Similar Content
By Duramax7man7
Very Solid tractor! Starts right up and Runs and Cuts like a Champ!
ONLY 419hrs
FEATURES:
Newer Agro Tires on Rear & Solid Front Turf Tires.
Wheel Weights on rear.
Fully Swapped Forward Swept axle and Steering off of 520h.
New Tractor Supply Adjustable Seat.
Exhaust Fully Restored. (Sandblasted, Outgassed and 2000deg High Temp Satin Exhaust Paint Coated.)
I ran my 60" Deck on this tractor for over a year with no issues.
Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
Asking >>>>> $1,099 OBO <<<<<<<
(248) 943-8634 Text or Call. God Bless.
By Duramax7man7
Very Solid tractor!
Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
$1175 OBO -POOS
(248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
By jmack
I’m looking for a transmission dipstick to a D-180. Let me know if you see one.
By Doug B
Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
By robertsonchris06@gmail.co
After using my 8-25 mower successfully for several years I noticed the belts were very worn. I replaced the belts and used the mower several mowings this past summer with no problems until as I was mowing the last time the mower would not move in any gear. After stopping and inspecting the traction belt it was almost completely destroyed. Prior to this I had noticed that the engage/disengage lever was getting hard to activate (very stiff). Has anyone had a similar thing happen?
Thanks in advance for any help on this problem.
Just want to keep my mower running.
Chris
