Countdown To Christmas!
Jayoutdoors
picking the correct hitch...help
Jayoutdoors
hey there  I would like to install a ball and pull my boat and utility tractor around the property.  I don't feel as if the design of this drawbar style is built for that not to mention low height.   What recommendations, bought or built do you have to help me out..
it would be nice to keep my tiller attachment on if possible.
also what did they use the bar coming from under seat for??
Edited by Jayoutdoors
peter lena
@Jayoutdoors  yes that added height will do the trick , always like the ball hitch , because its so quick / easy , BTW  also like lucas climbing gear oil , heavy duty , or synthetic  additive rear end oil , after a flush and new shift boot , TYE WRAP  just above the boot  on the steel shifter shaft , lets the boot move , silicone grease on inside if boot base , lets it move easily , do a flush on the gear unit , drive it around , dump it , very quiet / easy gearing , also get after related clutch linkage , lubrication points , that should just about do it , pete
Pullstart
That bent/holed up bar is not a factory item.  Lowell @wheelhorseman makes a pretty stout receiver hitch.  I don’t know if it’ll allow retaining the tiller bracket?
  • Excellent 3
Jayoutdoors
thanks i will get rid of the ugly thing.   I think the receiver style is definitely where I'm headed. the one linked above do allow for keeping the bracket and lower pin hitch
Pullstart
I didn’t see Greasy Pete’ link.  Same guy, Lowell.  :handgestures-thumbupright:
  • Haha 1
ebinmaine
Another vote for Lowell's hitch. ....
  • Heart 1
WHX??
I'll  go the other way and recommend a ball hitch for the front. Easy fab to make one to clip on a mule attach. Always easier to maneuver even in small yards.
I have no pics but on the tractor do list to make one.
Many of the boys here have done it so hopefully they have some pics.
I do have dedicated tractors with a ball mounted right on the draw bar but then useless for tub duty or anything else.
Problem with Lowell's hitches is you might lose the axle bracket and there goes the tiller. I doubt you would be able to use anything but a receiver hitch.
I don't see any lift for the tiller tho?
Kev is right that Holy piece is a PO dream.
Edited by WHX??
  • Excellent 2
SylvanLakeWH
This one snaps in to the front attachomatic...
Lowell's back one. Love it t.
Edited by SylvanLakeWH
  • Excellent 3
  • Heart 1
WHX??
Mighta figured Sylvia he had a way to keep the axle bracket.
Best to call him before you order @Jayoutdoors and explain your needs and make sure it would work with a tiller. He'll know. He might even offer a front mount.
Jayoutdoors
I've been researching it. The receiver part removes fairly easy for the lift hitch. So I think It should work for tiller lift.  The bracket below axle to pivot tiller off of stays with it.
SylvanLakeWH
Nope. I've inquired. He doesn't have front ones...
I bought my couple off Ebay.
stevasaurus
Front hitch..."Shorts" Paul made this for me.  Works excellent and should be easy to fabricate using these pictures.  :USA:
  • Excellent 3
clueless
There is a fellow on ebay, wildcruiser (2027) who sells 3 different ones that connect to the front "attach -a -matic" after removing the deck mule drive. I have all three. One you put what ever ball you need on it, the other is a 2" receiver. The third attaches permanently to the front and you don't have to remove the mule drive after you install it:handgestures-thumbupright:. They all work great my favorite is the permanent one. They are all for the front of the tractor so pulling you boat or trailer a fair distance is a bit difficult, but when it comes pulling them out or putting the in tight spaces they a the bomb, (think airplane tug). On the 2" receiver I use a 4" lift hitch, it get what ever your hooked to a bit more level, even easer to use. On the permanent one I use a Change-a-Ball, I'm sure that's not the right name but close, you just change what ever size ball you need with out removing the shaft (No Wrench Need):greetings-clappingyellow:.
  • Like 4
Jayoutdoors
had a hitch laying around. then I felt a little creative last night.  The only thing left to do is add two supports down to the pin!!
  • Excellent 2
  • Similar Content
    • n1defan
      By n1defan
      I am taking orders for the custom heavy duty hitches that Scott and I have been building.
      1. regular hitch $150 + shipping
      2. XI hitch $175 + shipping
      3. custom hitch to your dimensions $150 - $200 + shipping depending on what you need and cost of materials.
      extra plates and bolts $10 To mount hitch to tractor if you don't have a rear plow mount.
      Any questions you can PM me or post here.
      the larger of the two is an XI hitch
    • Southkraut
      By Southkraut
      Was looking to buy rear hitch assembly on eBay don’t know what is comparable with my ‘84 c125. They all look the same. Is there much of any difference through the models?
    • falvarado62
      By falvarado62
      Hi,
      I would like to purchase a class 3 hitch receiver for my 520H.
      I had purchased one for my C120 several years ago and look forward to having one my the 520.
      Thanks,
      Frank
    • Shea Worden
      By Shea Worden
      Hey guys. I was wondering about buying a clevis hitch from the wheelhorseman1000's website wheel horse parts and more, and i wanted to know if  i need the rockshaft between the gas tanks. I thought that the cable went right to the hitch with a trunnion to attach. If you didn't know from my other threads, I have a c81 with an 8-speed uni-drive transmission. My tractor already has the tube for the cable so thats what inspired me to get a clevis.
    • Heavy Duty
      By Heavy Duty
      Well I finally have enough done on my 414-8 to show you all my progress. I built a front 2" receiver hitch that will allow the use of a mule drive and snow blower, The weight bracket is a 4x4x14" steel tube filled with lead (85lbs total not counting the suitcase weights.)  The sleeve hitch works with a 2" receiver hitch, I have a 500 lb linear actuator controlling the height of the sleeve hitch. I plan on removing the actuator and adding full hydraulics to this tractor some day.
      On a side note...i'm really loving the new tires.
      414-8
      414-8
