Bill D 2,713 #1 Posted April 2, 2023 Got these from Grainger. Good quality. 4 Share this post Link to post Share on other sites
Sparky-(Admin) 24,913 #2 Posted April 2, 2023 For use where? The PTO lever where it goes thru the dash tower maybe? 1 Share this post Link to post Share on other sites
grinchsr 657 #3 Posted April 2, 2023 Maybe on the motion control linkage for the column mounted ones also. Share this post Link to post Share on other sites
WHX?? 55,904 #4 Posted April 2, 2023 (edited) Flip up fender pan hinges. Steering linkages on late model verticals. 3,4, 500 hydro tunnel linkages Edited April 2, 2023 by WHX?? Share this post Link to post Share on other sites
peter lena 9,821 #5 Posted April 2, 2023 @Bill D good stuff , like a dielectric grease for a lubricant in there , made for that , pete Share this post Link to post Share on other sites
moe1965 774 #6 Posted April 2, 2023 (edited) Steering wheel collar up by the fuel tank Edited April 2, 2023 by moe1965 Spelling Share this post Link to post Share on other sites
Bill D 2,713 #7 Posted April 2, 2023 (edited) On 4/2/2023 at 8:35 AM, grinchsr said: Maybe on the motion control linkage for the column mounted ones also. They're 1/2" ID bushings. The 2NCG5's fit the PTO lever. They also fit my Toro Powermax snowblower. The 2MTJ3's fit the hydro linkages on the Eaton equipped tractors. I'm sure they fit other things as well. Sorry for the confusion. When I posted the pictures I assumed most people knew what these fit. Edited April 3, 2023 by Bill D Grammer 1 Share this post Link to post Share on other sites
squonk 45,990 #8 Posted April 2, 2023 (edited) Do not use dielectric grease on plastics or rubbers with a silicon base. It will break them down over time, and you will have to replace them. The grease is also very hard to clean off these surfaces. If you’re trying to lubricate moving parts like gears or bearings, then dielectric grease won’t do anything for them. https://mycarmakesnoise.com/electronics/best-alternatives-for-dielectric-grease/ Although dielectric grease is beneficial, it can also be detrimental when applied incorrectly. The grease is non-conductive; thus, when used incorrectly, it can prevent current flow. If you fail to clean the conductor’s contact points after applying the dielectric grease, the current will not pass through. Another disadvantage of dielectric grease can cause silicone rubber to melt after years of use. You should, however, not use dielectric conductors encased with silicone rubber. https://rxmechanic.com/what-is-dielectric-grease/ Edited April 2, 2023 by squonk 2 Share this post Link to post Share on other sites
Bill D 2,713 #9 Posted April 3, 2023 4 hours ago, squonk said: Do not use dielectric grease on plastics or rubbers with a silicon base. It will break them down over time, and you will have to replace them. The grease is also very hard to clean off these surfaces. If you’re trying to lubricate moving parts like gears or bearings, then dielectric grease won’t do anything for them. https://mycarmakesnoise.com/electronics/best-alternatives-for-dielectric-grease/ Although dielectric grease is beneficial, it can also be detrimental when applied incorrectly. The grease is non-conductive; thus, when used incorrectly, it can prevent current flow. If you fail to clean the conductor’s contact points after applying the dielectric grease, the current will not pass through. Another disadvantage of dielectric grease can cause silicone rubber to melt after years of use. You should, however, not use dielectric conductors encased with silicone rubber. https://rxmechanic.com/what-is-dielectric-grease/ After I clean 9 pin connectors on Onan powered tractors I apply Noalox compound instead. Helps prevent oxidation and doesn't impede current flow. 3 Share this post Link to post Share on other sites
gt14rider 1,148 #10 Posted April 4, 2023 (edited) Used some from Mcmaster carr , 1/2"i.d. x 9/16" o.d. This is on motion control shaft. Edited April 4, 2023 by gt14rider 1 Share this post Link to post Share on other sites
peter lena 9,821 #11 Posted April 5, 2023 @gt14rider , never had any issues with those on my horses, found that detailing in and lubricating levers , as well as adding heim joints where ever I want to , makes for an effortless movement area , never wore out any since the upgrade . all 3 of my horses have the same improvement mod . just what I wanted , greasy pete Share this post Link to post Share on other sites
Wild Bill 633 931 #12 Posted April 6, 2023 On 4/2/2023 at 7:23 PM, Bill D said: Noalox compoun FYI, apparently not to be used on aluminum. Share this post Link to post Share on other sites
Bill D 2,713 #13 Posted April 6, 2023 5 hours ago, Wild Bill 633 said: FYI, apparently not to be used on aluminum. Noalox is specifically for aluminum conductors. It's a requirement when installing meter pans and electric panels to prevent oxidation on aluminum conductors. It's also used when making connections between copper and aluminum conductors. Ideal products makes it. Please check their website for more information. 2 Share this post Link to post Share on other sites
Wheelhorse#1 1,902 #14 Posted April 6, 2023 6 hours ago, Bill D said: Noalox Its also commonly use for aluminum to copper connections, or pigtailing electrical connections . Share this post Link to post Share on other sites
pfrederi 20,178 #15 Posted April 7, 2023 NoAlOx No Aluminum Oxidation 1 Share this post Link to post Share on other sites
Bill D 2,713 #16 Posted April 7, 2023 (edited) 2 hours ago, pfrederi said: NoAlOx No Aluminum Oxidation Even though the pins aren't aluminum, I can't see any reason why it wouldn't prevent oxidation and enhance the electrical connections in the 9 pin connector and other electrical connections found on our machines. Edited April 7, 2023 by Bill D 1 Share this post Link to post Share on other sites
