Clarence T. Nolley Jr 14 #1 Posted February 25, 2023 Hello: this is Clarence i have a wheelhorse C160 and need to know if a belt guard off of a B100 wil fit my C160,please reply back iam planning on purchasing one soon. thanks. 1 Share this post Link to post Share on other sites
Ed Kennell 47,268 #2 Posted February 25, 2023 Hi Clarence, I suspect they are not the same. To positively confirm this, you will need the model numbers of both tractors to determine if the part numbers are the same. Many factors can determine the design of the belt guards. Wheel base length, Type of transmission,hydro,3 speed, 6 speed, 8 speed, etc. 4 Share this post Link to post Share on other sites
953 nut 69,164 #3 Posted February 25, 2023 I think @ebinmaine can answer this question, think he has both. 2 Share this post Link to post Share on other sites
ebinmaine 80,653 #4 Posted February 26, 2023 40 minutes ago, 953 nut said: I think @ebinmaine can answer this question, think he has both. Only the C160s here Richard. Perhaps @Pullstart ? Who has the "B160" that's their own build? 1 Share this post Link to post Share on other sites
Pullstart 71,216 #5 Posted February 26, 2023 2 minutes ago, ebinmaine said: Only the C160s here Richard. Perhaps @Pullstart ? Who has the "B160" that's their own build? @Racinbob? 1 1 Share this post Link to post Share on other sites
ebinmaine 80,653 #6 Posted February 26, 2023 8 minutes ago, Pullstart said: @Racinbob? I believe that's who I was thinking of 1 Share this post Link to post Share on other sites
Lee1977 7,764 #7 Posted February 26, 2023 (edited) If it's they are 1976 or 1977 models they are the same if both are 8 speeds. Both parts are 105391. There may be other models that are the same but we need year and model to check. Edited February 26, 2023 by Lee1977 1 Share this post Link to post Share on other sites
Racinbob 13,135 #8 Posted February 26, 2023 (edited) Yup, I'm guilty. I bought a 1976 B-80 brand new and shortly thereafter converted it. I removed the B-80 tower decals with the intentions of getting B-160 decals but still haven't done it. That is correct. The B's and C's shared the same belt guards in 76 and 77. The bolt that goes into the engine block on the big blocks is 7/16" while the small block bolt is 3/8". @Clarence T. Nolley Jr go ahead and get that belt guard if the tractors are either of those years. The earlier B's were shorter and the later B's were lawn tractors. Also keep in mind that the hydros used a different belt guard that the 8-speeds but can be converted. Edited February 26, 2023 by Racinbob 2 1 Share this post Link to post Share on other sites
Clarence T. Nolley Jr 14 #9 Posted February 26, 2023 Thanks gentlemen i looked at the identification tag that he had posted on the listng and it 61-10K802-*1604 second number 6116 what does these numbers mean ?. 1 Share this post Link to post Share on other sites
ebinmaine 80,653 #10 Posted February 26, 2023 9 minutes ago, Clarence T. Nolley Jr said: Thanks gentlemen i looked at the identification tag that he had posted on the listng and it 61-10K802-*1604 second number 6116 what does these numbers mean ?. Take that 10K802 out the middle there n search it. Comes with a list that contains this: I'm not sure a C1x1 belt guard is compatible with a C160. What's the need for the belt guard anyway? 1 Share this post Link to post Share on other sites
Lee1977 7,764 #11 Posted February 26, 2023 (edited) 1 hour ago, ebinmaine said: Take that 10K802 out the middle there n search it. Comes with a list that contains this: I'm not sure a C1x1 belt guard is compatible with a C160. What's the need for the belt guard anyway? EB they made 4 runs of building B-100 in 1976 - 801 ,802, 803, and 804.. The belt guard will fit it's the same number part if his C-160 is a 76 or 77 model. Edited February 26, 2023 by Lee1977 2 Share this post Link to post Share on other sites
Racinbob 13,135 #12 Posted February 26, 2023 Looking at the 61-10k802 the 61 tells you it's a 1976, the 10k says 10hp Kohler. The last three numbers are runs. Anything different in those is insignificant. The transmissions were either a 5091 or 103907. Doesn't matter, they are the same. The different numbers may mean something like a drain plug difference, switching to a different numbering system or..................just doesn't matter. The belt guard on a 61-10k802 WILL fit on a C160 8-speed. Same part. 5 Share this post Link to post Share on other sites
Clarence T. Nolley Jr 14 #13 Posted February 26, 2023 Racinbob thanks for your reply,iam seeing the same thing with this belt guard,it looks the same as the belt guard shown in the listing. thanks. 1 Share this post Link to post Share on other sites
