porschpow
Hey Guys,
I have found out that I have a fast leak on the front  "drivers" side tire and a slower one on the rear "drivers" side tire.  Do you guys know where the best place to find tires (they're a bit worn), and tubes?
Not to mention, what is the best way to get them off the wheel?
Thank you in advance!
953 nut
If you have a Tractor Supply or Rural King near by they should have the tires and tubes. Any tire repair shop could mount them for you.
Dan693
Miller tire online has a ton of tires and tubes. Prices are good also. I also got some Hi-Run ags that I ordered through Walmart.
Harbor Freight sells a mini tire changer setup for like $40. You'll spend that or more at a tire shop.
FYI
Sarge
The last pair of ags I bought were for the front of Big Ugly (D180) - I went with the 18-8.50/8 stock size from BKT and so far have been very impressed with how well they are wearing despite that monster's weight and using a 56" blade with it , most of the nubs are still intact even working on rough rock surfaces . Think I picked those up off the auction site if I remember correctly and the price was great...
Sarge
96WS6TA
greater Cleveland tire!
  • Similar Content
    • Natejc_98
      By Natejc_98
      I’m looking for the recommended process to restore old wheels from grinding to sanding to painting. Also what tools are preferred in the process?
    • Tim's Toy Tractor
      By Tim's Toy Tractor
      Two 3 Rib Firestone Tires, 16x6.50-8, 2 of them mounted on OEM Wheel Horse Rims, NEW!
      These tires are New, Never Used! Not the cheap China ones, these are High Quality Firestone Tires!
      Great for any Garden Tractor or Riding Mower
      They are mounted on original Wheel Horse wheels that have been sandblasted & epoxied, and painted with ivory colored paint, note there are a few chips along the inside bead from mounting the tires. The rims will need your specific size wheel bearings installed.
      $99.00 Call Tim @ 1-313-460-8858        (Local Pick-Up Only, No Shipping)
    • Jon Paulsen
      By Jon Paulsen
      Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
      I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
      Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
    • PWL216
      By PWL216
      Are there aftermarket front rims available for C Series tractors? I have a 120 and a 160 that need front rims… thx.
    • MachXXII
      By MachXXII
      I’m trying to restore my grandfathers old 252-H to use around my property. The tires are shot and the rims aren’t too far behind. Anyone have any recommendations for rims and tires that would fit well on it?
      right now it has 22 x 7.50 - 12 on the back and 15 x 6 - 6 on the front.
