Matt Young
Ratchet strap fail
Matt Young
Last week I was hauling the c-121 back from my daughters softball practice (I used it to drag the diamond) and I made a right hand turn and stopped at the stop sign. As I made the left onto a non busy county road I watched in my right mirror as my horse decided it didn’t want to be trailered any longer. It rolled over 1 completely time and sat on its wheels. Unfortunately it broke some parts and tweaked the hood and deck lower-lift handle. I did manage to put it back on the trailer as a tripod and get it home. Always check your straps and rigging. Found the ratchet failed in my case. And unfortunately i cannot download a picture for this🤨
Edited by diddy78c
  • Sad 10
WHX??
Dan's @Achto  brother Tim had a freshly painted mint Ford come off at highway speed and made a mess of things. I think it's time for a refresher  thread on proper trailering & tie down techniques.
  • Like 4
CasualObserver
Bummer @diddy78c and thankfully no one was injured in this event.  It does highlight the importance of checking and re-checking straps as well as inspecting and replacing worn or broken ones.  And for those people who think one of those dinky little 1 inch ratchet straps made by the cheapest bidder will hold a tractor well enough, please reconsider. Always at least two straps. Redundancy.... two hold downs.  God and Gravity don't count when it comes to keeping stuff secured to a trailer or even in the back of a truck!
  • Like 8
Achto
Sorry to hear about your misfortune. Glad that there were no injuries. I use ratchet straps also but I shy away from "gadget straps" ( self retracting, no tag left to deal with, etc). Ratchets & straps are not the only things that can fail though. @WHX20 mentioned my brothers misfortune, the cause of his was a chain link that failed.
This pic was taken on Sun 7/22, right after we put it back together.
This one on Wed 7/25
Accidents can & will happen despite our every efforts. I hope yours is repairable @diddy78c
Edited by Achto
  • Sad 5
Matt Young
Definitely no fun, was he able to fix his
oldredrider
index(1).jpeg.eb967a4ad03c473aee9d7aa7d511618c.jpegAnd this BEFORE strapping down...
Edited by oldredrider
  • Sad 4
Achto
This happened last Wed. On the look out for parts yet - broken rear axle housing, grill, steering column, dash parts & the list keeps growing. I think he would be better off looking for a roller instead of trying to piece it back to gether.
Mike'sHorseBarn
This pic was taken on Sun 7/21, right after we put it back together.
I think that would almost bring me to tears. All that hard work and then something like that happens. Sickening.
peter lena
see a lot of those junk straps on the back of suv,s barely holding on to a bike, coming from cape cod you have to see the tie down arrangements securing bikes going to new York. I never follow those people, I use cam lock straps on rafts and anything else without issues. pete
rmaynard
Hey, and I wasn't even drinking when that happened.
  • Haha 8
squonk
I use at least 4 straps along with axle straps on every Horse that goes on the trailer.
  • Like 4
WHX??
Yes Dan's bro was using a piece of chain that was welded by dad many years ago but was used many times before that might have weakened it. Guess you should never use things that have been monkeyed with. Heck even cold shuts have been known to open
He also had it on a trailer behind his fit wheel camper so even worse he never knew it jumped off. He mentioned something about looking into those new fangled back up cameras to monitor. Not a bad idea.
On our way to the BS this year one of the safety chains came off the trailer hitch. These were even the good hooks with the safety spring over the hook. No idea how it came off but just goes to show ALWAYS check your rigging at gas stops and pee breaks.
Last couple of hauls I never evened tied down the horses but in an enclosed but maybe I should rethink my laziness. My open flatbed from work has sideboards and I didn't tie them down either thinking where they can go? They didn't move at all the way I had them wedged in. Should rethink that stupidness too.
Edited by WHX20
Matt Young
I have had these straps 6 years none failed until that day
Matt Young
On a positive note I did get an old c-175 last Saturday 😎
  • Excellent 2
953 nut
Any implements or small items like transmissions get hardwired to the trailer railing. Every :wh: gets at least two straps tied to cleats bolted to the deck.
19richie66
I think I had two 2" ratchet straps and three 1-1/2" ratchet straps holding Skittles on the trailer to and from the show this year. I found that all the bouncing around on the interstate loosened even these up. Every time I stopped for gas or break, I tightened them up. Never can have enough security. I hope you guys get everything repaired. Best of luck,Richie
  • Thanks 3
ebinmaine
Whether you guys are truck drivers like myself or not, I'm sure you're aware that there are minimum cargo retention laws placed by the federal government which are also over written by more strict or stringent laws by a lot of the states.
It sounds like those of you who use a lot of ratchet, (not pull to tighten!!), Type straps have definitely got your methods down and should be doing fine.
The company I work for focus is quite a bit on safety and trying to follow the rules most of the time and they actually require one additional strap on every unit than is required by the DOT. Sometimes this is a little challenging to accomplish but we do the best we can with what we have.
Please pay very very close attention to the working load limit or WLL that is on the tag of every single strap.
Rope is not legal.
Rubber cords are not legal.
  • Like 5
  • Excellent 2
Matt Young
Rope is not legal.
Sounds like you work for a similar company I did several years ago. I always try to look stuff over but apparently I missed it that day. But lessons learned no one was hurt, except the pocket book.
Stormin
  I have sides on my trailer and they give some peace of mind should anything come loose. I usually carry three tractors. All secured with ratchet straps front and rear. Tractor tyre sidewalls, front and rear, pulled up against the side.
  The roads up here are not the best and I check everything after the first 6 miles.
Matt Young
Finally got her back together!:woohoo:
  • Like 6
  • Excellent 2
cleat
Good to see she survived.
Keep her better strapped on from now on :auto-swerve:.
Cleat
  • Haha 1
Matt Young
Cleat
Will do upgrades to my aging ratchet straps
Mudrig150
One time when we were going to pick up one of my tractors the strap almost got tangled in the wheels of the trailer, and then the front pto cover, which has some SHARP edges almost flew off. We were on the highway for quite a while, so if that would've flown off, it definitely caused a crash or some form of damage.
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get a big diesel swap.
      Thanks,
      John
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • PWL216
      By PWL216
      About a year ago I bought a C-121 auto with the intention of using it as my go-to mower. Shortly thereafter I got a great deal on a low hour 314-8.  It ran perfect and had several attachments - it became my new go-to mower.  So, I decided to repurpose the 121 to be a front end loader. After purchasing the build plans from P.F Engineering (which are excellent), I realized I couldn’t build it for less than $2k in material. I decided to look for a used one and found a Thompson TC10 local to me, mounted on an “end of life” 1077, for $1,000.  The loader swap itself was pretty straight forward. The only modifications needed were drilling a couple of mounting holes in the tractor frame, grinding away a little of the loader top frame so the hood opened/closed and welding in a new hydraulic pump mount. I have a few things to button up still and the bucket itself needs attention but it’s fully functional. I also bought a pair of clamp-on pallet forks.
      I also did a “refresh” of the 121. The total project cost is shown below. Roughly $2,300, with just the FEL itself being around $1,300.
      Tractor
      C-121 Auto $500
      Solid engine mounts $50
      Front End Loader
      Johnson 10TC $1,000
      Hydraulic fluid $35
      Spare hydraulic hose $40
      Ignition
      Battery $35
      Battery cables $20
      Points & Condenser $20
      Fuel
      Carb & Gasket $65
      Electric fuel pump $60 (later removed)
      Air filter $10
      Fuel filter $15
      Fuel line $10
      Spark plug $5
      Decals and Paint
      Decals $115
      Paint $30
      Lights
      Headlight Lens $45
      LED Headlights $25
      Rear lights $25
      Misc $200
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
