Jerryw77 7 #1 Posted August 30, 2022 I have a 1968 Commando 8 and the tiller I got a 141" belt it is a little long I have 7 -1252 model and serial is 145272 for tiller not sure if it will even work on my tractor . I have it close. My pto drive petal was coming back and binding the belt on foo rest so I added another pulley under and forward of petal foot rest. And I took double pulley off mower deck and installed where the normally go so I think if I put a pulley out front on frame of it should work better it works but under load it stops tiller. Share this post Link to post Share on other sites
Goldnboy 1,117 #2 Posted August 31, 2022 I recall correctly 141" is for twin cylinder engines and 139" is for the single cylinder engine. Shown is one of two mid idler styles which is what I use with a single cylinder engine Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,258 #3 Posted August 31, 2022 Is the Commando 8 not a medium frame 43-1/2" wheelbase tractor? I don't know if the belt may need to be shorter still. A tiller is not listed for the Commando 8 most likely because it does not have the low range in the transmission to slow down the ground speed. 1 Share this post Link to post Share on other sites
daveoman1966 3,883 #4 Posted August 31, 2022 As with mower decks, the V-BELT for the tiller is in the TILLER schematics. Your tiller model 7-1252 is an older model and the OEM drive belt for it is #1599. This belt is 139"L x 0.5"W. 1 Share this post Link to post Share on other sites
Jerryw77 7 #5 Posted August 31, 2022 22 hours ago, Goldnboy said: I recall correctly 141" is for twin cylinder engines and 139" is for the single cylinder engine. Shown is one of two mid idler styles which is what I use with a single cylinder engine bare with me this is my first wheel horse is that the pto setup that the petal runs? Or does that mount out front by front axle? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,258 #6 Posted September 2, 2022 This one is used with the manual or electic pto clutch. The belt goes straight up from the large idler pulley to the front of the pto pulley and then down to the flat idler and back to the tiller. Share this post Link to post Share on other sites
daveoman1966 3,883 #7 Posted September 2, 2022 Mid-tach-O-Matich hitch with Teller IDLER PULLEY ASSY installed. There are 3 or 4 variants to the Idler Pulley Assy, but they all attach in the same way. Share this post Link to post Share on other sites
peter lena 9,893 #8 Posted September 2, 2022 @daveoman1966 nice picture / description lay out , only thing I would change / upgrade is the pulley bearings , you cannot believe how easily those pulleys work / spin up with a bearing / lubricant change . once I made the change over , did that on , each / every belt driven pulley I have , also detailed in the pto lever rod function , smooth / easy / quiet pete 1 Share this post Link to post Share on other sites
