ebinmaine 77,564 #1 Posted January 5, 2024 These look like a Standard Part to me but I'm not sure what to call them. 1 Share this post Link to post Share on other sites
Wayne0 1,527 #2 Posted January 5, 2024 Looks to be pretty easily made. Old Yankee speakin' here. 2 Share this post Link to post Share on other sites
WHX?? 55,281 #3 Posted January 5, 2024 (edited) Just cable clamps... might find them in the Hillman drawers or McMaster Carr? They do seem to grow legs and walk away. Maybe check with Original Cab as a replacement part? Edited January 5, 2024 by WHX?? 4 Share this post Link to post Share on other sites
ebinmaine 77,564 #4 Posted January 5, 2024 6 minutes ago, Wayne0 said: Looks to be pretty easily made. Old Yankee speakin' here. No way for me to easily reproduce it. 1 Share this post Link to post Share on other sites
ebinmaine 77,564 #5 Posted January 5, 2024 12 minutes ago, WHX?? said: Just CABLE CLAMP ... might find them in the Hillman drawers or McMaster Carr? They do seem to grow legs and walk away. Maybe check with Original Cab as a replacement part? Appreciate that info Jim. A bit of interwebs searching shows some but not this thick. Maybe Grainger ...? 1 Share this post Link to post Share on other sites
Wayne0 1,527 #6 Posted January 5, 2024 8 minutes ago, ebinmaine said: No way for me to easily reproduce it. Bang a piece of strap over a mandrel. Or as @WHX?? suggested. 2 Share this post Link to post Share on other sites
wallfish 19,400 #7 Posted January 5, 2024 8 minutes ago, ebinmaine said: No way for me to easily reproduce it. HUH? Cut a door hing then. 3 Share this post Link to post Share on other sites
ebinmaine 77,564 #8 Posted January 5, 2024 1 minute ago, Wayne0 said: Bang a piece of strap over a mandrel. Or as @WHX?? suggested. The metal is too thick to reform on the one bent one we have. I'm missing one too though so I figured to purchase two. 3 minutes ago, wallfish said: HUH? Cut a door hing then. Ya might have a thought there John. Trina can poke around and see what we have. She's the local gate manufacturer and hinge stock manager. 1 Share this post Link to post Share on other sites
wallfish 19,400 #9 Posted January 5, 2024 (edited) 3 minutes ago, ebinmaine said: The metal is too thick to reform on the one bent one we have. I'm missing one too though so I figured to purchase two. Ya might have a thought there John. Trina can poke around and see what we have. She's the local gate manufacturer and hinge stock manager. If your door has 3, steal the middle one and replace it later! Tractor stuff is more important! LOL Probably a bigger hole on the door hing so you can even bush it too! Smoothness Edited January 5, 2024 by wallfish 1 3 Share this post Link to post Share on other sites
ebinmaine 77,564 #10 Posted January 5, 2024 8 minutes ago, wallfish said: If your door has 3, steal the middle one and replace it later! Tractor stuff is more important! LOL I do not disagree! 8 minutes ago, wallfish said: Probably a bigger hole on the door hing so you can even bush it too! Smoothness This cab may actually have the same size pin! 1 Share this post Link to post Share on other sites
JCM 10,802 #11 Posted January 5, 2024 Give OTC a call. They look like stock door hinges that are on their cabs. Frame work looks like OTC as well. 1 1 Share this post Link to post Share on other sites
wallfish 19,400 #12 Posted January 5, 2024 1 minute ago, ebinmaine said: I do not disagree! This cab may actually have the same size pin! You can open it up if you need a little more hole, or cut just a sliver and knock it closed more if you need a smaller hole 1 Share this post Link to post Share on other sites
Ed Kennell 45,051 #13 Posted January 5, 2024 A gate hinge? 4 Share this post Link to post Share on other sites
wallfish 19,400 #14 Posted January 5, 2024 (edited) 2 minutes ago, Ed Kennell said: A gate hinge? You build'n armored cabs or sumtin ED? Edited January 5, 2024 by wallfish 4 Share this post Link to post Share on other sites
ebinmaine 77,564 #15 Posted January 5, 2024 3 minutes ago, wallfish said: You build'n armored cabs or sumtin ED? Go big or go home 3 Share this post Link to post Share on other sites
Ed Kennell 45,051 #16 Posted January 5, 2024 3 minutes ago, wallfish said: You build'n armored cabs or sumtin ED? Hey, he didn't like your skinny cable clamps, so I went heavy. 4 1 Share this post Link to post Share on other sites
c-series don 11,513 #17 Posted January 5, 2024 (edited) @ebinmaineWell today is your lucky day because I have four of them. I’ll text you. Edited January 5, 2024 by c-series don 5 1 1 Share this post Link to post Share on other sites
8ntruck 8,632 #18 Posted January 5, 2024 (edited) Apparently, you start a thread on the Wheel Horse forum with a title of "How do I find these cab hinges?" Edited January 5, 2024 by 8ntruck 3 Share this post Link to post Share on other sites
Maxwell-8 4,370 #19 Posted January 5, 2024 5 hours ago, 8ntruck said: Apparently, you start a thread on the Wheel Horse forum with a title of "How do I find these cab hinges?" and within minutes, someone will send you a couple. 1 3 Share this post Link to post Share on other sites
ebinmaine 77,564 #20 Posted January 5, 2024 54 minutes ago, Maxwell-8 said: and within minutes, someone will send you a couple. Ain't this place great?!?! Hiya Max! @c-series don You're a good man. 😃 2 Share this post Link to post Share on other sites
CCW 1,491 #21 Posted January 5, 2024 12 hours ago, ebinmaine said: No way for me to easily reproduce it. Weld a piece of tubing to a piece of flat stock. You could even take a few nuts of the proper size welded together and drilled out then welded to the flat stock. 1 2 Share this post Link to post Share on other sites
peter lena 9,782 #22 Posted January 5, 2024 @JCM agree with you on the opportunity , typically those stamped , ends have a structural crack , right there , adding a front / back light steel reinforcement , along with FENDER WASHERS , to spread / reinforce the elastic lock nuts , would make that a solid point , instead of a flexing / cracking area . https://www.google.com/search?q=preforated+steel&rlz=1C1CHBF_enUS866US866&oq=preforated+steel&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIJCAEQABgKGIA regularly use this for a go to point , only a suggestion , also easily trimmed up with tin snips . still have this in stainless steel . insure a heavier flat washer , to spread the connection . pete 3 Share this post Link to post Share on other sites
ebinmaine 77,564 #23 Posted January 5, 2024 3 hours ago, CCW said: Weld a piece of tubing to a piece of flat stock I need to remember that idea for next time 2 Share this post Link to post Share on other sites
