sjoemie himself
Case International 585 and implements
ebinmaine
2 hours ago, sjoemie himself said:
I'm looking for a piece of material as shown below. Anybody what this specific pattern/style of plate is called?
To me that's called "diamond plate"  but there's as many patterns as days in a year.
P.p.s.. Also looking for a drill and tap set for standard American/English threads. What sizes should I be looking for?
At home I've got a set with drills and taps for M3-M12. Is there something similar available in the non-metric flavour?
You're in the range of 3/32" to 1/2" there, give or take....
Check some of your bolts to see if they're fine or coarse thread.
That said, I have both sets of taps and dies on hand.
Handy Don
it is easy to go down the rabbit hole with these. I have two medium quality sets. Today these would be USD 40 and 15 respectively. It is easy to get light duty for less and “mechanic” or “production” quality for much, much more (for example with spiral flutes for more precise work, and special alloys for long tool life--think USD 300 and up).
One set has six fine thread taps and dies and six coarse thread taps and dies. 26 pieces all together including the handles. The dies are for cutting threads (the round style vs. the hex-shaped ones intended for chasing threads). They are sized in inches (SAE) ¼, 5/16, ⅜, 7/16, and ½”. These correspond to the most common sizes I see on the WH tractors and other projects and have served me well for many years of light use.
The other has only taps sized for screws #4 to #8 in both coarse and fine thread -- these are commonly used by electricians for electrical boxes and panels. I need them only rarely (they were a gift) and only once (so far) on a WH!
sjoemie himself
The plate is know as 'traanplaat' or 'tear(drop)plate' in the Netherlands.
What we have is more rounded I guess you could say and most of it has more than one tear.
About the threads, the bolts I have removed so far are all coarse threads.
@Handy Don any brands you could recommend in the 'medium' price range? I would only use the taps and dies to chase threads when necessary.
I might try to find some new nuts and bolts when I have fixed a part of the tractor once I know the correct sizes and quantities for that part.
Over the years many brackets etc. have been bolted back on with metric sized bolts, maybe I'll swap them out with standard ones when time comes.
Handy Don
Wow. Did some quick inter web shopping and got a bit of an education update.
SAE-only is becoming a rare item. People skilled enough to buy (and use) taps & dies are apparently buying sets with a larger range of sizes in both SAE and metric. Makes sense, really, as I suspect I’ll want metrics before long!
Also, the “low end” stuff has become cheaper (and poorer in quality) than I remembered while the “medium” has become more costly at the same quality. Makers responding to market trends.
I’ll do some more digging and PM you.
  • Thanks 1
sjoemie himself
Posted (edited)
Hi all! Been a while. Still kicking around. Still building.
In regards to building there's some heavy stuff that needs moving from time to time. Most of it I did with the diy spear but that has it's limits. I've been looking for a lifting mast (is that what you call it?) to go behind the 585. Yesterday I finally picked one up. Lift height is 2.8m (~10ft.) and lift weight is 2500kg (5500lbs).
That kind of lift capacity is great and all but it now (the lack of) weight of my tractor is the limiting factor :confusion-helpsos:
Any way.. here are some pictures.
*edit 2.0 picture issues resolved, supporting member status renewed :happy-jumpgreen:
Edited by sjoemie himself
Picture issues, solved
  • Excellent 4
ebinmaine
Hi Joe!!!
:greetings-wavingyellow:
8ntruck
What you call a lifting master is normally called a fork lift here.  Regardless of what you call it, that is a very handy tool for moving things around.  You will probably wonder how you got along without one.
The discussion on taps and dies brought to mind an adventure I had with one of my projects at work.  The last position I had before retiring was the tooling engineer for the press department.  As new products came into the plant, I was very involved in design and development of the new press dies to build the new product.
The winning vendor for one job ended up being a Brazilian tool shop.  Well, Brazil is a country that runs on the metric system.  The plant I'm working in is in the middle of the US - deep in SAE territory.  I specified that the bolts in these tools were to be SAE threads.  SAE threads are also called English threads.  I'm guessing that the tool shop had to buy some 'English' bolts and taps.  What we actually got were Whitworth threads - a thread system that originated and was common in England in the 1st half ov the 20th century.
  • Like 3
Handy Don
1999 Mars orbiter. $125 million satellite. Orbital data handed over by one team without units specified. Control team assumed different units and loaded accordingly. Crash.
Apollo mission near catastrophe due to oxygen tank stirrer spec’d for lower voltage than actually used. Arcing. Bang.
In engineering school, any answer presented without units was an automatic fail. Learned that lesson super quickly.
  • Like 4
sjoemie himself
The different threads and sizes really are a hot topic. So much 'fun' can be had when a customer comes in with a unknown nipple with the question "can you find me an adapter for this".. is it Witworth, BSP, BSPT, NPT, Metric, Metric fine, UNF, UNC?? :blink:
Besides that at work we also have hydraulic couplings which are a whole world in and of itself. There's different sizes of 'L' couplers which are metric and pretty standard on most agricultural equipment, but those can also be a 'heavy' version which uses the same inner cone size but a larger nut size that are more commonly used in excavators and wheelloaders. John Deere has their own sizes or so I'm told. Than there's the 'British' variety and of course JIC and maybe even more which I've never seen or heard of :P
P.s. I have not yet invested in either taps or dies because it's simply not a priority at the moment.
Working, renovating a home and taking care of 5 horses and giving some attention to the better half doesn't leave a lot of time for hobby activities sadly. Everything in due time..
P.p.s. Am (still) looking for a replacement grille for the 585 but find new reproductions to be very expensive and I have some doubts about fitment. I did come across some used ones in the US but I'm not sure how that works regarding shipment, duty, tariffs and what not.
Anyone got experience in that departement?
Greetings from the Netherlands, Mark
Handy Don
Some years ago @Pullstart shipped a palleted tractor plus some parts to @Tractorhead in Germany.
More recently, I shipped a palleted box of family heirloom furniture to Ireland. Being used furniture of low market value, it was under the duty threshold at the time. There were very explicit rules about size, weight, and all content as well as documentation--detailed but not onerous.
With so many source-destination-content-timing combinations, it pays to consult a shipper with direct current knowledge.
  • Thanks 1
  • Similar Content
    • Donavon1
      By Donavon1
      Need some help deciding on a brand of engine to buy for my 1054. (Needs to be a diesel 10 hp+) I’m refining used motor oil/cooking oil for fuel for it. So it will have to have an option to run used oil and diesel
    • PWL216
      By PWL216
      I have for sale a 1984 C-105 with deck and Snowblower. I got this as part of a package. There’s no battery and I haven’t tried to start it. I’m selling it as a project. The deck has one spindle out, but with it, as prior owner claims bearing was replaced. The snowblower has the flag and looks to be in very good condition. All but 1 tire holds air. The mower is complete. Includes mule drive. The extra hood (c-175) you see in the picture can go with the tractor for an additional $50. Thx for looking.
    • OldWorkHorse
      By OldWorkHorse
      Working on a custom light bar for the recently restored 314-8
    • JZilla024
      By JZilla024
      Hello everyone!
      I recently inherited my grandpa's
      Wheel Horse 753. I remember it running before his health declined about 15 years ago. My intentions are just to get it running and do a mild restoration, it'll stay in the family.
      Without further ado, here it is!
      Having a hard time with pictures due to no phone service at my shop. I'll be sure to update soon.
