John c 136 #1 Posted March 3, 2023 Any of you guys have any tips, or pointers on getting the PTO bearing out for clean and new grease service ? thanks 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,901 #2 Posted March 3, 2023 (edited) A press would be the best way I believe.I didn't have access to one so I used homemade tool, all thread and thick fender washers and nuts to tighten down to pull the bearings out, if that makes sense. I'll see if I have a pic somewhere. I replaced mine but you can grease them if not too worn once you get them out.I would just relace their not very expensive. Edited March 3, 2023 by Wheelhorse#1 1 Share this post Link to post Share on other sites
Ed Kennell 44,823 #3 Posted March 3, 2023 You have any advice Mr. Grease ? @peter lena Share this post Link to post Share on other sites
squonk 45,481 #4 Posted March 3, 2023 (edited) @rmaynardhad a nice write up on removing /installing the bearing Edited March 3, 2023 by squonk 1 Share this post Link to post Share on other sites
peter lena 9,758 #5 Posted March 3, 2023 @Ed Kennell think I used a thin brass drift punch to get that bearing going , also liked the thread rod for installation . since using the correct lubricant in every related bearing , its a seamless / smooth / quiet function. pete Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,992 #6 Posted March 3, 2023 I would not remove the bearing to grease it. That would likely destroy it. Wash it up best you can and follow up with a spray of brake dry clean and let it dry. That will allow the new grease to stick to the rollers. Work it into rollers until full and no more. 3 Share this post Link to post Share on other sites
Handy Don 15,898 #7 Posted March 3, 2023 20 minutes ago, gwest_ca said: I would not remove the bearing to grease it. That would likely destroy it. Wash it up best you can and follow up with a spray of brake dry clean and let it dry. That will allow the new grease to stick to the rollers. Work it into rollers until full and no more. Fully agree on this. Removing a needle bearing from a blind holder without a removal-specific tool is pretty much certain to ruin the bearing. And even with the tool, it’s a gamble. 1 Share this post Link to post Share on other sites
John c 136 #8 Posted March 3, 2023 I was planning on a wash out and putting back new grease, anybody have a write up on taking the PTO apart ? While I'm in there I was going to try my hand at popping the seal out of the sealed bearing too and give it a wash out/regrease 2 Share this post Link to post Share on other sites
oliver2-44 11,211 #9 Posted March 3, 2023 2 hours ago, gwest_ca said: I would not remove the bearing to grease it. That would likely destroy it. Wash it up best you can and follow up with a spray of brake dry clean and let it dry. That will allow the new grease to stick to the rollers. Work it into rollers until full and no more. Share this post Link to post Share on other sites
squonk 45,481 #10 Posted March 3, 2023 1 hour ago, John c said: While I'm in there I was going to try my hand at popping the seal out of the sealed bearing too and give it a wash out/regrease That bearing is $6.50 at Napa. # PP204RR6 Hardly worth the effort to tear it open, cleaning it, Packing grease back in and trying to get the seal back in so it stays there. 1 2 Share this post Link to post Share on other sites
John c 136 #11 Posted April 11, 2023 so the small sealed bearing held in with the snap ring, does that just tap out with a drift punch and ball pein, or is it need a hyd press to get it out ? Share this post Link to post Share on other sites
Marv 994 #12 Posted April 11, 2023 John, Here is what I do Marv PTO Bearings Replace Pictorial Share this post Link to post Share on other sites
John c 136 #13 Posted April 12, 2023 nothing there Marv ?? Share this post Link to post Share on other sites
lynnmor 8,615 #14 Posted April 12, 2023 23 hours ago, John c said: so the small sealed bearing held in with the snap ring, does that just tap out with a drift punch and ball pein, or is it need a hyd press to get it out ? You should be able to tap it right out. When installing the new one, do not drive it in by the center race, you can use a socket or pipe that only contacts the outer race. Share this post Link to post Share on other sites
peter lena 9,758 #15 Posted April 12, 2023 @John c done this on all horses , main thing for me is the hi temp grease , on the rubber side shield bearings , and the inner pto needle bearing , the outer bearing # pp204 RR6 is available at auto parts , like to verify what the lubricant is but for the money an outer pto bearing is an easy swap .would use lucas grease , the marine grease is available Walmart for $ 7.50 big tube , very hi temp / stress rating is what you want , very light coating on the inner needle bearing , those mule drive bearings are cake to pop off seals , clean out , brake cleaner flush , repack same amount , put seals back on . anything thing you can do to reduce that collective drag , makes things better , also did all my mower decks . those original spindle bearings , are used in ceiling fans , with the correct grease they stand up to heat and angular stress . also put a heim joint on my pto lever clutch end , solid/ smooth , pete Share this post Link to post Share on other sites
Marv 994 #16 Posted April 13, 2023 John, look here Marv 1 Share this post Link to post Share on other sites
