WHX?? 58,172 #1 Posted April 1, 2024 Since this is turning out to be a resto starting a new thread here. The original thread... Not much progress as some health issues really slowing me up. Some pics and progress by the end of the day right now I gotta try and climb up in the parts shed loft and see if I have a hood for @c-series don. 4 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,681 #2 Posted April 1, 2024 Gotta see this one through! 32 minutes ago, WHX?? said: Not much progress as some health issues really slowing me up. Is this something @Achto can solve with what I call a 2 x 4 treatment? In all seriousness, hope it's not too bad! 1 1 2 Share this post Link to post Share on other sites
daveoman1966 3,884 #3 Posted April 1, 2024 I can likely find a hood for the A-90... Also have an assortment of other A-90 parts.... as well as a dozer blade. See pics. I am in n/w PA...40m southe of Lake Erie. 2 1 Share this post Link to post Share on other sites
ebinmaine 80,755 #4 Posted April 1, 2024 I'll be over here following along. Hopefully you can get this done before us bunch of clowns gets it up around 60 pages. 6 Share this post Link to post Share on other sites
Achto 32,770 #5 Posted April 1, 2024 20 minutes ago, ebinmaine said: Hopefully you can get this done before us bunch of clowns gets it up around 60 pages. Not likely, but one needs to have goals. 5 Share this post Link to post Share on other sites
WHX?? 58,172 #6 Posted April 1, 2024 8 hours ago, Mike'sHorseBarn said: Is this something @Achto can solve with what I call a 2 x 4 treatment? In all seriousness, hope it's not too bad! He should wack me around with a 2x4... maybe feel better. Apparently had a heart attack end of Feb. Chest hurt & couldn't walk from the shop to the warehouse without losing breath. Mrs finally made me go in. Ended up in emergency and 4 days in the hospital. They was saying I was A Fib. Told them to go to hell I was born & raised in WI. Was supposed to get shocked to get heart going right again but then they couldn't do it cause of stroke risk or some baloney. Took some static shocks off the blast cabinet & fired up a horse and grabbed hold of the plug wire... didn't work. So for now they just stood me in a corner and shot pills at me with a sling shot. Month later no better. No faith in doctors at all and VA no help whatsoever. Picked a bad day to quit smokin... and drinkin... and salt. 2 4 9 Share this post Link to post Share on other sites
Achto 32,770 #7 Posted April 1, 2024 4 minutes ago, WHX?? said: Picked a bad day to quit smokin... and drinkin... and salt. At least you didn't have to give up your sense of humor. 1 6 1 Share this post Link to post Share on other sites
WHX?? 58,172 #8 Posted April 1, 2024 (edited) Shouldn't need any parts @daveoman1966 but thanks and will keep you in mind I do. For a basket case all parts were ther. She is a roller now. Steering was froze up solid. Fan gear, tie rods, spindles and everthing. I won in the end. Brake & clutch all freed up and workin as should. Hubs ... worst I ever seen. New keyways & crack in one I need to try and weld up. Was going to replace them but their not like standard hubs. Shorter and different diameter for the rim hole. Axles have the key very close to the axle bearing. Standard hub on the left. Edited April 1, 2024 by WHX?? 4 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,565 #9 Posted April 2, 2024 Wow... Fair thee well @WHX??... hope you are on the mend... 44 minutes ago, WHX?? said: Took some static shocks off the blast cabinet & fired up a horse and grabbed hold of the plug wire... didn't work. I can bring the little to @Pullstart's plow day you need a jolt... 3 Share this post Link to post Share on other sites
WHX?? 58,172 #10 Posted April 2, 2024 (edited) Lol I may take a hit off Richard's A-60... Was in doubt I would make it to Pullstart's at all. Not suposed to do anything strenuous and only lift 20 lbs but Dan gonna do the heavy & even offered to hold it when I pee... Edited April 2, 2024 by WHX?? 11 Share this post Link to post Share on other sites
SylvanLakeWH 32,565 #11 Posted April 2, 2024 Excellent... I'll bring jumper cables for your heart... @Achto can handle all your other "needs"... 6 Share this post Link to post Share on other sites
953 nut 69,409 #12 Posted April 2, 2024 12 hours ago, WHX?? said: Mrs finally made me go in Guess Cindy wants you to hang around a bit longer, so do we. I will add you to my prayer list for healing and Cindy for putting up with you. 3 1 1 3 Share this post Link to post Share on other sites
squonk 48,137 #13 Posted April 2, 2024 12 hours ago, WHX?? said: Lol I may take a hit off Richard's A-60... Was in doubt I would make it to Pullstart's at all. Not suposed to do anything strenuous and only lift 20 lbs but Dan gonna do the heavy & even offered to hold it when I pee... See I knew you was a Sally! 10 years this Nov. since my attack. going to eat a gal of ice cream on the anniversary! 5 Share this post Link to post Share on other sites
rjg854 13,370 #14 Posted April 2, 2024 2 hours ago, 953 nut said: Guess Cindy wants you to hang around a bit longer, so do we. I will add you to my prayer list for healing and Cindy for putting up with you. I'm with Richard on this one, I'll pray for you and Cindy. Been 6 years since mine, a couple of stents. And I've been doing fine. Easy does it, brother. I'm sure you want to milk that SSA for all you put into it. 2 1 Share this post Link to post Share on other sites
WHX?? 58,172 #15 Posted April 9, 2024 (edited) New switches & ig switch harness. Old ig switch cleaned up and checked good. Choke & throttle rusted tight. Managed to save one but had to replace the other. Edited April 9, 2024 by WHX?? 6 Share this post Link to post Share on other sites
