Retired Wrencher 6,109 #26 Posted April 11, 2023 1 minute ago, Oldskool said: Thanks. I thought I would never find one up in my neck of the woods.. It's going to be a fun little project. Well I think they all are. I like those big blocks. Was always on my list but never bought one.I am almost done with two this year already. But being retired helps. 1 1 Share this post Link to post Share on other sites
ebinmaine 74,971 #27 Posted April 11, 2023 6 minutes ago, Oldskool said: At some point I may have to get inside that transmission. What is the best way to free up the cross pin? Drill a small hole on the case seam and use penetrant? Small hole is not a bad idea. Heat. Patience. Repeat. 1 1 Share this post Link to post Share on other sites
Blasterdad 3,045 #28 Posted April 11, 2023 2 minutes ago, Oldskool said: At some point I may have to get inside that transmission. What is the best way to free up the cross pin? Drill a small hole on the case seam and use penetrant? I wouldn't drill a hole in the seam, maybe on the left side in the middle as a last resort, try penatrant & working it first. Nice Brinly hitch.! Just noticed the front tires are on backwards too, something for the to do list. 3 Share this post Link to post Share on other sites
953 nut 62,595 #29 Posted April 11, 2023 54 minutes ago, Oldskool said: At some point I may have to get inside that transmission. What is the best way to free up the cross pin? Drill a small hole on the case seam and use penetrant? I would suggest several 1/8" holes with a 1/4" top portion drilled half way down to act as a reservoir for penetrating oil of your choice. 2 2 1 Share this post Link to post Share on other sites
ebinmaine 74,971 #30 Posted April 11, 2023 It would be a very good idea to get the set screws out of those hubs and start dropping penetrating oil in there as well. 1 1 Share this post Link to post Share on other sites
johnnymag3 2,621 #31 Posted April 11, 2023 And you will want to correct the incorrect belt routing on the mule drive.... I love my C 160......They are beasts. John 1 1 Share this post Link to post Share on other sites
Oldskool 6,666 #32 Posted April 11, 2023 4 hours ago, Blasterdad said: I wouldn't drill a hole in the seam, maybe on the left side in the middle as a last resort, try penatrant & working it first. Nice Brinly hitch.! Just noticed the front tires are on backwards too, something for the to do list. I'll try that. I didn't even notice the tires past my giddiness 2 Share this post Link to post Share on other sites
Oldskool 6,666 #33 Posted April 11, 2023 3 hours ago, johnnymag3 said: And you will want to correct the incorrect belt routing on the mule drive.... I love my C 160......They are beasts. John Good to know. That pulley is froze up tight as well 2 Share this post Link to post Share on other sites
ebinmaine 74,971 #34 Posted April 11, 2023 3 hours ago, Oldskool said: Good to know. That pulley is froze up tight as well Lemme know if that don't free up. 1 1 Share this post Link to post Share on other sites
ebinmaine 74,971 #35 Posted April 11, 2023 7 hours ago, Blasterdad said: front tires are on backwards Good eye there. 2 1 Share this post Link to post Share on other sites
Oldskool 6,666 #36 Posted April 11, 2023 9 hours ago, Oldskool said: At some point I may have to get inside that transmission. What is the best way to free up the cross pin? Drill a small hole on the case seam and use penetrant? Is the hitch pin mild or hardened steel? 1 Share this post Link to post Share on other sites
Oldskool 6,666 #37 Posted April 11, 2023 Someone left these nifty little trailer balls bolted in the front end. Must of had small trailers? 5 Share this post Link to post Share on other sites
Oldskool 6,666 #38 Posted April 11, 2023 Well I think these tierods have tied their last rods. 3 2 Share this post Link to post Share on other sites
Sailman 1,305 #39 Posted April 11, 2023 Great find! Having a C-160 Hydro and a 416-8 with Kohler engines I can say you will enjoy that machine! It'll do anything you need it to do. Good luck with getting it back "on the road". 2 1 Share this post Link to post Share on other sites
Oldskool 6,666 #40 Posted April 11, 2023 It's now a roller. Thank to an unknown WH it now has some air under it. 6 Share this post Link to post Share on other sites
953 nut 62,595 #41 Posted April 11, 2023 2 hours ago, Oldskool said: Is the hitch pin mild or hardened steel? It is a mild steel pin. If you have a large drill press and a long enough set of drill bits you could drill the pin out. I have made it a practice to cut the pin off flush with the transmission and remove the hitch/lift parts prior to attempting to drive the pin out. I then drill a shallow 1/2" hole to hold the punch in place so you don't have to center it with each hammer blow. Lowell @wheelhorseman sells new hitch pins at a reasonable price so it isn't worth trying to save one unless it cones out easily. 1 1 1 Share this post Link to post Share on other sites
Oldskool 6,666 #42 Posted April 11, 2023 26 minutes ago, 953 nut said: Lowell @wheelhorseman sells new hitch pins at a reasonable price so it isn't worth trying to save one unless it cones out easily. I'm hoping to find out soon how hard/easy it will be 2 Share this post Link to post Share on other sites
Oldskool 6,666 #43 Posted April 12, 2023 So how many Horse owners can say they had to scrap the underwear out of the engine before they could whirl it over? 6 Share this post Link to post Share on other sites
23 Reo 230 #44 Posted April 12, 2023 With the underwear you have a very special Horse. 4 Share this post Link to post Share on other sites
Oldskool 6,666 #45 Posted April 12, 2023 Just how long does it take a pair of Haines breifs to disintegrate? I wod say it's been that long since it may have ran. 2 Share this post Link to post Share on other sites
ebinmaine 74,971 #46 Posted April 12, 2023 1 hour ago, Oldskool said: long does it take a pair of Haines breifs to disintegrate? About as long as it would take a small sloth to ride a unicycle backwards and right side down on a flat tire 3.7 nautical miles around the outside of the back 40 hectares ... Give or take 25 years and a pickle and pimento sandwich. 1 4 1 Share this post Link to post Share on other sites
Oldskool 6,666 #47 Posted April 12, 2023 Thanks to @ebinmaine Eric I have some used tierods. Gonna tighten them up and install. At least I'll be able to steer it around. 2 Share this post Link to post Share on other sites
SylvanLakeWH 29,518 #48 Posted April 12, 2023 2 hours ago, Oldskool said: So how many Horse owners can say they had to scrap the underwear out of the engine before they could whirl it over? That's kinda personal... 1 hour ago, 23 Reo said: With the underwear you have a very special Horse. So's that... 1 hour ago, Oldskool said: Just how long does it take a pair of Haines breifs to disintegrate? I wod say it's been that long since it may have ran. And that... 15 minutes ago, ebinmaine said: About as long as it would take a small sloth to ride a unicycle backwards and right side down on a flat tire 3.7 nautical miles around the outside of the back 40 hectares ... Give or take 25 years and a pickle and pimento sandwich. And well... @ebinmaine... really??? underwear, pickles, sloths and pimento's...? Oh man... Where's @Pullstart's latest injury when you need it??? 4 Share this post Link to post Share on other sites
Pullstart 68,405 #49 Posted April 13, 2023 If it wasn’t mentioned about that pin, try grabbing it with a pipe wrench and some heat. Spinning it will break it free much easier than trying to drive it! 2 2 Share this post Link to post Share on other sites
Horse Newbie 7,398 #50 Posted April 13, 2023 On 4/10/2023 at 8:38 PM, Oldskool said: This just got air lifted, well lowered, into my yard. Traded my basket case Panzer T205 for it. I'm thinking I made out ok. @ebinmaine I can now join the C series crew lol. The trans is free and shifts fine. The engine turns by hand,no carb. The clutch spins,attach o magic pulley is froze. Tierods are rusted away. Just a quick chance over. I got yelled at for securing my C-160 with clothes line… 1 4 Share this post Link to post Share on other sites
