ebinmaine 78,185 #76 Posted July 25, 2022 Just now, Snoopy11 said: Yes, particularly with the carburetor setup. It might be worth my while to pulley swap this tractor before looking into +++ rpm options... as I might very well be satisfied with a bit more speed... Don I believe that to be a real possibility particularly when you consider how much torque a k341 already has 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #77 Posted July 25, 2022 6 minutes ago, ebinmaine said: how much torque a k341 already has Yes... really... the more I think about it... the more I am erring on the side of a tiny pulley swap... as I am really just wanting a couple MPH faster in third gear high range. I already have a fast Horse... would probably win the Kentucky Derby... so I'm not needing anything fast... I just have a SUPER long driveway... and with a pulley swap, I could keep the rpms lower... while moving along at a nice pace.... which is really all I want. Nice conversation... the forum really helps logic things like this out... I think... next time I visit a farm store... I will look into pulleys and belts... Don 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #78 Posted July 25, 2022 Hey @ebinmaine... Eric... you wouldn't happen to know the bore size of the top of your head would you? I could always measure... Don Share this post Link to post Share on other sites
ebinmaine 78,185 #79 Posted July 25, 2022 Right now at wide open throttle that tractor should go about 6.2, 6.4 mph. If you swap the sizes of the pulley you end up more in the range of 10, 10.5. You'll have to make a whole new belt guard of some sort obviously. Third gear will be tricky but doable. Put the tractor in gear. Engine at idle. Let out the clutch slowly. Once rolling, increase RPMs. 1 Share this post Link to post Share on other sites
ebinmaine 78,185 #80 Posted July 25, 2022 2 minutes ago, Snoopy11 said: Hey @ebinmaine... Eric... you wouldn't happen to know the bore size of the top of your head would you? I could always measure... Don Yeah you better measure it and get it right the first time. I'm only familiar with the 70s vintage stuff and even then I've had some that probably were swapped out at some point and weren't right 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #81 Posted July 25, 2022 1 minute ago, ebinmaine said: Third gear will be tricky but doable. My first time going into third gear on this 416-8... I had the throttle all the way up, and let the clutch out... The good thing is... I'm already used to wheelies... so... it wasn't THAT uncomfortable... just... a little unexpected... Don 3 Share this post Link to post Share on other sites
ebinmaine 78,185 #82 Posted July 25, 2022 3 minutes ago, Snoopy11 said: My first time going into third gear on this 416-8... I had the throttle all the way up, and let the clutch out... The good thing is... I'm already used to wheelies... so... it wasn't THAT uncomfortable... just... a little unexpected... Don I've done that with my cinnamon horse so I know exactly what you're talking about. Same basic machine. 1 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #83 Posted July 25, 2022 5 minutes ago, ebinmaine said: If you swap the sizes of the pulley you end up more in the range of 10, 10.5 10 mph would be just about right. And... I always have low range to pull like hell... 6 minutes ago, ebinmaine said: You'll have to make a whole new belt guard of some sort obviously Hopefully... if I just go down 2-3 inches in size... things won't get too wonky... but belt guards are pretty easy to fab... Don 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #84 Posted July 26, 2022 So... the pulley on the 110995 transmission is a 5/8x6.5 inch pulley... thus... I plan to go with this: Don 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #85 Posted July 29, 2022 (edited) I got the muffler changed today. I hated the look of that big muffler coming out of the side... Oh, and as you can see in the picture... I put a 90 degree oil drain plug in... instead of the long piece of steel pipe that went over the axle... See below for the "before" oil drain Don Edited July 29, 2022 by Snoopy11 1 3 Share this post Link to post Share on other sites
ebinmaine 78,185 #86 Posted July 29, 2022 2 hours ago, Snoopy11 said: muffler Whutsatt offrum? 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #87 Posted July 29, 2022 1 hour ago, ebinmaine said: Whutsatt offrum? It's da' original muffler off the Duromax 457 that is on the L-157... Don 1 Share this post Link to post Share on other sites
Lee1977 7,632 #88 Posted July 30, 2022 (edited) On 7/25/2022 at 4:09 PM, Snoopy11 said: Hey @ebinmaine... Eric... you wouldn't happen to know the bore size of the top of your head would you? I could always measure... Don doble post Edited July 30, 2022 by Lee1977 Share this post Link to post Share on other sites
Lee1977 7,632 #89 Posted July 30, 2022 On 7/25/2022 at 4:09 PM, Snoopy11 said: Hey @ebinmaine... Eric... you wouldn't happen to know the bore size of the top of your head would you? I could always measure... Don Bore size should be the same on the magmun as the K. The the K341 is 3 3/4" standard. With a 3 1/4" stroke. Share this post Link to post Share on other sites
peter lena 9,846 #90 Posted July 30, 2022 @Snoopy11 AGREE WITH @ebinmaine on the kirk insite , personally , expecting a splash engine lubrication to keep up at high revs / loading , is like really hoping it will work , like those honda twins , pretty bombproof , hope you find your answer , pete 1 Share this post Link to post Share on other sites
davem1111 2,274 #91 Posted August 1, 2022 Tie rods: I thought I'd add this here, since it's somewhat related to Don's resto-mod. Before I gave him the tractor, I wanted the 8" wheels off the front to replace the 6" ones on my 312-A. I had them mostly swapped before I realized that this changed the required tie rod length on BOTH tractors. I guess the "ear" location on the spindle is different. I don't know if Don was able to adjust his enough or replaced them, but mine would not adjust far enough, so I needed to replace them. New required tie rod length was about 10". Buying another set of "stock" tie rods wasn't likely to work, since they would be the wrong length too, so I looked at some options to make some new ones. I'm kind of wishing I had gone with the Heim ends that someone suggested... I went with standard ends. I couldn't find 3/8" 24 threaded rod locally so I ordered a long piece. At Lowes I noticed that a 3/8" rod slid nicely into a 1/2" square steel tube so I bought some of that too. These new tie rods are 3/8" 24 threaded rod inside 1/2" square tube, with a little weld at the end of the tube to keep it from sliding around. I guess I could have used nuts to accomplish that but 1) it didn't occur to me at the time, and 2) I didn't have enough 3/8" 24 nuts on hand when I dove into this. I think these will serve well, but if not, I have some experience making them now and some ideas how to make even better ones. Tractor is back in service, front alignment is straight, and she steers nicely. 5 Share this post Link to post Share on other sites
ebinmaine 78,185 #92 Posted August 1, 2022 1 hour ago, davem1111 said: serve well You'll be just fine with those Dave. Very innovative replacement. 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #93 Posted August 5, 2022 First comment... now the 416-8 won't stop following me around... it goes everywhere I do. I realize that I am attached to it... but... gosh... now it is attached to me... Second comment... now the 416-8 wants special treatment, air conditioning in the garage...??? The L-157 and the 800S are jealous... Don 1 2 Share this post Link to post Share on other sites
ebinmaine 78,185 #94 Posted August 5, 2022 1 hour ago, Snoopy11 said: now the 416-8 wants special treatment, This can happen with the newer members. They must be carefully assimilated into the herd. 2 Share this post Link to post Share on other sites
kpinnc 17,766 #95 Posted August 8, 2022 (edited) On 8/5/2022 at 1:28 PM, Snoopy11 said: Second comment... now the 416-8 wants special treatment, air conditioning in the garage...??? You said that wrong Don. The 416-8 DESERVES special treatment. I fixed it for you ... Same for C160s. Edited August 8, 2022 by kpinnc 4 Share this post Link to post Share on other sites
Snoopy11 5,731 #96 Posted September 29, 2022 Got some more goodies on the old girl... @ebinmaine ...I think BBT will like this.... it glows... Don 1 1 Share this post Link to post Share on other sites
