the axle under the truck with the power. I don’t know of if I mentioned before that I installed a 4” lift as well. I haven’t really touched the body yet but that’s coming up soon. The engine is back from the machine shop and ready for assembly once I get all the parts gathered up. I had an aggressive port job done on the head, bored the block .050” over to run flat top pistons from a 390fe v8, and decked the head .010”. I have a 268 comp cam I’m going to slip in then going to run a 4brrl Holley sniper and add some boost with a turbo. My goal is to be somewhere around 500hp. I have a lot of other plans but those come later. 4 2 Share this post Link to post Share on other sites
MainelyWheelhorse 3,208 #62 Posted October 19, 2025 On 4/5/2024 at 4:55 PM, ebinmaine said: I have my 4th F Series 300 now. If I recall correctly mine were: 1992 F150 2wd. 5 speed. Maroon. Step side 6 ft bed. 1993 F150 2wd. HD rear suspension. Medium blue. 8 ft fleetside bed. 5 speed. 1996 F150 2wd. Automatic. White. 8 ft fleetside bed. My current one is a 1986 F250 HD 4wd. 4 speed with Low 1st. 4:10 gears. Medium blue. 8 ft fleetside bed. There's a thread on here about this one too. Long term project I'm hoping to dedicate more time to this year. @ebinmaine Between the new Camper and the Horse trailer it may be sooner than later. 1 2 Share this post Link to post Share on other sites
ebinmaine 81,282 #63 Posted October 20, 2025 1 hour ago, MainelyWheelhorse said: may be sooner Here's hoping!! 1 Share this post Link to post Share on other sites
