ebinmaine 77,539 #76 Posted July 3, 2022 8 minutes ago, ohiofarmer said: Something to consider with metal siding on the building is house wrap. It really cuts the wind wanting to find its way into the building. i read about it somewhere and a buddy of mine tried it and has been thanking me ever since.. Also use rat guard at the base of the building to keep critters and wind from coming in at the bottom of the siding. Ours is going to be metal roof but wood siding. Still contemplating what to do under the metal but at the very least I think we're going to have a layer of felt. 1 Share this post Link to post Share on other sites
ebinmaine 77,539 #77 Posted July 3, 2022 More trees felled and cut up today. The area is really starting to open up! Trina and her mom used the 867 Pigpen tractor to haul wood. 🪵 🪵 🪵 5 Share this post Link to post Share on other sites
oliver2-44 11,272 #78 Posted July 4, 2022 13 hours ago, ebinmaine said: Did you coat/paint/treat your floor? No I didn’t do any floor coating at my shop or my dads shop. Both floors have a good steel trowel finish. Smooth but not slick. 2 Share this post Link to post Share on other sites
ohiofarmer 3,383 #79 Posted July 4, 2022 9 hours ago, ebinmaine said: Ours is going to be metal roof but wood siding. Still contemplating what to do under the metal but at the very least I think we're going to have a layer of felt. It is common to use fan fold insulation like they use as underlayment under vinyl siding. It comes in flat packets that are 48 inches wide and contain about 100 square feet. Being that width, they are laid as the roof is applied over them. Hopefully its not too windy that day. Felt paper would be much more difficult to lay over roof purlins. The slight breeze would take it off. 3 Share this post Link to post Share on other sites
ebinmaine 77,539 #80 Posted July 4, 2022 9 hours ago, ohiofarmer said: It is common to use fan fold insulation like they use as underlayment under vinyl siding. It comes in flat packets that are 48 inches wide and contain about 100 square feet. Being that width, they are laid as the roof is applied over them. Hopefully its not too windy that day. Felt paper would be much more difficult to lay over roof purlins. The slight breeze would take it off. The roof will have 4" pine strapping across the trusses that the felt and corrugated metal roofing is attached to. When he uses the rolled felt it's laid the same direction as the roof panels. That's obviously a bit unconventional but it's a lot easier for them to install the roofing and underlayment in the same pass. Gives them a place to stand. The climate here is rarely able to make enough condensation to run and the felt slows that even more. While it's certainly possible for the droplets to run down the felt and out between the strips, it's of very little concern. I'll ask about that fanfold. We sell it at my work. Certainly wouldn't hurt to have a little extra R-value up there. 1 1 Share this post Link to post Share on other sites
Achto 31,132 #81 Posted July 4, 2022 I recommend the fan fold as well. I've installed it on two metal roofs and it works out good. 1 1 Share this post Link to post Share on other sites
ebinmaine 77,539 #82 Posted July 5, 2022 Here's where we're at after 3 days of forest clearing. We've felled, limbed, sectioned and sorted a good strong 60 or 70 small to medium trees. On the left and forward of the tractor pictured there are 5 or 6 small trees left. I'll knock those down as soon as the tractor is gone. Should be in the next couple days. Tomorrow we need to mark the excavation lines and a "suggested NO zone". We'd like to stay a certain amount of distance away (12-15' ?) from the tree line on the left with heavy machinery if at all possible to maintain the health of the forest. If you zoom in on the center of the picture you can see a pile of future firewood. There's a VERY sizable pile of logs and cut pieces to picture left, out of frame. We'll have enough firewood for at LEAST 2 seasons after this. Next few days I change focus to getting the trailer hitch put on the Kia Soul and getting a tractor ready for Owl's Head show. Been mulling over taking one of the BBT's tractors that isn't often used. 1 4 Share this post Link to post Share on other sites
ebinmaine 77,539 #83 Posted July 6, 2022 Here's most of the pile of wood. Burnable stuff of course. There was a fair amount of hemlock and quite a good many small saplings that we just threw off to the sides... Left side Right side End view of the right side so you get an idea of the size of the pile 2 1 Share this post Link to post Share on other sites
lynnmor 8,644 #84 Posted July 6, 2022 3 hours ago, ebinmaine said: Here's most of the pile of wood. Burnable stuff of course. Most of that is a size that will be easy to work with, I have some similar size dead trees that need to be converted to firewood but they will be dropped in a jungle making it a project. 1 Share this post Link to post Share on other sites
ebinmaine 77,539 #85 Posted July 6, 2022 50 minutes ago, lynnmor said: Most of that is a size that will be easy to work with Agreed. We've come to a point as far as firewood that we only process stuff that's larger in diameter than maybe a baseball. If we can't split it at least once it just goes through the chipper or into the brush pile which eventually will go through the chipper. 1 1 Share this post Link to post Share on other sites
ebinmaine 77,539 #86 Posted July 23, 2022 Update with video describing the site from a side view. @Gregor @kwalshy. 3 3 Share this post Link to post Share on other sites
8ntruck 8,623 #87 Posted July 23, 2022 (edited) On 7/3/2022 at 10:50 AM, ebinmaine said: Ours is going to be metal roof but wood siding. Still contemplating what to do under the metal but at the very least I think we're going to have a layer of felt. My neighbor put a layer of OSB on the purlins, then a layer of what he called water &Ice, then the metal roofing. Did the same on his house roof when he rebuilt it last year. Edited July 23, 2022 by 8ntruck 1 Share this post Link to post Share on other sites
sjoemie himself 3,106 #88 Posted July 23, 2022 @ebinmaine you said it "quite a project" indeed. 1 Share this post Link to post Share on other sites
ebinmaine 77,539 #89 Posted July 23, 2022 8 hours ago, 8ntruck said: water &Ice Ice and water shield. Bituthene. We sell it at work every day. Excellent product for it's intended purpose of preventing ice jambs and some use it as a temporary roof covering. One of the reasons we're going with the building type we've chosen is to keep costs down. Adding a layer of any sort of sheet goods like OSB will dramatically increase the cost. It's a LOT of roof area. Share this post Link to post Share on other sites
8ntruck 8,623 #90 Posted July 23, 2022 That it will. Was just throwing an idea out there that has seemed to work well for my neighbor. 1 Share this post Link to post Share on other sites
ebinmaine 77,539 #91 Posted July 23, 2022 1 hour ago, 8ntruck said: throwing an idea out there that has seemed to work well I do appreciate all the thoughts and experiences of everyone. Share this post Link to post Share on other sites
rjg854 12,862 #92 Posted July 24, 2022 Just keep in mind, if you use steel on a roof, on bare purlins, you're going to get a certain amount of sweat because of the changing temperatures inside and outside the of the building. That's why you need a solid surface and vapor barrier under the steel unless the dripping isn't going to be a problem. 2 Share this post Link to post Share on other sites
ebinmaine 77,539 #93 Posted July 24, 2022 8 hours ago, rjg854 said: Just keep in mind, if you use steel on a roof, on bare purlins, you're going to get a certain amount of sweat because of the changing temperatures inside and outside the of the building. That's why you need a solid surface and vapor barrier under the steel unless the dripping isn't going to be a problem. At the least we'll have a layer of felt. As long as the water runs to the outside of the enclosed portion of the building it'll be fine. 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #94 Posted July 24, 2022 3 minutes ago, ebinmaine said: it'll be fine My favorite logo... Don 1 Share this post Link to post Share on other sites
kwalshy 246 #95 Posted July 25, 2022 On 7/22/2022 at 10:40 PM, ebinmaine said: Update with video describing the site from a side view. @Gregor @kwalshy. You have a good amount of excavation work on this project. And with that much fill material required with today's price of diesel, I'm sure that total cost is a pretty penny! I hope those big rocks/boulders are only the size of a WH or two, not the size of VW Bug! 1 Share this post Link to post Share on other sites
ebinmaine 77,539 #96 Posted July 25, 2022 3 minutes ago, kwalshy said: ! I hope those big rocks/boulders are only the size of a WH or two, not the size of VW Bug! Hahahaha. There'll be some of each I'm sure... When we moved everything around for the New Garden site out behind the house there was two boulders that a 40,000 pound excavator could pick up but not move away from the machine to full extension. 1 Share this post Link to post Share on other sites
ebinmaine 77,539 #97 Posted July 31, 2022 Well we decided to move the building away from the road a little more. We'll have to lay over a few extra trees. Here's a video describing the site including the building location. Share this post Link to post Share on other sites
ebinmaine 77,539 #98 Posted August 8, 2022 A few minutes ago I got off the phone with the excavator. We're still looking okay for the third or fourth week of August. We've decided to move the new building away from the road a little bit as of a couple weeks ago. I've also decided to add more drivable area out back of the building. That of course will add to the cost some but we submitted a high number to the bank and we also have contingency money above that so it should be fine. Share this post Link to post Share on other sites
ebinmaine 77,539 #99 Posted August 15, 2022 Excavation started today!!! We're headed up North so we'll have a fantabulous new yard when we get back. 2 Share this post Link to post Share on other sites
ebinmaine 77,539 #100 Posted August 21, 2022 This is the wood pile left by the excavator. Plenty of firewood 🪵 for next year. We've been working on cutting in to the pile to get it sorted out. Here's our new driveway the excavator guy did without me even asking. THAT'S customer service. Some views of the new area. This wall. Is AWESOME. ALL the rocks came out of the excavated area. Video as viewed from the base of the rock wall. 3 2 Share this post Link to post Share on other sites
