Forrest Carver 52 #1 Posted August 23, 2022 Hi there, can anyone recommend good quality aftermarket deck wheels and roller wheels? Mine are kind of tired. I saw some on Amazon but they looked chintzy Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,353 #2 Posted August 23, 2022 What is the part number of the originals? Share this post Link to post Share on other sites
Forrest Carver 52 #3 Posted August 24, 2022 5240 on the roller, 103665 on the wheel Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,353 #4 Posted August 24, 2022 5240 has been replaced by 94-1599 Some replacements https://www.rcpw.com/search/?quest=5240 103665 has been replaced by 110506 One alternate https://www.rcpw.com/search/?quest=103665 Share this post Link to post Share on other sites
Forrest Carver 52 #5 Posted August 24, 2022 Great, thank you for the help! Share this post Link to post Share on other sites
lynnmor 8,900 #6 Posted August 24, 2022 Be sure to replace the bolts or pins that these spin on, using severely worn parts will shorten wheel life. Grease the wheels often and they will last a long time. 1 Share this post Link to post Share on other sites
pacer 3,180 #7 Posted August 24, 2022 I think you will find what @lynnmor is describing..... the 'axles' will very likely be worse than the rollers. I weld/build up my own in the shop, but if you arent equipped for that, at least hunt up some long 1/2" bolts. Share this post Link to post Share on other sites
Lee1977 7,709 #8 Posted August 25, 2022 Cleat and I make ours. Share this post Link to post Share on other sites
Handy Don 16,948 #9 Posted August 27, 2022 (edited) On 8/25/2022 at 1:37 PM, Lee1977 said: Cleat and I make ours Same idea! The RM-325 and RM-365 through RM-327 and RM-367 series mower decks from '65 through '67 have their anti-scalp rollers very exposed to the grass cuttings. To prevent the shaft from spinning in (and wearing out) the bracket, they rely on the cotter pin through the shaft to engage a pin welded to the bracket. On mine, the cotters, pins, brackets and shafts were all in dire condition. Taking a cue from WH's pin technique for later front axles and for anti-scalp shafts on the larger decks, I ground off the remains of the pin, welded heavy washers to the brackets to overcome the wallowing, and made new ½" shafts with flags that I secured from spinning via drilled and tapped holes in brackets using a ¼" locking flange bolt. By the way, I've gotten new direct replacement gage wheels with solid bushings and grease zerks from http://a-ztractor.com/. Worth it to me considering the load that these wheels carry, especially on the larger decks over bumpy lawns. Edited August 27, 2022 by Handy Don 1 Share this post Link to post Share on other sites
