rjg854 12,630 #126 Posted August 1, 2022 I could be wrong but it looks like it's held on with a roll pin Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #127 Posted August 1, 2022 59 minutes ago, ebinmaine said: Agreed. Likely not bent but welded that way many many moons ago. I've had one or two come through my workshop that way. simple reweld then? 1 Share this post Link to post Share on other sites
Snoopy11 5,723 #128 Posted August 1, 2022 1 minute ago, josephbruce11212@gmail.co said: simple reweld then? That... or leave it as is... put on a small block Ford... and go run the Indy 500... Don 2 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #129 Posted August 1, 2022 20 minutes ago, rjg854 said: I could be wrong but it looks like it's held on with a roll pin It is held on by a roll pin. I will disassemble but once reinstalled I don't think that is the end with the issue...right? 1 Share this post Link to post Share on other sites
Snoopy11 5,723 #130 Posted August 1, 2022 17 minutes ago, josephbruce11212@gmail.co said: I don't think that is the end with the issue...right? I'm not entirely sure which end is the "issue"... but adjusting either end would fix it... I think... Don Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #131 Posted August 1, 2022 2 minutes ago, Snoopy11 said: I'm not entirely sure which end is the "issue"... but adjusting either end would fix it... I think... Don true, but with a roll pin already set through the shaft the hole in the shaft sorta becomes the "fixed" point? I could be over or under thinking this Share this post Link to post Share on other sites
ebinmaine 75,775 #132 Posted August 1, 2022 8 minutes ago, josephbruce11212@gmail.co said: true, but with a roll pin already set through the shaft the hole in the shaft sorta becomes the "fixed" point? I could be over or under thinking this You are correct IIFF none of the parts are worn out. Check the ends of the shaft where it would be riding in the bushings to make sure that it still measures at or close to stock size which I think is 3/4? If you already have a warrant out main shaft there's no point in disassembly and rewelding. That being the case it would be better to disassemble... then weld on a new piece. 1 1 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #133 Posted August 1, 2022 Best part of getting a new tractor, besides the tractor and working on the tractor......new tools!! 2 2 Share this post Link to post Share on other sites
rjg854 12,630 #134 Posted August 1, 2022 On my 854 I drilled for a larger size roll pin and that completed my fix, an easier way would be to set it where you want it and have it welded. 2 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #135 Posted August 1, 2022 2 hours ago, rjg854 said: On my 854 I drilled for a larger size roll pin and that completed my fix, an easier way would be to set it where you want it and have it welded. Good idea Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #136 Posted August 3, 2022 Got some of the small stuff primed....its getting there!! Wooooot! 2 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #137 Posted August 3, 2022 Can someone let me know what the 2 left side switches are? When I picked up the tractor it did have lights on the seat....but the 605 didn't have a battery 1 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #138 Posted August 8, 2022 (edited) I contacted the Delmont Apple Festival committee to see how I could show off my tractor....they responded promptly that they enjoy having anyone participate. Now to have this horse done by Sept.1st! Edited August 8, 2022 by josephbruce11212@gmail.co 2 1 Share this post Link to post Share on other sites
Ed Kennell 43,793 #139 Posted August 8, 2022 46 minutes ago, josephbruce11212@gmail.co said: Now to have this horse done by Sept.1st! Shouldn't be a problem to have it ready for the BIG SHOW in Arendtsville in June '23. We expect to see it there Joe. 1 1 Share this post Link to post Share on other sites
953 nut 63,046 #140 Posted August 8, 2022 On 8/3/2022 at 12:36 PM, josephbruce11212@gmail.co said: let me know what the 2 left side switches are? When I picked up the tractor it did have lights on the seat....but the 605 didn't have a battery Previous owners sometimes do things that just make you go Hmmmm..... 1 1 1 4 Share this post Link to post Share on other sites
ebinmaine 75,775 #141 Posted August 8, 2022 ⬆️⬆️⬆️⬆️⬆️⬆️⬆️ THAT. Is awesome. Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #142 Posted August 8, 2022 (edited) Did some painting today....Regal Red was the color of choice. Couldn't get the hitch off...it's on there good...painting with it on as best as possible. Edited August 8, 2022 by josephbruce11212@gmail.co 1 2 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #143 Posted August 8, 2022 Any advice on getting the shifter knob off? 1 Share this post Link to post Share on other sites
ebinmaine 75,775 #144 Posted August 8, 2022 53 minutes ago, josephbruce11212@gmail.co said: Any advice on getting the shifter knob off? Look around the base of the knob to see if the there's a set screw. 1 Share this post Link to post Share on other sites
Snoopy11 5,723 #145 Posted August 8, 2022 57 minutes ago, josephbruce11212@gmail.co said: Any advice on getting the shifter knob off? Eric could be right... @ebinmaine ...but all of the ones I have had screw off... I just get a good ape grip on in, give it a counter-clockwise grunt... and off it comes... Don 1 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #146 Posted August 8, 2022 44 minutes ago, ebinmaine said: Look around the base of the knob to see if the there's a set screw. Didn't see a set screw...pretty sure it's a twisty but man!! It's on there! 1 Share this post Link to post Share on other sites
rjg854 12,630 #147 Posted August 8, 2022 Carefully try some heavy leather wrapped around the ball and a pipe wrench. 2 1 Share this post Link to post Share on other sites
Snoopy11 5,723 #148 Posted August 8, 2022 8 minutes ago, josephbruce11212@gmail.co said: but man!! It's on there! Try a pair of channellock pliers... Don Share this post Link to post Share on other sites
Snoopy11 5,723 #149 Posted August 8, 2022 1 minute ago, rjg854 said: and a pipe wrench We posted at the same time @rjg854 Don Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #150 Posted August 8, 2022 That was my next option, just didn't want to ruin the knob but the heavy leather might be a winner. 1 Share this post Link to post Share on other sites
