Horse46
Ceramic cylinder heads
I was watching a few Tube vids last night on governor set up and came across a guy who had fitted a ceramic head to his K341.
Q. Are they any good, are they expensive, where are they available from?
On a stock governed engine I see no advantages, but lots of disadvantages. My guess is he did it because he could....
  • Similar Content
    • By andrewLL
      Hi, and a happy Christmas to all.
      Looking for some advice here, a couple of years ago a bought a cheap K341AS on fleebay, the chap I bought it from said it would not run right and I think he mentioned breathing fire from the carb.  He replaced it on his black hood Wheelhorse with a ‘Chonda’ engine. Since then it has sat at the back of my garage but another recent fleebay purchase was a black hood C105 with new engine.  So time to do something, but not tomorrow! Turkey, but no sprouts is the order of the day.
      I thought as a start I should sort the engine out, but can’t easily test it until it can be mounted on the tractor.  I have started to strip it down and the oil is quite clean so hopefully it was looked after.  Now for a few questions:-
      The engine is painted grey but normally Wheelhorse have a red engine, could this be a rebuilt engine?, I guess the tractor it came off was mid 80’s so a possibility.
      When I took the head off it was all quite clean and only took a light brushing and some carb cleaner sprayed on to clean it up.  However the top of the piston is stamped with .003 and the block with +3.  What does this mean, I thought oversized pistons were plus ten, twenty and thirty thousandth.  Has this engine been rebored?
      Measuring  the valve gaps they are .013” inlet (.008 - .010”) and .020” out (.017 - .019”) is this enough out of tolerance to cause problems?  If so it should be an easy fix to get it going again.
      i am thinking of just buying a cheap replacement carb having had problems with a carb on my Raider (K301) after two rebuild kits it still leaked petrol and a replacement carb sorted it all (apart from stopping when v hot, see another post of mine)
      The bore of the cylinder is very clean and no scratches so hopefully no problems there.
      What do you think?
      i don’t seem able to upload pictures from my iPad, it says only allowed 30.7KB,  what’s going on? How do I sort it?
      Andrew
    • By midpack
      I have a K341 that gave up a rod a while back. talk about "Big Bang Theory..." anyway, I tore it down to see how bad it got inside and to my surprise other than the rod, and the very bottom of the piston skirts the inside looks great!
      the crankpin looked like it might have taken some abuse but i used a white stone (lightly) and some polishing paper and it must have been debris from the rod or piston because it came right off.
      i took some measurements and it does show some wear. the crankpin measures 1.498 to 1.499 (low limit is 1.499) and out of round a full .001 (spec calls for .0005 max)
      the bore measures .002 out of the wear limits and is out of round about .005. going to need a new piston anyway and i can bore it at work . no problem there.
      my question is, would you re-use the crank in that condition? I can't grind a crank at work...  lol
    • By Team70R
      Got the new Chinese carb on my k341 and I'm still having issues with it. When I open the throttle all the way with it not running everything opens as should but when it's running the throttle shaft on the carb only opens half way. As in the governer isn't functioning correctly or a spring is warn. It surges terribly and almost dies when you drive it. Definitely frustrating!!! Here's a video of it running.
      IMG_2755.MOV
    • By DorkFish
      Has anyone ever used one of these replacement Kohler carbs from Amazon?  Went ahead and ordered one for my 16 HP K341.  The throttle shaft on the old one has so much play that I'm surprised the thing even runs at all.  I've heard plenty of good reviews and also plenty of jeers claiming they are cheap and don't work as well.  Looks like an exact copy of the Kohler carb.  I guess we'll see for certain tomorrow when I get it put on...
    • By ztnoo
      Does any one know of a reference link to finding the weight of complete Kohler engines, in particular the K321 & K341?
      If you know of no electronic data about this topic, but have one of these on the bench and complete, could you somehow weigh it for the benefit of group knowledge.
      (Sneak the bath scales out to the garage if you can).
      I'd actually like to see a listing of weights for the entire Kohler K series, if anyone can contribute any piece of this puzzle.
      Regards,
      Steve
