Panther416-8 342 #1 Posted September 22, 2022 So I put a new carb on the 16 horse Kohler Magnum and now I have an issue with the throttle lever. As it is running the lever keeps moving down by itself, it doesn't stay in the high position. I had no issues with it before replacing the carb. Any ideas what to look for? The clamp that holds both the choke and throttle cables in the front of the engine is tight. 3 Share this post Link to post Share on other sites
Snoopy11 5,731 #2 Posted September 22, 2022 Can we have some pictures of your setup? Side question (just in case) Do you have any little springs in stock @Panther416-8? Ones like this... Don 3 Share this post Link to post Share on other sites
The Freightliner Guy 1,364 #3 Posted September 22, 2022 Does it have enough tension or to little tension 1 Share this post Link to post Share on other sites
pfrederi 21,303 #4 Posted September 22, 2022 If the throttle handle moves very easily take it out give the pivot a couple whacks with a hammer while blocked against something ...or drill it out use a bolt and nylock nut 3 2 Share this post Link to post Share on other sites
peter lena 10,107 #5 Posted September 22, 2022 @Panther416-8 after freeing up my throttle / choke cables , using SUPER LUBE OIL , in the cables and related linkage , use some perforated steel on existing mount spots to add light spring pull on the cable . lever areas , EXPERIMENT FOR EFFECT , did that on 1 kohler magnum, soon adapted it to all 3 . cables / levers , do not creep , solid / smooth . pete 1 2 Share this post Link to post Share on other sites
c-series don 12,656 #6 Posted September 22, 2022 My 416-H does the same thing. I tried squeezing the pivot point with vice grips but it didn’t help. I’ll have to try @pfrederi’s idea and take it out and smashing it! 1 1 Share this post Link to post Share on other sites
peter lena 10,107 #7 Posted September 22, 2022 @Snoopy11 sounds wrong , but those springs actually assist closing those cables , as I experimented with them , the best effect was on the pull to close side . cables and related levers and movement points were lubrication smooth with action . just went back and forth with engine off function , started up , and it was like magic , smooth easy response , and zero throttle closure , years and lots of hours , still good. pete 1 1 Share this post Link to post Share on other sites
pacer 3,181 #8 Posted September 22, 2022 I suspect @pfrederi solution will be what you will end up having to do. It works strictly on friction and with age it slowly loosens. Hopefully a "whack" will tighten it up, but just may have to put a bolt/washers there. 3 Share this post Link to post Share on other sites
Handy Don 17,674 #9 Posted September 23, 2022 On 9/22/2022 at 3:36 PM, pacer said: I suspect @pfrederi solution will be what you will end up having to do. It works strictly on friction and with age it slowly loosens. Hopefully a "whack" will tighten it up, but just may have to put a bolt/washers there. I'm a fan of a shoulder bolt, flat washer, and nylock nut (with all the original washers and spacers in their original positions). The shoulder keeps the pivoting lever and bracket from getting worn by the sharp threads and the nut lets you adjust the friction to your liking easily. 2 1 Share this post Link to post Share on other sites
Rick3478 477 #10 Posted September 24, 2022 On 9/22/2022 at 1:24 PM, c-series don said: My 416-H does the same thing. I tried squeezing the pivot point with vice grips but it didn’t help. I’ll have to try @pfrederi’s idea and take it out and smashing it! I've used the vice grip method myself with success. You have to use a large one to get enough mash on the rivet. The advantage is that you don't have to take anything apart. Bolt & nut is probably best long term. 5 Share this post Link to post Share on other sites
Bill D 3,193 #11 Posted September 24, 2022 I've used a grade 8 bolt and nylock nut or all steel lock nut. I also replaced the fiber friction washers with plastic washers. The original fiber washer broke. 2 Share this post Link to post Share on other sites
Handy Don 17,674 #12 Posted September 24, 2022 16 hours ago, Bill D said: replaced the fiber friction washers with plastic washers The friction washers are an essential part of the function, for sure. 1 Share this post Link to post Share on other sites
Bill D 3,193 #13 Posted September 24, 2022 39 minutes ago, Handy Don said: The friction washers are an essential part of the function, for sure. Plastic washer seems to be working fine so far. 1 Share this post Link to post Share on other sites
Handy Don 17,674 #14 Posted September 24, 2022 2 hours ago, Bill D said: Plastic washer seems to be working fine so far. Not surprised, though some "slippery" plastics would likely need extra tension. 1 Share this post Link to post Share on other sites
Panther416-8 342 #15 Posted September 25, 2022 I drilled out the large rivet as per @pfrederi using a 1/4" bit , kept the fiber washers and used a bolt and nylon lock nut. Works perfectly now, stays wherever i set it. Thanks all for the suggestions. 2 1 Share this post Link to post Share on other sites
peter lena 10,107 #16 Posted September 25, 2022 @Panther416-8 looks like a simple fix to me , as with anything I go after to repair / fix look at total function , anything / everything that's part of intended set up . another thing I do , is to go after cable lay out , put it where it wants to be , any forcible bend , stiff spot will effect slide. add a few cable clips , to mounting spots , super lube oil . notice your battery ground rail , next to battery , good spot to tie into battery ground bolt point , for enhanced , verified electrical grounding . add a battery cable / or electrical lug , to trouble spot , headlights , rectifier , amp charging reaction , also a pto lever start spot that can be improved . pete 1 Share this post Link to post Share on other sites
OldWorkHorse 3,156 #17 Posted September 25, 2022 Have the same issue on my 314-8 throttle will slowly slide down to about 2/3 throttle. Been planning to fix it but havnt looked into it much, guess I found a solution and my next small project. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,533 #18 Posted September 25, 2022 The throttle cable increases the rpm. The governor tries to reduce the rpm. The faster the engine runs the more force the governor develops to reduce the throttle opening. That is why the throttle crepes back most at high rpm. 2 Share this post Link to post Share on other sites
kpinnc 19,060 #19 Posted September 27, 2022 My 520-H does the same thing. I never considered adding a bolt and nylock. That's a great idea, and I will be doing this myself! 2 Share this post Link to post Share on other sites
peter lena 10,107 #20 Posted September 27, 2022 @kpinnc local H/W store probably has small pull out drawer section with those slide washers , probably also has SUPER LUBE in a 6 oz bottle , made for cabling function. use that on all my cable / linkage / lever areas , pete 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,533 #21 Posted September 27, 2022 1 hour ago, kpinnc said: My 520-H does the same thing. I never considered adding a bolt and nylock. That's a great idea, and I will be doing this myself! Use a bolt with enough unthreaded shank to go all the way through the assembly plus a bit. Add flat washers to the outside so the nylock nut has room for future adjustment. You can reach in with two wrenches to adjust as necessary. 2 Share this post Link to post Share on other sites
Horse Newbie 7,405 #22 Posted September 27, 2022 (edited) On 9/22/2022 at 12:28 PM, pfrederi said: If the throttle handle moves very easily take it out give the pivot a couple whacks with a hammer while blocked against something ...or drill it out use a bolt and nylock nut Because my throttle knob did not want to come off easily and I was about to tear it up, and the fact that to drill it out you have to probably take the throttle lever mechanism completely out to drill it, I reached in there with some vice grips and squeezed the pivot rivet a little and that made it tight enough to where mine on my 520 H stays where I put it now… Edited September 27, 2022 by Horse Newbie 1 Share this post Link to post Share on other sites
peter lena 10,107 #23 Posted September 28, 2022 @Horse Newbie think most important thing you can do is to go over every intended movement point , what I do on cables is to unhook from carb , does it move easily / smoothly ? often cables were clamped down , where they do not want to be , loosen up hold downs , lubricate , if any binding is suddenly gone , you are on track with cable base setting. I go the opposite way of force , detail and enhance function . just an idea , pete 1 Share this post Link to post Share on other sites
