Phan 49 #1 Posted October 6, 2023 Hi all, She starts no issue and runs strong ! I got her a few years ago but had never used it until last winter when I used a snow blower and added some 10W40 motor oil to the Tranxale. I made a mistake and added too much. Then I noticed that when I engaged the PTO, the engine stalled. I put the snow plow on instead of the blower, it ran fine except I found oil leaking from a hose and the cup of the lifter. Anyone, please advise me. Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,845 #2 Posted October 6, 2023 Have a model number and serial number? Do you have a seat switch? The pto switch and the seat switch control the ignition on most models. Operator falls out of seat with the pto engaged so ignition is shut off. 1 Share this post Link to post Share on other sites
WHGuy413 2,848 #3 Posted October 6, 2023 Definitely sounds like a safety switch issue to me. Had the same problem with a c-105 that I worked on for a friend. Safety switch ended up being bad. Share this post Link to post Share on other sites
Phan 49 #4 Posted October 6, 2023 3 hours ago, gwest_ca said: Have a model number and serial number? Do you have a seat switch? The pto switch and the seat switch control the ignition on most models. Operator falls out of seat with the pto engaged so ignition is shut off. I do not remember, but I do remember the PTO working with the snow blower at one point. I looked under the seat and saw a plug, but it was not connected to the seat. I may have accidentally disconnected it but I don't recall. Share this post Link to post Share on other sites
953 nut 63,003 #5 Posted October 6, 2023 You said it stalled with the snow blower on but was not a problem previously. Will energising the PTO without the snow blower stop the engine from running without the snow blower on the tractor? On later model the PTO switch has two switches in it. One switch will prevent the starter from operating when the PTO is engaged, the other half on the PTO switch is in series with the seat switch and will shut down the engine's ignition if there is no operator in the seat when the PTO is activated. The wiring diagram for a 1977 B and C series shows an electrical switch that will prevent starting with the PTO on but there doesn't appear to be a seat switch and nothing from PTO switch controlling the ignition. Share this post Link to post Share on other sites
Racinbob 12,424 #6 Posted October 7, 2023 Richard, that is not the correct diagram. I was baffled when I read your post because I knew my 76 had a seat switch and you're right, it doesn't show it. Here is the correct diagram taken from the original owners manual. Apparently we need to be wary of those colored diagrams. 1 Share this post Link to post Share on other sites
953 nut 63,003 #7 Posted October 7, 2023 3 hours ago, Racinbob said: I was baffled when I read your post because I knew my 76 had a seat switch and you're right, it doesn't show it Thanks for posting this Bob. I couldn't think of a component that would cause this problem if it wasn't a seat switch. The drawing I pulled up from the files section was a bit confusing since it shows two PTO switches and lines that don't lead to anything that are calling out for a manual PTO and an electric PTO. Perhaps this is something Garry @gwest_ca can look into for us. Share this post Link to post Share on other sites
953 nut 63,003 #8 Posted October 7, 2023 The 1975 wiring diagram in our files section is like the one @Racinbob has shown us if @Pokk has a manual PTO rather than an Electric one. Keep the faith, we will figure this out! 1 Share this post Link to post Share on other sites
Phan 49 #9 Posted October 7, 2023 I found this on the internet Wheel Horse C160H 71-16KS01. It shows a wire to the seat which mine is missing the end wire connector of the seat (I might accidentally remove it). How/where can I connect it/buy it? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,845 #10 Posted October 7, 2023 Read the notes here. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,845 #11 Posted October 8, 2023 20 hours ago, 953 nut said: Thanks for posting this Bob. I couldn't think of a component that would cause this problem if it wasn't a seat switch. The drawing I pulled up from the files section was a bit confusing since it shows two PTO switches and lines that don't lead to anything that are calling out for a manual PTO and an electric PTO. Perhaps this is something Garry @gwest_ca can look into for us. Models with electric pto clutch have the wiring on the left and controls the starter with the pto switch. Have forgotten which tractor models these are. Models with manual pto clutch have the wiring on the right. Single pto switch controls starter. 1 Share this post Link to post Share on other sites
953 nut 63,003 #12 Posted October 8, 2023 4 hours ago, gwest_ca said: Models with electric pto clutch have the wiring on the left and controls the starter with the pto switch. Have forgotten which tractor models these are. Models with manual pto clutch have the wiring on the right. Single pto switch controls starter. Do the electric PTO models have a seat switch? Seems rather odd that the 1975 drawing with a manual PTO has a set switch. and the electric PTO models show two switches. I have never owned either one so have no firsthand knowledge. 1 Share this post Link to post Share on other sites
Phan 49 #13 Posted October 8, 2023 Hello everyone, Has anyone saw this: https://www.youtube.com/watch?v=9BPwY2s5Xco&t=880s&ab_channel=BrandonMatz I assumed he meant that there are two types of fluid: the hydraulic fluid (the first cap he filled with fluid and spilled at 12:22) and the transmission fluid. What is the hydraulic fluid I should use, mind it has been leaking on a hose. Share this post Link to post Share on other sites
Phan 49 #14 Posted October 8, 2023 9 hours ago, 953 nut said: Do the electric PTO models have a seat switch? Seems rather odd that the 1975 drawing with a manual PTO has a set switch. and the electric PTO models show two switches. I have never owned either one so have no firsthand knowledge. Me too Share this post Link to post Share on other sites
953 nut 63,003 #15 Posted October 9, 2023 1 hour ago, Pokk said: Has anyone saw this: Should have used 10 W 30 or 10 W 40 oil. Dexron was used up to 1971 or so. Share this post Link to post Share on other sites
