SylvanLakeWH 32,591 #1 Posted March 10, 2023 (edited) The Popeye Arm is getting old and stiff doing snow with the manual lift... So... Proof of concept using a HF winch... Still working on the details but it works... The winch plate attaches to the 2" hitch. Edited March 10, 2023 by SylvanLakeWH 4 7 Share this post Link to post Share on other sites
Pullstart 71,281 #2 Posted March 10, 2023 The snow plow for the Senior has a series of pulleys to lift from the front, via energy at the rear. If you have cable enough and I ASSUME you do, you can mount the winch anywhere if that becomes in the way.. 1 1 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #3 Posted March 11, 2023 How does this effect downward pressure? I always figured that a cable system to lift the blade would allow the blade to ride up. 2 Share this post Link to post Share on other sites
SylvanLakeWH 32,591 #4 Posted March 11, 2023 1 minute ago, elcamino/wheelhorse said: How does this effect downward pressure? I always figured that a cable system to lift the blade would allow the blade to ride up. I don't use / have down pressure. I don't use a solid link and I have not had any issues on the 3 concrete drives I plow... I haven't used it yet to plow but it should have no impact. I'm still working out wires, switch placement etc. 16 minutes ago, Pullstart said: The snow plow for the Senior has a series of pulleys to lift from the front, via energy at the rear. If you have cable enough and I ASSUME you do, you can mount the winch anywhere if that becomes in the way.. It seems to have adequate lift. I wanted it on the 2" receiver plate so I can move it around easily... I just put an eyebolt in the bottom of the plow and hook onto that... works pretty well... 2 Share this post Link to post Share on other sites
c-series don 12,477 #5 Posted March 11, 2023 @SylvanLakeWHThis might be a dumb question but can that tractor but can that tractor be converted to electric lift? 1 Share this post Link to post Share on other sites
CCW 1,519 #6 Posted March 11, 2023 Blade lifting is one of the things I had in mind when mounting my winch. 3 Share this post Link to post Share on other sites
SylvanLakeWH 32,591 #7 Posted March 11, 2023 (edited) 1 hour ago, c-series don said: @SylvanLakeWHThis might be a dumb question but can that tractor but can that tractor be converted to electric lift? I don't know... Never any experience with them... I go with what's in my garage "inventory "... and i don't have one of those... It's just an 12 v connection so i don't see why not... Anyone know? How about some pics if so... I have this one hooked up to my auxiliary horn / lights battery... so it's not stealing power from my three drive batteries... I have 2 E-141's...so could do one of each... Edited March 11, 2023 by SylvanLakeWH 3 Share this post Link to post Share on other sites
peter lena 10,075 #8 Posted March 11, 2023 @SylvanLakeWH looks interesting , get some cable lubricant in that cable . every time it flexes it will pull in the lube , stopping rust and keeping the cable supple . pete 3 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,591 #9 Posted March 11, 2023 (edited) 2 minutes ago, peter lena said: @SylvanLakeWH looks interesting , get some cable lubricant in that cable . every time it flexes it will pull in the lube , stopping rust and keeping the cable supple . pete Great suggestion! Recommendation on type / brand? I use WD 40 on my power drain snake cable, but that is to 1) displace the water and 2) it's stored in a dry basement... Edited March 11, 2023 by SylvanLakeWH Share this post Link to post Share on other sites
peter lena 10,075 #10 Posted March 11, 2023 @SylvanLakeWH did a lot of winch maintenance in the N G , always drew them out full length . and did the cable lubrication soak down as it was pulling the truck forward as the cable wound itself on it was twisting in the lubrication . also did related pulleys , connection points . pete 1 Share this post Link to post Share on other sites
peter lena 10,075 #11 Posted March 11, 2023 @SylvanLakeWH https://www.zoro.com/crc-chute-lubricant-aerosol-can-20-oz-03204/i/G0527073/? search around for best price . but a specific cable lube , will stay with it , pete 1 Share this post Link to post Share on other sites
Achto 32,790 #12 Posted March 11, 2023 55 minutes ago, SylvanLakeWH said: I don't know... Never any experience with them. Maybe you could add a 12v linear actuator to the rock shaft. https://www.amazon.com/linear-actuator-12v/s?k=linear+actuator+12v 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,591 #13 Posted March 11, 2023 17 minutes ago, Achto said: Maybe you could add a 12v linear actuator to the rock shaft. https://www.amazon.com/linear-actuator-12v/s?k=linear+actuator+12v Hhhmmm... aren't those for the rear implements? or will they work for the front blade...? if so, how? Share this post Link to post Share on other sites
Achto 32,790 #14 Posted March 11, 2023 Just now, SylvanLakeWH said: will they work for the front blade...? if so, how? Would have to hook it to the rock shaft (the same one that the lift handle moves) Not the best pic but the actuator would basically do the same job as the hydraulic ram on my Raider. 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,591 #15 Posted March 11, 2023 I see... Might look at that for E-141 number 2... The winch on a 2" hitch appealed to me because 1) i had it and 2) it can be used elsewhere easily... I do like the fit of the actuator though... looks slick...! 2 2 Share this post Link to post Share on other sites
c-series don 12,477 #16 Posted March 11, 2023 18 minutes ago, Achto said: Would have to hook it to the rock shaft (the same one that the lift handle moves) That’s what I’m talking about, like the one that came factory on a 418-8. Hooks to the rock shaft and does the same thing any hydraulic or manual lift would do. 4 Share this post Link to post Share on other sites
ebinmaine 80,756 #17 Posted March 11, 2023 Excellent work here Jim. On that linear actuator, as long as the actuator has NO direct contact with the plow it would work great. The lift section would need to be a chain/cable NOT a solid link. The actuators, for the most part, aren't made to take the sudden strains of a working plow. 1 3 Share this post Link to post Share on other sites
Ed Kennell 47,396 #18 Posted March 11, 2023 Hey Jim, Feel I should share a problem I found years ago when I mounted a wheel horse plow on my Yammy 4 wheeler. I used a RC HF winch to lift the plow and was not able to control the winch overrun and broke a few eyebolts before I installed a heave spring in the lift cable. You can also see a lever that pulls the blade locking pin when the plow is raised allowing the blade angle to be changed. 2 2 1 Share this post Link to post Share on other sites
wallfish 20,618 #19 Posted March 11, 2023 (edited) 11 hours ago, SylvanLakeWH said: if so, how? Without a doubt you should use a spring like Ed posted for the link to the plow frame when using a winch Edited March 11, 2023 by wallfish 4 1 Share this post Link to post Share on other sites
peter lena 10,075 #20 Posted March 11, 2023 @Achto @SylvanLakeWH @ebinmaine like those actuators , if I were to use one , would consider a seperate , bracket to secure its pull , as well as a chain link set up . @Ed Kennell has the right spring set up , let that take the sudden pick up , at a much softer rate , avoiding stress shock. not having an electrical lift , have experimented a lot with spring balance point . glad to see you guys looking for a better way to do a regular function , better watch out , you are heading into my trend of thought , going rogue , pete 2 ACHTO 2 1 Share this post Link to post Share on other sites
Ed Kennell 47,396 #21 Posted March 11, 2023 14 hours ago, SylvanLakeWH said: The Popeye Arm is getting old and stiff Everyone realizes the value of a hydro and hydo lift....Some of the tougher operators just take longer. 2 1 1 Share this post Link to post Share on other sites
wallfish 20,618 #22 Posted March 11, 2023 The old school type connected to the rear axle trans support. 3 1 Share this post Link to post Share on other sites
peter lena 10,075 #23 Posted March 11, 2023 @wallfish been experimenting with springs for a long time , this is just about right for me , probably cuts lift wt in half , still allows for self plowing , without arm assist . pete @Achto @SylvanLakeWH @ebinmaine like those actuators , if I were to use one , would consider a seperate , bracket to secure its pull , as well as a chain link set up . @Ed Kennell has the right spring set up , let that take the sudden pick up , at a much softer rate , avoiding stress shock. not having an electrical lift , have experimented a lot with spring balance point . glad to see you guys looking for a better way to do a regular function , better watch out , you are heading into my trend of thought , going rogue , pete 2 ACHTO 2 Share this post Link to post Share on other sites
c-series don 12,477 #24 Posted March 11, 2023 @ebinmaineEric that’s a good point you bring up about the shock load on a linear actuator, I never thought of that! @wallfish looks like that actuator is on a C-series? I have one of those and never installed it thinking it was for a late sixties tractor? Is that just for the rear implements or does it somehow work with the rock shaft? Do you have anymore pictures? Sorry for all the questions, too much coffee this morning and now I want to go install this actuator on one of my C-series!!!! Thx 1 1 Share this post Link to post Share on other sites
wallfish 20,618 #25 Posted March 11, 2023 (edited) 7 minutes ago, c-series don said: @ebinmaineEric that’s a good point you bring up about the shock load on a linear actuator, I never thought of that! @wallfish looks like that actuator is on a C-series? I have one of those and never installed it thinking it was for a late sixties tractor? Is that just for the rear implements or does it somehow work with the rock shaft? Do you have anymore pictures? Sorry for all the questions, too much coffee this morning and now I want to go install this actuator on one of my C-series!!!! Thx That's a pic off the net. BUT .. They connect to the rock shaft and are used just like a hydraulic ram. The rock shaft has an arm attached instead of a handle. The rock shaft part was part of the kit that swapped with the handle but making one from a handle type isn't too difficult. Basically cut off the handle and weld on a piece of flat stock with holes to connect the actuator. I might have that factory piece here to get some pics if we can't find any on the net Edited March 11, 2023 by wallfish 1 2 Share this post Link to post Share on other sites
