Donavon
Wheel horse 1054
Donavon
Need ideas to convert my 1054 A Frame plow into a snow blower
Any idea's?
Ed Kennell
3 minutes ago, Donavon said:
Any idea's?
Put an ad in our classifieds wanted section.      Single stage Wheel Horse snow blowers are for sale everywhere.     I just sold one for $50.
953 nut
There is a snow blower made for the 953/1054. Lincoln at A-Z Tractor may have one, give him a call.  https://www.a-ztractor.com/
Pullstart
:text-yeahthat: and it does not mount the same as a snow plow :handgestures-thumbupright:
Ed Kennell
If you are mechanically talented and able to cut, weld , and fabricate, you could possible attach a self powered walk behind snow blower to your existing plow frame.
I believe a member on here did just that mounting two walk behinds side by side.
IMO, you would be much better served by trying to find a correct blower for sale close to you.   To ship a blower would cost 2-3 times the value of a blower.
Pullstart
That was @Gregor :handgestures-thumbupright:
Donavon
I'm wondering if I take a post hole augger and mount it on the plow if it would work the same as a snow blower auger
  • Confused 1
pfrederi
Post hole auger will move the snow to one end...Snow blower augers move it to the middle...
Gregor
Unfortunately that puter took a crap, and I no longer have pics of that set up. I had 2 1964 Lawn Boy snow blowers mounted to the front of a 656. It was a fun project, but not practical at all. To begin with a 2.5 HP snow blower will barely blow snow out of it's own way. Second of all, 2 snow blowers mounted on the front of a tractor is VERY heavy. Lifting them and steering the tractor, was a major problem. To top that off, the noise level was deafening. Like I said, fun project, but not practical at all.
  • Like 4
  • Similar Content
    • morePEdal
      By morePEdal
      *16 HP Onan Engine, 665.4 Hours
      *8 Speed Transmission
      *48” Snow Plow- Works Great! Set up and READY TO GO BEFORE THE SNOW!
      *Nice 42” Mowing Deck, no rot or welds, smooth spindles
      *OEM Wheel Weights, 50 lbs. Each
      *Chains
      *Valves adjusted this summer, runs great!
      *Good battery
      *Tires All Hold Air
      *LED lights all the way around
      *Manuals included
      Bought a Honda tractor with 4WD and 4WS with deck, plow and snowblower so I don’t need this tractor.
      Cash Only!
      *WILL NOT RESPOND TO “IS THIS STILL AVAILABLE?”
      *COMING SOON:  Also selling a Wheel Horse 520H with a 2-Stage Snowblower. Check out that listing if you want a snowblower garden tractor!
    • DeltaNu1142
      By DeltaNu1142
      I bought a 5xi package yesterday including some attachments I'm not going to need:
      4' plow, model # 79355 - in great condition, very minor surface rust on crossmember and back side of blade. $250 48" mower deck with blower and bagger - in good condition, working when removed from tractor yesterday. Previous owner said it never clogged on him. Some surface rust on deck and one 2" hole near the center. $300.
      I'm open to offers and interested in trades! I'm looking for a 2-stage snow thrower, p/n 79366. Maybe tools, etc.
      Available for pickup--let me know if you have any questions. Thanks!
      Here's a photo of the deck that's included. It's got some rust holes, but functions perfectly. Most of the price here is wrapped up in the blower & bagger:
    • Bbo44
      By Bbo44
      SOLD SOLD 520xi with air cooled 20hp Kohler - tractor in great shape and solid. Everything works. Engine was removed a few years ago and cleaned of grass buildup. New head gaskets and PTO seal a few years ago. Engine showed a decent amount of wear but runs strong and fires right up. Didn’t like the wear and needed a zero turn for my property. Would not hesitate to mow with it right now. 1200 hours. Have original paperwork. New air filter, fuel filter, fresh oil & filter. It’s been mowing 3+ acres for 20 years.
      52” side discharge deck complete. Currently mounted on the 520xi- solid, welded/patched cracks and holes. Front roller broken and patched, newer belt. Was just removed and cleaned. Welded chips in blades, but never finished sharpening. Solid deck, decent life left.
      48” wheel horse complete plow for 520xi 79355. Was used for snow. In great shape.
      48” wheel horse plow incomplete for 300 series garden tractor. Was used for parts. Not sure what it is missing but what’s there is very solid.
      MUST TAKE ALL. WILL NOT SEPERATE. Won’t answer if you ask. $750 CASH for everything. Only thing I’d consider selling separate is the 48” incomplete plow for 300 series. Will not deliver.
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • Wheel Horse 3D
      By Wheel Horse 3D
      Our customized ornaments have a base identical to our version of the original style ornament, but can be topped with 3 different styles of horse head and 3 different styles of wheel! Each is available unfinished, primed, or fully painted.
      They also include the pictured mounting hardware and the base spacer for a clean finished look. Can be ordred here https://greystone-3d.square.site/product/customizable-wheelhorse-hood-ornaments/10
