WHX??
A-90 Special Resto
WHX??
Since this is turning out to be a resto starting a new thread here.
The original thread...
Not much progress as some health issues really slowing me up.
Some pics and progress by the end of the day right now I gotta  try and climb up in the parts shed loft and see if I have a hood for @c-series don.
  • Like 4
Mike'sHorseBarn
Gotta see this one through! :thumbs:
Is this something @Achto can solve with what I call a 2 x 4 treatment?
In all seriousness, hope it's not too bad!
  • Haha 2
daveoman1966
I can likely find a hood for the A-90...  Also have an assortment of other A-90 parts.... as well as a dozer blade.  See pics.
I am in n/w PA...40m southe of Lake Erie.
803127784_liftbar(3).JPG.717076e895c7043b2fa81f4fd147e8d6.JPG2130593668_a90snow(1).JPG.65c78242357b044f1433bd2fc0c45886.JPG1221020994_A90DOZ(3).JPG.837ae97d3765a8ac33addeefaff880f1.JPG558355700_parts001.JPG.59488b91409f8a70321f605b46b395df.JPG
ebinmaine
:popcorn:
I'll be over here following along. Hopefully you can get this done before us bunch of clowns gets it up around 60 pages.
  • Haha 6
Achto
Not likely, but one needs to have goals.:lol:
  • Haha 5
Achto
4 minutes ago, WHX?? said:
Picked a bad day to quit smokin... and drinkin... and salt.
At least you didn't have to give up your sense of humor. :handgestures-thumbupright:
  • Haha 6
  • Heart 1
WHX??
Shouldn't need any parts @daveoman1966 but thanks and will keep you in mind I do.
For a basket case all parts were ther.
She is a roller now. Steering was froze up solid. Fan gear, tie rods, spindles and everthing. I won in the end. Brake & clutch all freed up and workin as should.
Hubs ... worst I ever seen. New keyways & crack in one I need to try and weld up. Was going to replace them but their not like standard hubs. Shorter and different diameter for the rim hole. Axles have the key very close to the axle bearing. Standard hub on the left.
Edited by WHX??
  • Like 4
  • Sad 1
SylvanLakeWH
Wow... Fair thee well @WHX??... hope you are on the mend...
44 minutes ago, WHX?? said:
Took some static shocks off the blast cabinet & fired up a horse and grabbed hold of the plug wire... didn't work.
I can bring the little:scared-shocked: to @Pullstart's plow day you need a jolt... :handgestures-thumbupright:
  • Excellent 3
SylvanLakeWH
Excellent... I'll bring jumper cables for your heart... @Achto can handle all your other "needs"... :scared-eek:
  • Haha 6
953 nut
12 hours ago, WHX?? said:
Mrs finally made me go in
Guess Cindy wants you to hang around a bit longer, so do we.   I will add you to my prayer list for healing and Cindy for putting up with you.   :ychain:
  • Haha 1
  • Heart 3
squonk
Lol I may take a hit off Richard's A-60... :lol:
Was in doubt I would make it to Pullstart's at all. Not suposed to do anything strenuous and only lift 20 lbs but Dan gonna do the heavy & even offered to hold it when I pee... :laughing-rolling:
See I knew you was a Sally! :lol:
10 years this Nov. since my attack. going to eat a gal of ice cream on the anniversary! :banana-linedance:
  • Haha 5
rjg854
I'm with Richard on this one, I'll pray for you and Cindy.  Been 6 years since mine, a couple of stents. And I've been doing fine.
Easy does it, brother. I'm sure you want to milk that SSA for all you put into it.  ;)
WHX??
New switches & ig switch harness. Old ig switch cleaned up and checked good. Choke & throttle rusted tight. Managed to save one but had to replace the other.
Edited by WHX??
  • Excellent 6
