Jeff-C175 7,209 #26 Posted September 5, 2022 47 minutes ago, RED-Z06 said: Think an air chisel might give more control? Dunno! You wanna give it a try and let us know? I don't have one or I would have tried it! 1 Share this post Link to post Share on other sites
RED-Z06 2,718 #27 Posted September 5, 2022 8 hours ago, Jeff-C175 said: Dunno! You wanna give it a try and let us know? I don't have one or I would have tried it! They are handy...just got one myself as a last resort to get the steering wheel roll pin out of a simplicity...an hour of hammering and it got it out in 10 seconds 3 Share this post Link to post Share on other sites
kpinnc 18,756 #28 Posted September 6, 2022 (edited) Jeff, Did you replace the valve springs? I think worn out springs regulary make clacking noises in a Kohler, even with the lash set correctly. If you set the valves too tight and the noise goes away, that's the surefire sign the springs are worn. Edited September 6, 2022 by kpinnc 1 Share this post Link to post Share on other sites
Jeff-C175 7,209 #29 Posted September 6, 2022 22 minutes ago, kpinnc said: Jeff, Did you replace the valve springs? I think worn out springs regulary make clacking noises in a Kohler, even with the lash set correctly. If you set the valves too tight and the noise goes away, that's the surefire sign the springs are worn. No, the only thing I did was pull the pan and remove the BGs. If I ever have it out again it will be for a full rebuild and I'll definitely keep this in mind, thanks! 1 Share this post Link to post Share on other sites
ebinmaine 79,729 #30 Posted January 1, 2023 @RED-Z06 Did you pull the gears yet? 1 Share this post Link to post Share on other sites
ebinmaine 79,729 #31 Posted January 1, 2023 On 9/4/2022 at 12:13 PM, Jeff-C175 said: crank gear at the red arrow Jeff these pics aren't showing anymore. Do you still have them to re-post? I'm looking to do the BG removal on a K341. 1 Share this post Link to post Share on other sites
RED-Z06 2,718 #32 Posted January 1, 2023 6 hours ago, ebinmaine said: @RED-Z06 Did you pull the gears yet? I did not...shes still hammering hard as ever, going to have to do it soon, i pulled that engine so many times in 2022 i didn't want to do it again... 2 Share this post Link to post Share on other sites
ebinmaine 79,729 #33 Posted January 1, 2023 58 minutes ago, RED-Z06 said: I did not...shes still hammering hard as ever, going to have to do it soon, i pulled that engine so many times in 2022 i didn't want to do it again... New year, new pull count? I did a set this morning. 1 Share this post Link to post Share on other sites
ebinmaine 79,729 #34 Posted January 1, 2023 I used a method mentioned by @kpinnc based on a thread by ((??)). @Marv... Drive the pins out. 1 Share this post Link to post Share on other sites
