ebinmaine 63,502 #1 Posted October 3, 2023 What's the definitive way to tell if a KT17 is a Series 1 or Series 2 engine? Share this post Link to post Share on other sites
oliver2-44 8,917 #2 Posted October 3, 2023 The Series 1 did not have an oil filter. Also by serial number but tins can be switched. 1 Share this post Link to post Share on other sites
ebinmaine 63,502 #3 Posted October 3, 2023 21 minutes ago, oliver2-44 said: The Series 1 did not have an oil filter. Also by serial number but tins can be switched. What's the year span? Share this post Link to post Share on other sites
J854D 128 #4 Posted October 3, 2023 (edited) @ebinmaine, Eric, the spec numbers for series 1 is 24299 and lower and series 2 is 24300 and higher. If you go to the manuals section under engines, there is a KT17 & KT19 service manual available. The descriptions part of that file has a nice breakdown of the years and Wheel Horse models that those engines were used in. -JD- Edited October 3, 2023 by J854D 1 2 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,540 #5 Posted October 3, 2023 https://www.wheelhorseforum.com/search/?q=kt17&quick=1&type=downloads_file 1 1 Share this post Link to post Share on other sites
ebinmaine 63,502 #6 Posted October 3, 2023 3 hours ago, oliver2-44 said: The Series 1 did not have an oil filter. Also by serial number but tins can be switched. I believe I have a series 2 without a filter also. Share this post Link to post Share on other sites
midpack 813 #7 Posted October 3, 2023 1 hour ago, ebinmaine said: I believe I have a series 2 without a filter also. I do as well 1 Share this post Link to post Share on other sites
oliver2-44 8,917 #8 Posted October 3, 2023 @midpack@ebinmaine I stand corrected. Looking at the service manual it says "some engines are equipped with an oil filter" I'm curious, does your engines have a blanked off place to add an oil filter? Share this post Link to post Share on other sites
ebinmaine 63,502 #9 Posted October 3, 2023 34 minutes ago, oliver2-44 said: @midpack@ebinmaine I stand corrected. Looking at the service manual it says "some engines are equipped with an oil filter" I'm curious, does your engines have a blanked off place to add an oil filter? @OldWorkHorse is there a blank on that one? Share this post Link to post Share on other sites
8ntruck 6,478 #10 Posted October 3, 2023 I'm thinking that a series 1 does not have provisions for an oil filter, and the series 2 does have oil filter provisions. Curious if the KT 17 series 1 had the same oiling issues that the KT 19 series 1 did. Share this post Link to post Share on other sites
midpack 813 #11 Posted October 3, 2023 1 hour ago, oliver2-44 said: I'm curious, does your engines have a blanked off place to add an oil filter? My series 2 has a block off plate. I even found a mounting plate but I haven't put it on. A remote filter would be the way to go Share this post Link to post Share on other sites
953 nut 52,197 #12 Posted October 3, 2023 1 hour ago, 8ntruck said: Curious if the KT 17 series 1 had the same oiling issues that the KT 19 series 1 did 1 Share this post Link to post Share on other sites
Brockport Bill 1,409 #13 Posted October 4, 2023 here are 2 photos of what is my understanding shows the 2 different features of the Series 1 and Series 2 engine - Share this post Link to post Share on other sites
Brockport Bill 1,409 #14 Posted October 4, 2023 i have found the Series 1 or 2 engine model indication on the tins and the air cleaner to be unreliable since so many have been changed over the years 1 Share this post Link to post Share on other sites
ebinmaine 63,502 #15 Posted October 4, 2023 8 hours ago, Brockport Bill said: here are 2 photos of what is my understanding shows the 2 different features of the Series 1 and Series 2 engine - Bill it appears from my reading and asking questions that the earlier Series 2 engines did NOT have the oil filter boss. We have a pair of 1986 417As that we have no reason to believe have been modified and neither one has the boss to add an oil filter. Share this post Link to post Share on other sites
Brockport Bill 1,409 #16 Posted October 4, 2023 4 hours ago, ebinmaine said: Bill it appears from my reading and asking questions that the earlier Series 2 engines did NOT have the oil filter boss. We have a pair of 1986 417As that we have no reason to believe have been modified and neither one has the boss to add an oil filter. I have a c175 from 83 that's series 1 and a 84 c175 with series 2...it's certainly challenging to confirm various models with certainty?? 1 Share this post Link to post Share on other sites
ebinmaine 63,502 #17 Posted October 4, 2023 21 minutes ago, Brockport Bill said: I have a c175 from 83 that's series 1 and a 84 c175 with series 2...it's certainly challenging to confirm various models with certainty?? Agreed. Especially in your case where that's right near the year split. 1 Share this post Link to post Share on other sites
