Bodean 35 #1 Posted June 5, 2023 Tractor says 704 on it but it has a k181s motor and a two piece fuel tank its leading me to believe its a 854 any help would be appreciated this is my 1st one 1 Share this post Link to post Share on other sites
Sparky-(Admin) 25,934 #2 Posted June 6, 2023 Post up the serial number on the decal I circled in blue… I won’t be able to decipher it but someone here will. 3 Share this post Link to post Share on other sites
WHX?? 57,384 #4 Posted June 6, 2023 (edited) Bodean My guess is a 753 with a transplant and wrong belt guard!? Really all academic... a nice survivor but yes as Sparkeye says...good eye Mike. Edited June 6, 2023 by WHX?? Share this post Link to post Share on other sites
Pullstart 70,676 #5 Posted June 6, 2023 (edited) Round hoods rock! It looks like the PO was an electrician? Edited June 6, 2023 by Pullstart 3 2 1 Share this post Link to post Share on other sites
Sparky-(Admin) 25,934 #6 Posted June 6, 2023 6 hours ago, Pullstart said: It looks like the PO was an electrician? Umm…more like a rookie apprentice that wasn’t supervised well 3 Share this post Link to post Share on other sites
Retired Wrencher 6,783 #7 Posted June 6, 2023 I hope the tractor works out well for you. Feel free to ask questions here and in other areas of this Forum. 2 Share this post Link to post Share on other sites
ri702bill 12,474 #8 Posted June 6, 2023 It is either a 1963 or 64, not a 62. I'm leaning towards it being an 854, not a 753. There are some differences - the 753 used a K161S engine with the short air cleaner. - the 854 used the K181S engine with the taller air cleaner. The hood on a 854 is one inch longer when measured from the cutout near the gas cap to the joint at the grille - to let the larger air cleaner fit. Which air cleaner do you have?? BOTH have a rather tight fit with their respective hoods - a 753 hood does not work with a tall air cleaner...... There is a NON-original knob for a switch? next to the height stop adjuster - what is it?? Share this post Link to post Share on other sites
Bodean 35 #9 Posted June 6, 2023 1 hour ago, ri702bill said: It is either a 1963 or 64, not a 62. I'm leaning towards it being an 854, not a 753. There are some differences - the 753 used a K161S engine with the short air cleaner. - the 854 used the K181S engine with the taller air cleaner. The hood on a 854 is one inch longer when measured from the cutout near the gas cap to the joint at the grille - to let the larger air cleaner fit. Which air cleaner do you have?? BOTH have a rather tight fit with their respective hoods - a 753 hood does not work with a tall air cleaner...... There is a NON-original knob for a switch? next to the height stop adjuster - what is it?? I believe that was for a single head light there is a hole in the hood 11 hours ago, Sparky said: Post up the serial number on the decal I circled in blue… I won’t be able to decipher it but someone here will. 1 Share this post Link to post Share on other sites
Bodean 35 #10 Posted June 6, 2023 1 hour ago, ri702bill said: It is either a 1963 or 64, not a 62. I'm leaning towards it being an 854, not a 753. There are some differences - the 753 used a K161S engine with the short air cleaner. - the 854 used the K181S engine with the taller air cleaner. The hood on a 854 is one inch longer when measured from the cutout near the gas cap to the joint at the grille - to let the larger air cleaner fit. Which air cleaner do you have?? BOTH have a rather tight fit with their respective hoods - a 753 hood does not work with a tall air cleaner...... There is a NON-original knob for a switch? next to the height stop adjuster - what is it?? I believe that was for a single head light there is a hole in the hood 11 hours ago, Sparky said: Post up the serial number on the decal I circled in blue… I won’t be able to decipher it but someone here will. 2 Share this post Link to post Share on other sites
Bodean 35 #11 Posted June 6, 2023 I posted pic of air cleaner and serial number hope this helps figure out what i have . 1 Share this post Link to post Share on other sites
WHX?? 57,384 #12 Posted June 6, 2023 (edited) 854 gets my nod now. Serial number puts it right alongside other 854s and the tall air cleaner Bill mentioned. A good candidate for a mechanical resto and a nice patina. Edited June 6, 2023 by WHX?? 1 Share this post Link to post Share on other sites
Pullstart 70,676 #13 Posted June 6, 2023 @Vinylguy here makes amazing decals if you prefer to correct the model on the belt guard 2 Share this post Link to post Share on other sites
ri702bill 12,474 #14 Posted June 6, 2023 (edited) The leading number "4" is the model year - 1964. The tall air cleaner is the correct 8 HP one. Hood lengths - I measured a 7HP hood and a crappy 854 hood I have - the shorter 7 Hp measures 15-1/8", and the 854 hood measures 16-1/8" from the tank cutout to the joint for the grille. The 854 is, to my knowledge a ONE YEAR hood. You have an excellent worker of a tractor - IF the 3 speed is a problem - DO consider upgrading to a later 6 or 8 speed - relatively straight forward to do - the 6 speed is a bit easier. Both @Pullstart and @Handy Don have done the 6 speed swap, I did the 8 speed from a 1979 C81. Having the low range is a big asset... You can always go back to the 3 speed later if you want. Edited June 6, 2023 by ri702bill 1 Share this post Link to post Share on other sites
ri702bill 12,474 #15 Posted June 6, 2023 1 hour ago, Bodean said: I posted pic of air cleaner and serial number hope this helps figure out what i have . Just MIGHT be time for a new air filter and foam??? 1 4 Share this post Link to post Share on other sites
Pullstart 70,676 #16 Posted June 6, 2023 29 minutes ago, ri702bill said: You have an excellent worker of a tractor - IF the 3 speed is a problem - DO consider upgrading to a later 6 or 8 speed - relatively straight forward to do - the 6 speed is a bit easier. Both @Pullstart and @Handy Don have done the 6 speed swap, I did the 8 speed from a 1979 C81. Having the low range is a big asset... You can always go back to the 3 speed later if you want. some day, you’ll remember I swapped an 8 as well 1 1 Share this post Link to post Share on other sites
Bodean 35 #17 Posted June 6, 2023 2 hours ago, WHX?? said: 854 gets my nod now. Serial number puts it right alongside other 854s and the tall air cleaner Bill mentioned. A good candidate for a mechanical resto and a nice patina. Thanks for the info i believe im going for a every nut and bolt restoration on this one. 1 Share this post Link to post Share on other sites
Bodean 35 #18 Posted June 6, 2023 1 hour ago, ri702bill said: The leading number "4" is the model year - 1964. The tall air cleaner is the correct 8 HP one. Hood lengths - I measured a 7HP hood and a crappy 854 hood I have - the shorter 7 Hp measures 15-1/8", and the 854 hood measures 16-1/8" from the tank cutout to the joint for the grille. The 854 is, to my knowledge a ONE YEAR hood. You have an excellent worker of a tractor - IF the 3 speed is a problem - DO consider upgrading to a later 6 or 8 speed - relatively straight forward to do - the 6 speed is a bit easier. Both @Pullstart and @Handy Don have done the 6 speed swap, I did the 8 speed from a 1979 C81. Having the low range is a big asset... You can always go back to the 3 speed later if you want. It measures 16 and a fuz i believe i truly have a 854 1964 thanks for all your help ill look into the trans swap out 2 1 Share this post Link to post Share on other sites
Bodean 35 #19 Posted June 6, 2023 Believe it is the 854 by the hood measure at 16.1 just so happen to find this at the local bone yard this morning 1 2 1 Share this post Link to post Share on other sites
ri702bill 12,474 #20 Posted June 6, 2023 (edited) 9 minutes ago, Bodean said: thanks for all your help ill look into the trans swap out As I said, the 6 speed is an easier swap - no need at get another input pulley or belt - the 8 speed does need both. No need to play with brake linkage or parking brake?? with a 6 speed - the brake band on an 8 speed mounts "backwards" and you need a Raider style brake rod. You need to holesaw two holes in the metal with either one - one in the base of the hoodstand for the Hi-Lo lever, the other under the seat in the base of the toolbox for the fill tube or dipstick. (the 6 speed has a short pipe and plug, the 8 speed has a LONG dipstick and plastic tube that MUST be cut to fit under the fixed seat....) Edited June 6, 2023 by ri702bill 2 Share this post Link to post Share on other sites
ri702bill 12,474 #21 Posted June 6, 2023 Yup - an 854 hood!! 1 Share this post Link to post Share on other sites
WHX?? 57,384 #22 Posted June 6, 2023 2 hours ago, Bodean said: Believe it is the 854 by the hood measure at 16.1 just so happen to find this at the local bone yard this morning Wow what a stroke of luck ...with matching patina! Go get a lotto ticket! 2 Share this post Link to post Share on other sites
Handy Don 16,941 #23 Posted June 7, 2023 19 hours ago, Bodean said: Believe it is the 854 by the hood measure at 16.1 just so happen to find this at the local bone yard this morning Finding this is excellent luck and a good omen! You already have the two trickiest to find items--the hood and the 3” air cleaner. BTW, the 6-speeds I’ve seen (e.g. a 5060) don’t have a dipstick opening on the top of the transmission so no need for a hole in the toolbox. @Pullstart's opinion on the 8-speed is that checking and filling the oil via the lower side plug is pretty easy and unless you are seeing seepage, oil checks on the manual gearboxes are infrequent so you can just plug the top filler hole and not put a hole in the toolbox! Share this post Link to post Share on other sites
Wheel-N-It 2,978 #24 Posted June 8, 2023 On 6/5/2023 at 10:47 PM, Pullstart said: Round hoods rock! It looks like the PO was an electrician? Or an electrical inspector from North Carolina 2 Share this post Link to post Share on other sites
Sailman 1,307 #25 Posted June 10, 2023 I'm in the 854 camp too. The 704 has a different dash set up with the sunken look. Hood has to have steering wheel removed to take it off. 1 Share this post Link to post Share on other sites
