ebinmaine 80,471 #26 Posted November 29, 2022 Why does the detent piece behind the shifter not contact? It appears that the shifter is in place correctly and it isn't terribly worn, if at all. Are there spacers missing or is the detent piece bent.....? 3 Share this post Link to post Share on other sites
ebinmaine 80,471 #27 Posted November 29, 2022 Wiring harness, dash, cables out. PTO arm and linkage removed. Likely that won't go back on. Got the frame and transmission separated. 7 Share this post Link to post Share on other sites
ebinmaine 80,471 #28 Posted November 29, 2022 Also got ahold of @Vinylguy Terry to talk about some slightly custom decals. 2 4 Share this post Link to post Share on other sites
PeacemakerJack 11,039 #29 Posted November 30, 2022 On 11/28/2022 at 7:47 PM, ebinmaine said: No waiting on this one brother man. Trina and I are aiming to have it drivable by year end. That’s the spirit! You guys are attacking this thing with veracity and determination. Me thinks “the Bear” wants to have it functional for snow removal this season…🤔🤔🤔 1 1 Share this post Link to post Share on other sites
Achto 32,557 #30 Posted November 30, 2022 Is it ok If I come along on this journey? 1 2 Share this post Link to post Share on other sites
ebinmaine 80,471 #31 Posted November 30, 2022 6 hours ago, PeacemakerJack said: That’s the spirit! You guys are attacking this thing with veracity and determination. Me thinks “the Bear” wants to have it functional for snow removal this season…🤔🤔🤔 Yessir!! Trina can toss a plow on her 867 Pigpen anytime. We also have the Ariens walk behind snowblower. And of course there's my Cinnamon Horse C160-8. I can use a 48" plow on the manual lift just fine. But the BIG 60" @wallfish-built plow w/ skid steer cutting edge & Hydro lift. THAT'S a snow mover. TBH there's no real NEED to have this tractor done by a specific time... Well..... I can't let her have ALL the plowing fun!!! The Local Restoration Department BBT person is all over getting this Automatic back on the active duty list!! 23 minutes ago, Achto said: Is it ok If I come along on this journey? Absolutely! Glad to have ya. Pull up a 🪑. Have you a ☕. 3 2 Share this post Link to post Share on other sites
Horse Newbie 7,405 #32 Posted November 30, 2022 21 hours ago, ebinmaine said: Why does the detent piece behind the shifter not contact? It appears that the shifter is in place correctly and it isn't terribly worn, if at all. Are there spacers missing or is the detent piece bent.....? Is that detent piece designed to hold the lever in a certain position?- somewhere between all the way in one notch or the other ? 1 Share this post Link to post Share on other sites
ebinmaine 80,471 #33 Posted November 30, 2022 2 minutes ago, Horse Newbie said: Is that detent piece designed to hold the lever in a certain position?- somewhere between all the way in one notch or the other ? I'd say it's to indicate by feel of the lever when you're in neutral. See the blue circled part. There's an indent in the piece. It just isn't contacting the shift lever there. 1 Share this post Link to post Share on other sites
squonk 48,003 #34 Posted November 30, 2022 It's just tin, BEND IT! 4 Share this post Link to post Share on other sites
ebinmaine 80,471 #35 Posted November 30, 2022 I'm putting a link to a thread here for my own notes. Very good idea. Share this post Link to post Share on other sites
ebinmaine 80,471 #36 Posted November 30, 2022 4 minutes ago, squonk said: It's just tin, BEND IT! That's what I figured to do. I just wanted to make sure I didn't mess up the correct function. 2 Share this post Link to post Share on other sites
Horse Newbie 7,405 #37 Posted November 30, 2022 55 minutes ago, squonk said: It's just tin, BEND IT! 3 Share this post Link to post Share on other sites
ebinmaine 80,471 #38 Posted November 30, 2022 I got the pressure washer out and hooked up. Frame and steering wheel tower sprayed on the top side only with HALF BOTTLE of Pink Stuff degreaser. Let it sit for a bit, then sprayed it down with hot 🔥 high pressure. Flip frame. Spray degreaser. Rinse. Repeat. Got the frame cleaned up nicely and even gave the snowblower tractor a little rinse. 3 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #39 Posted November 30, 2022 1 minute ago, ebinmaine said: I got the pressure washer out and hooked up. Frame and steering wheel tower sprayed on the top side only with HALF BOTTLE of Pink Stuff degreaser. Let it sit for a bit, then sprayed it down with hot 🔥 high pressure. Flip frame. Spray degreaser. Rinse. Repeat. Ummm... ??? Don 2 Share this post Link to post Share on other sites
ebinmaine 80,471 #40 Posted November 30, 2022 55 minutes ago, Snoopy11 said: Ummm... ??? Don Here ya be. 3 3 Share this post Link to post Share on other sites
Snoopy11 5,731 #41 Posted November 30, 2022 Tractor on the carpet so its feet don't get cold, aye Eric...? Don 1 1 Share this post Link to post Share on other sites
ebinmaine 80,471 #42 Posted November 30, 2022 Just now, Snoopy11 said: Tractor on the carpet so its feet don't get cold, aye Eric...? Don Yes. Don. Tractors don't have slippers. 4 Share this post Link to post Share on other sites
oliver2-44 11,717 #43 Posted November 30, 2022 45 minutes ago, ebinmaine said: Yes. Don. Tractors don't have slippers. But @ebinmaine your C160 hydro tractor does have slippers!..... 3 1 Share this post Link to post Share on other sites
ebinmaine 80,471 #44 Posted November 30, 2022 1 minute ago, oliver2-44 said: But @ebinmaine your C160 hydro tractor does have slippers!..... Ya know. ..... That is true.... Some are inside the transmission. Some are not. 8 Share this post Link to post Share on other sites
Blasterdad 3,167 #45 Posted November 30, 2022 4 hours ago, ebinmaine said: Is your snowblower belt tensioner on upside down on purpose? 3 1 Share this post Link to post Share on other sites
ebinmaine 80,471 #46 Posted November 30, 2022 15 minutes ago, Blasterdad said: Is your snowblower belt tensioner on upside down on purpose? I dunno. I didn't install it. Thanks for the link though. 🙂 5 Share this post Link to post Share on other sites
ebinmaine 80,471 #47 Posted December 1, 2022 Can you folks tell me where to get gaskets for the transmission? Looks like 3 or 4 between case/pump/endplates etc?? Share this post Link to post Share on other sites
ebinmaine 80,471 #48 Posted December 2, 2022 I got the seat separated from the fender pan. Rear light off that too. Motion control lever plastic handle is off. Removed a few more stickers/decals. I did more scraping and cleaning on the frame. Trina started sanding some of it. On past restorations we've known we wouldn't be using a lot of the small parts so we just put a pile set aside. I've been trying to be a little better organized with disassembly on this one. I've already done a few mechanical repairs and I'm keeping those parts in separate boxes and bags. Influence/blame/teachings of @JCM Jim and others... 2 1 Share this post Link to post Share on other sites
RandyLittrell 3,945 #49 Posted December 2, 2022 On 11/28/2022 at 7:45 PM, ebinmaine said: We're thinking about sanding off a bit then add filler primer to help smooth it out. If they only blew some shiney paint on it, might be best to at least DA it down till you know it will hold. Randy 1 Share this post Link to post Share on other sites
RandyLittrell 3,945 #50 Posted December 2, 2022 Looking good Eric!!! I would love to find a C-160 auto at the right price and at the right time. There is one close right now, but a bad time to buy a tractor!! Randy 1 Share this post Link to post Share on other sites
